Guy
Forum Replies Created
Viewing 20 posts - 1,621 through 1,640 (of 1,898 total)
  • in reply to: BeoLink Passive #39993
    Guy
    If you are happy to keep using the BeoLink Passive to drive your speakers then there is no need to change.
    There is no specific need to keep ML. Simply use the Beolink Passive’s PowerLink input and treat this as you would any other Active speaker.
    If you need separate control of the bathroom speakers, then add an NL source with a Powerlink output.
    in reply to: Beolab 11 #39886
    Guy
    Try here: https://www.avaservices.co.uk/
    in reply to: Beovision 6-26 #39870
    Guy
    Perhaps you put in V.OPT 0, where it doesn’t respond to any IR commands.
    To set back to V.OPT 1, with the TV in standby (red light):
    On the Beo4, press the POWER button and LIST together.  Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show V.OPT.  Then press 1.  The power light on the device will blink to show that it has been accepted.
    Then try MENU again and see if the TV responds.
    Alternatively, have you tried MENU 0 0 GO to get back into the service menu, even if you don’t think the TV is responding to MENU?
    EDIT:  MENU 0 0 GO should still work in BtB mode, and should then allow you to disable it.
    in reply to: The best choice for your first B&O speaker? #39817
    Guy
    I am very pleased with my BeoSound 1 – bought for £120 on eBay a couple of months ago.  I used a small hammer to gently hammer out (from the inside) a couple of dents in the front grill and now it looks very presentable.  I mostly use if for FM radio (still going strong in UK), but occasionally for CDs and there’s an AirPort Express connected to the Aux input.
    IMG_6120
    EDIT:  The older ones (like mine, SW version 1.3) don’t have the clock or timer.  There is just a ‘sleep timer’ function.
    EDIT 2: Having watched Steve’s video more closer, I noticed that he selected AUX by pressing CD < and > simultaneously.  On my older SW version, you select AUX by pressing the search buttons (<< and >>) simultaneously.  (Or A.TAPE or AUX on the remote.)
    in reply to: LC2 Repair #39627
    Guy
    You have cleaned the acid of the smd caps?
    I actually cleaned the IR board before changing the caps, because the area (3-pins) where it connects to the main board looked discoloured. I have now given it a further clean and there is no change.
    I have had to pack it all away now because 4-year-old grandson is staying this weekend, but I will have another play next week.
    Thanks again for your suggestions.
    in reply to: LC2 Repair #39625
    Guy
    Thanks Die Bogener – all useful info!
    However …
    IR control worked for a while, then worked intermittently, then stopped working ?
    Touch control is still fine, and 5v still being supplied to IR board.
    Not sure what to look at next!
    in reply to: LC2 Repair #39623
    Guy
    Update:
    Resistor R1 5.6 Ohm replaced (temporarily with ‘metal foil’ replacement for controlled testing, now aware of fire risk).  Correct T1.6AH fuse also fitted (incorrect one was fitted by previous owner).
    Tested LC2 again:
    • 5V now present including to IR board.
    • IR still not working.
    • Touch control is working – dimming/switching correctly with 60W bulb fitted.
    Obvious place to look next was the 2 x 22uF capacitors on the IR board.
    I replaced these with 22uF 16v Tantulum beads that were left over from my BL5000 two-way repair.  Easier to solder than SMD replacements!
    Now fully working with both IR and touch control ?
    So a couple of questions before I place order with RS for correct fireproof resistor:
    • Any reason that I shouldn’t leave those tantalum bead caps in place?  I am happy to replace them in the future if the IR stops working again.
    • Any suggestions for replacing the (missing) little contact rubber between the PCB and the dome foil?  I was thinking of cutting a small piece from the Beo4 screen connection ‘rubber’.  Any better ideas, or is the part still avail from B&O?
    Thanks for everyone’s helpful comments so far!
    in reply to: LC2 Repair #39620
    Guy
    Ah, now I had a look at the schematics and indeed there were two 5.6 ohm resistors. I believe I had to remove the IR module to get access… My local dealer had one listed as a ‘flame proof resistor’, which appears to be a SPRX1/2 by Koa. The datasheet states: ‘fixed metal film, Flameproof, Ceramic Body, Flame Retardant Coating”. This was as good as I could get at the time.
    Thanks for the update – very useful.
