Forum Replies Created
GuyModeratorHere’s a copy of the instructions – hope they help!
You must be logged in to view attached files.Location: Warwickshire, UK
GuyModeratorSorry, yes I read it wrong!
But my suggestion to try a different media player to play the tracks still stands.
GuyModeratorYes, N.MUSIC is one of the options for the Beotime’s alarm source.
GuyModeratorHi and welcome to Beoworld!
I don’t have a BS5, but have you tried comparing the two formats using a different player, perhaps even WMP on your PC?
Also maybe try using Windows Media Player (instead of EAC) to rip to FLAC, and see if that makes any difference.
GuyModeratorThere is no sensor that detects the door position – the motor simply runs for a set period of time and alternates direction. If no noise whatsoever on first press, it sounds like a motor problem.
How technical are you? The service manual is available to Silver Gold members. I would probably open it up and maybe swap the CD and cassette motors to see if that determines the fault.
(EDIT: And welcome to Beoworld! The BC9500 is a great piece of equipment – well worth fixing!)
GuyModeratorI am not sure if it’s relevant but have you tried adjusting the phone’s AirPlay settings – I found this page on mine, perhaps ‘Automatically AirPlay’ is set to ‘Automatic’ on yours? Perhaps try setting to ‘never’.
EDIT: As an aside, I just noticed that ‘AirPlay Receiver’ option at the bottom, but scrolled down and realised that it is just for Apple Vision Pro, which is a shame!
GuyModeratorSo far I only have one issue. The 9500 has a constant low power-like hum when in standby mode. I’ve tried chsnging between 220v and 240v but I can’t hear any difference. Anyone else experienced this? The 9300 in contrast is completely silent in standby.
I had this when my BC9500 was placed on wooden bookshelves – the shelves seemed to amplify the hum.
I tried replacing these: https://www.dksoundparts.com/product/transformer-bushings-beomaster-3500-4500-5000-5500-6000-6500-7000-etc/
The old ones were rock hard, like plastic. However, I am not convinced that the new ones made much difference!
The problem is mentioned half way down this page, where there’s a suggestion of using cut up squash balls as feet!
EDIT: I found my post about fitting them: https://archivedforum2.beoworld.org/forums/p/189/345429.aspx#345429
GuyModeratorhow much is the stick from AVA Service?
£4.96 including 20% VAT
GuyModeratorGood work – I’ll be interested to hear if you can get hold of a new display and whether it cures the fault.
Hopefully this thread will encourage others to fix their BC2s while replacement parts still exist.
GuyModeratorI think that the correct order is earpiece, gauze (thin black sheet), felt/foam, metal. My foam had perished so I didn’t bother with that. When re-assembling, it can be held in place in the plastic cover using the small piece of tape on the metal piece.
The display disconnects at the circuit board. In my first post in the thread, you can see the white ribbon connector at the top left of the second photo. So, yes you will need to dismantle further following the YouTube video that I linked.
GuyModeratorIs the numbering in the schematic the same as my numbering? I know there must be a convention, but I don’t know it.
I don’t know, but from inspection you can probably work out ground, and maybe find the 12V (or 14V) using a multimeter and then have an educated guess for the remainder!
Out of curiosity, is the Avant wired the same as a BV11?
Looks the same in the service manual – this calls the connector a ‘MicroFit 4-pin’, if that’s any help.
GuyModeratorNormally I’d refer you to the service manuals (avail to Silver & Gold members), but here are screenshots from the relevant sections. I am not convinced that it is straightforward but if you can get it to work please come back and let us know how!
BV11:
BV10:
GuyModeratorA photo of the back of the display frame would be helpful so that we know what the retaining lugs look like.
I just removed it again to take a couple of photos. I noticed that one of my clips is indeed missing (blue circle), but it still seems to hold together well. The red circles show where the clips in red in the bottom photo hold.
EDIT: There are some very small clips just above the keyboard no 1 and 2 buttons. The cover pivots away from these as you remove it; there is no need to apply any tools in this area.
GuyModeratorPlease can you tell me where this Plectrums are from, can’t find it anywhere. Thanks Manfred
Like these, from any music shop or Amazon: https://www.amazon.co.uk/Different-Thickness-Non-slip-Plectrums-Electric/dp/B09Y1VXHK4
GuyModeratorThe guitar plectrums were very thin plastic. You could also use the corners of bank or credit cards but they may be too thick.
GuyModeratorI used two thin guitar plectrums, and slid them down each side of the display cover from the top. There are actually four little clips on the display cover, two at the top and two at the bottom. The display cover then lifts up away from the LCD. (You don’t have to remove any of the keyboard buttons, as the display cover is not clipped in this area).
Co-incidentally I took mine to pieces again yesterday to fit that new pointer. It works, but for some reason the LCD display fades and disappears after several hours. I can refresh the screen by turning off and on again, but there is obviously still something wrong. Perhaps the LCD itself is faulty.
GuyModeratorGreat news – glad that you got it working and the display of station names on the BS4 is an added bonus – I don’t think they display on BL3500.
I think that you can add many more favourites than four. Each of the coloured buttons represents a List, and in each list you can have up to 99 stations. From memory, I think you then access favourites by pressing (eg) RED 6, BLUE 4 etc. You can store N.MUSIC playlists in a similar manner. You may want to look for a Beoplayer rather than a Beoport user manual to see how to use.
GuyModeratorCorrect text is in pdf file attached:
GuyModeratorA thousand apologies but the Registry Update text that I posted earlier was corrupted. Each time I paste the text it converts the ” sign to unicode ” for some annoying reason!
The server URL in the Registry Editor should read:
https://nradio.beoplayer.com/nradiodata.asp
And should be enclosed with ” symbol at start and finish!!
GuyModeratorI might try a fresh install of Beoplayer on a Virtual Machine and see what happens.
I just tried a fresh install on a Windows 7 VM.
I ran the registry updater and no radio stations appeared. I then tried the other trick from that other thread as follows:
Navigate to C:\Program Files\Bang & Olufsen\BeoPlayer and look for a file called UpdateNotifier.exe
Double click to run a database update, whereupon you get this message: (Yours should say ‘Beoport’ rather than ‘Beoplayer’)
And all the radio stations rapidly downloaded.
EDIT: I noticed that no BBC radio stations were downloaded, so I checked the registry of the Virtual Machine and the downloaded radio database was last updated on 14 Jul 2023. I think B&O must have removed the BBC stations at this last update because they were no longer compatible.
