Guy
Forum Replies Created
Viewing 20 posts - 1,781 through 1,800 (of 1,898 total)
  • in reply to: BeoSystem 4 Auxiliary In #36154
    Guy
    I have not used this supplier but here’s a cable: https://www.ebay.co.uk/itm/134055567663
    Add one of these for RCA: https://www.ebay.co.uk/itm/123024786244
    Otherwise I am pretty sure that B&O supply a mini 9-pin to SCART plug/socket – see the following details (with part numbers) from the Beolink Handbook (click image for larger picture):
    scart mini av
    Then if needed your could stick one of these on the end of the SCART: https://www.ebay.co.uk/itm/333261656955
    in reply to: Beocentre 9500 Outputs #36171
    Guy
    Great point trackbeo – I would definitely try a cable change first as a possible (probable?) solution. Also don’t use your stand alone pre-amp – it’s not needed.
    Here’s the type of cable to which trackbeo referred: https://www.ebay.co.uk/itm/284178585525
    (That’s not a specific supplier recommendation – I just did a quick search on eBay!)
    in reply to: Beocentre 9500 Outputs #36168
    Guy
    Have you tried connecting your turntable directly to the BC9500’s phono socket (without adding your pre-amp)? What happens then?
    in reply to: Beocentre 9500 Outputs #36166
    Guy
    The Beocenter 9500 shouldn’t need a pre-amp as it has one built in for the phono input. But I would expect an overloaded/distorted output with 2 RIAA pre amps, not low sound.
    Also, this doesn’t explain why it doesn’t work when connected to AUX. Does the Beocenter work in all other respects, and have you tried another source into Aux?
    in reply to: Beosound 1 cd problem #36119
    Guy
    Mine does exactly that but only for some CDs, so I put up with it! I found it works best with older CDs from my collection, for some reason. Have you tried a variety of CDs? Was a CD inserted when you ran test mode (I think it should be).
    An un-educated guess would be problems with capacitors on the servo board – this it what causes similar disc-reading problems in other B&O CD players. Hopefully someone with Beosound 1 experience will be able to help further.
    The service manual isn’t much help as it just recommends board replacement!
    in reply to: MCL2P and Beovox rear surround speakers #36102
    Guy
    Yes that should work. The MCL2P would take both L and R rear signals from the TV and send to the respective speakers. I think you’ll need a Powerlink Mk2 cable between TV and MCL2P in order to get power on/off and muting.
    I don’t think you’ll find BeoVox3000 in the BV7’s speaker menu, so you’ll have to experiment with other speaker choices to get the best sound, at an appropriate level.
    Guy
    I wouldn’t discount a Playmaker. You can pick these up quite cheaply second-hand and they of course have built in trigger for Powerlink speakers via an RJ45 to PL cable.
    in reply to: new product: Balenciaga X Level[? A1?] #36065
    Guy
    ^ Thanks to trackbeo for bringing in details from the other two (now closed) Balenciaga threads. Next time we have duplicate threads I’ll instead try ‘merging’ them to bring content together. Apologies to MM and Mr10Percent for not doing so in this case – I’m new to this moderation business! ?
    in reply to: Not that I understand the purpose, but… #32955
    Guy
    I’ll close this thread so that future comments can be placed in a single thread (with the product name in the title) here: https://forum.beoworld.org/forums/topic/new-product-balenciaga-x-level/
    I do realise that this thread is placed in ‘General Discussion and Questions’, and the other in ‘Beoworld People and Lifestyle’, but this niche product would seem more suited to the latter! PM me if you disagree!
    Thanks for your understanding ?
    in reply to: Another cutting edge product #32961
    Guy
    I just formatted the above post just so that the quote was separated from the post!
    I assume that the post above was tongue in cheek, but the fact that we have three threads on the same subject does reduce the forum’s usefulness somewhat!
    TBH, I favour trackbeo’s initial post because he had the good sense to include the product name in the title. The two subsequent threads brought content and comment that should have been added to the first.
    I’ll close this thread now.
    in reply to: Beovision 7 LED – LCD Panel disassamble? #36077
    Guy
    Can you find a part number somewhere, search for another brand TV in which the panel is used and then find a YouTube video to explain dismantling the panel itself?
    I have just dismantled the panel in a edge-lit Samsung 32″ TV to try to fix a backlighting problem. In my case it’s actually unrepairable as the light diffuser sheet is cracked giving internal reflections. If it had simply been an LED problem it would have been an easy fix, hence well worth attempting.