    I did had a quick search and found this: https://www.partco.fi/en/electronic-components/passives/resistors/flame-proof-resistors/12325-fres-05w-5r6.html
    … so I’ll either go for that or the TE Connectivity one that I linked to earlier.
    in reply to: LC2 Repair #39619
    Guy
    Thanks Martin – I’ll be sure to fit the flameproof one.  To be honest, I wasn’t aware that resistors could be ‘flameproof’, but can see that in this application they are being used as a kind of secondary fuse, hence the safety requirement.  Every day’s a school-day!
    I was aware that capacitors have to be carefully chosen in the PSU stage.  I had an issue with a Beocord (V6000) a few years back.  My wife watch watching a VHS tape downstairs when I heard screaming that the video was ‘on fire’.  Actually it just had lots of smoke coming from it (by design?) rather than fire, but you can see the damage here:
    DSCF0809
    The smoke absolutely stank! The acrid smell hung around and was so bad that the Beocord went in the garden immediately and off to the dump the next day!
    in reply to: LC2 Repair #39614
    Guy
    I’ve had two cases of a dead LC2, and both times it was the 5.6ohm resistor (although my notes say R3?) that had gone open. No burn marks or anything. Both units work now.
    Thanks for that Lausvi – sounds promising! R3 is also 5.6 Ohms but it’s on the top side of the board near that white bridging wire (hidden by the IR module in my first picture).
    Did you find/fit a flameproof equivalent/replacement? The only one I can find is this:  https://uk.rs-online.com/web/p/through-hole-resistors/1870824
    in reply to: LC2 Repair #39616
    Guy
    Metall oxide or wire resistors dont burn… coal resistors do burn.
    Thanks Die_Bogener. I actually ordered metal film, so I will probably fit those for testing and then replace with the TE Connectivity Flameproof (which is metal oxide) if I am going to use it permanently.
    EDIT: And I have now read Martin’s useful post and link here: https://archivedforum2.beoworld.org/forums/p/36289/305349.aspx#305349
    in reply to: LC2 Repair #39611
    Guy
    There are 2 brown caps, the 220uf is prone to fail… yes, with shorts killing the resistor.
    Thanks – I’ll look at those. Should be easier than changing caps on a BeoLink5000!
    in reply to: LC2 Repair #39609
    Guy
    Yes it’s getting to be a pain!  So much of my stuff is in boxes since moving to a rental in Feb.  We just need UK house prices to crash (any day now …) and then I’ll be able to buy somewhere permanent to live!!
    in reply to: LC2 Repair #39605
    Guy
    Looks like a flame-proof type.
    Thanks Martin – that explains the ‘safety critical’ annotation in the circuit diagram.
    Also makes them hard to find!
    in reply to: LC2 Repair #39603
    Guy
    After thinking it twice, I thought that even if repaired, it would be a nonsense to have to use any 40w bulb nowadays and dropped the idea.
    I can’t remember what bulb I used but I am pretty sure that I tried my other working LC2 with some type of energy (LED) bulb and it worked (in the on/off mode, which is all I want). I can’t check because it’s in a box somewhere, but I’ll let you know when I have fixed this one!
    I use JBMedia’s Lightmanager Pro for day-to-day (night-to-night?) light control and that works very well.
    Anyway, resistors (pack size 50!), fuses and Zener on order …
    in reply to: LC2 Repair #39607
    Guy
    Thanks Die Bogener. I initially suspected those IR board caps (C7 and 8, both 22uF) after reading this old thread: https://archivedforum2.beoworld.org/forums/p/11884/103685.aspx#103685
    The IR board isn’t even getting 5V, and that main board resistor (R1) has blown. Not sure whether failed caps (do they fail short?) would have caused this.
    I am going to have to come back to this when I have dug out my soldering iron – it’s in a box somewhere …
    in reply to: Random eBay Stuff #39554
    Guy
    Please let me call them for you…
    I see that Banbury Lodge has 22 rooms. I have enough Beocom landline phones to fit one in each, with several left over … ?
    in reply to: Random eBay Stuff #39552
    Guy
    https://www.addictionhelper.com/rehab-locations/oxfordshire/banbury/banbury-lodge/
    Ha ha – that’s just down the road from my house ?
    But I just need two suitable Beovisions and a slightly older VHS player than the two I already have, and then I’ll be able to connect it all up!
    in reply to: Random eBay Stuff #39550
    Guy
    Here we go:
    IMG_6230
    And instructions:
    IMG_6235
    in reply to: Random eBay Stuff #39548
    Guy
    An MCL junction box?
    Close! The hole (and the two the other side) are for co-ax (aerial) cables.