    In the Samsung I had to disconnect a couple of ribbon connectors from the timing controller to the LCD screen, unclip all around the screen and then the LCD panel simply pulled away to expose the LED edge strip (and diffuser sheet behind).
    I couldn’t find my exact model, but here’s an example of one of the many videos that I referred to: https://www.youtube.com/watch?v=0h433tokO1U
    EDIT: This video was also quite useful: https://www.youtube.com/watch?v=77tymvTJDxo
    in reply to: CD 5500 running hot! left side near back #36009
    Guy
    Funny that I should still appear as a bronze member Guy, by the way ?
    I’ll raise it to Keith – I think there has been a fair amount of manual input required regarding membership status on transition to the new forum.
    EDIT: Now sorted thanks to Keith!
    in reply to: CD 5500 running hot! left side near back #36007
    Guy
    Thanks guys! I will reference the schems. It’s 117v, North America version I found some circuit board pics here, too: https://lampizator.eu/LAMPIZATOR/REFERENCES/Bangandolufsen/Bang%20&%20Olufsen%20CD5500%20CD%20player.html I see some caps and those 2 large things that look like solonoids?
    The full CD5500 service manual (incl 120V US version) is available on the site for Silver and Gold members, if that helps!
    https://beoworld.org/manuals.asp
    in reply to: World’s best B&O collection – 1,000 items! #35857
    Guy
    Great video thanks Steve! ?
    I suspect that I have nearly as many Beocoms – lots of charity shop ‘finds’ from when I lived in Denmark!  The rest of my B&O collection sadly doesn’t compare … ?
    in reply to: using remote for Radiostations? #35072
    Guy
    ^ You actually only need to add V.SETUP.  It will only be available when on a ‘video’ source (TV, DTV, V.MEM or DVD), hence the need for the blocking procedure mentioned above.  The other sub-options (TUNE etc) are added automatically.
    Hence if I add V.SETUP to one of my Beo4s, and when on a video source press LIST to show V.SETUP and then press GO.  Pressing LIST again will then cycle through TUNE, PICTURE, STORE, CLEAR, BASS, TREBLE, LOUDNSS and S.STORE.
    EDIT:  For completeness and future reference:  In a similar manner, you can add A.SETUP which (for audio sources) will give you just BASS, TREBLE, LOUDNSS and S.STORE.
    in reply to: Activate Camera input on BV6-23 with Beolink 1000 #35828
    Guy
    As far as I know CAMERA is not possible using BL1000.  The Camera socket is suppose to ‘auto sense’ and switch to that input, but I never got that to work on my BV6-26 or 6-23.
    Any chance that you could move the Nintendo to the DVI/PC input and then access using BL1000 by pressing  SHIFT then STORE?
    in reply to: Beocenter 8500 – Speaker Out Right #1 Not Working #35711
    Guy
    The usual mute relay symptom is that the output cuts in and out according to the load. It is caused by oxidation of the contacts rather than a purely mechanical relay problem.
    Guy
    Are you sure that it’s from the Beocenter and not another project?  I don’t recognise it from having dismantled mine (but I have the earlier single-belt tape deck) and I can’t see anything similar in the Service Manual’s limited exploded parts diagram.
    in reply to: Beocenter 8500 – Speaker Out Right #1 Not Working #35709
    Guy
    Have you checked the mute relay?  This is usually the culprit when the speaker 2 outputs are working fine.
    in reply to: Beovision Standfuß #35602
    Guy
    Some BV10-32 stand information (in English, sorry!)
    As far as I know there are two ‘official’ B&O stands for the BV10-32.  I have owned both.
    The Type 4707 is the motorised floor stand.  The top of the TV will be at 96cm from the floor, like this:
    IMG_6186
    This is the stand without the TV mounted:
    BV10-32 floor stand
    The other is the Type 4710 which is the motorised table stand.  I used one of these on the floor initially for my BV10-32, but found it to be too low (about 20cm lower than the floor stand, from memory).  Here is the one I had, but sold:
    IMG_5548
    I think that STB brackets sell fixed (non-motorised) stands but they are very expensive new and rare second-hand.
    I recommend the type 4707 floor stand.  I have used additional brackets to attach an Apple TV to mine behind the BV10-32.
