Guy
Forum Replies Created
Viewing 20 posts - 1,721 through 1,740 (of 1,898 total)
  • in reply to: BeoCenter 2300 AUX input from DAC line-out low volume? #37128
    Guy
    However, when I connect the RCA to Aux cable to the Topping’s stereo line out, I get barely audible sound from the Beocenter (at volumes 40+).
    Are you sure that the RCA to 7-pin DIN cable is wired as an input at the DIN end? (i.e to pin 3 and 5, not 1 and 4)
    in reply to: Wiring latest Beoosund speakers #37101
    Guy
    I would like to see if it is possible to use a CAT-7 cable and add a USB-C, ethernet and a mini-jack connection at both ends of the same cable, without distorting the signals?
    My understanding is that if you are not running gigabit ethernet (or PoE) then there are potentially two spare twisted pairs in CAT7. I reckon you could possibly pass analogue audio or power over the spare connectors but not both. I think the usb c power connection may be a problem because usb c uses the other data pins to confirm power requirements etc – it is not just a dumb voltage supply.
    It could well be worth experimenting, in which case get some of these to make it easier to swap connections around. Also, I would find some cheaper experimental devices rather than trialling with B&O equipment!
    (I was once going to trial passing ethernet to a smart TV over a spare in-wall hdmi cable – it may well have worked but I never got past the concept stage and have since moved house)
    in reply to: Beogram 8002 Cartridge Recommendation #37006
    Guy
    Unless you can find an MMC4 used your best bet is Sound-Smith SMMC4: https://sound-smith.com/cartridges/bo/smmc4 at $200.
    … plus $55 shipping and packing. Plus about £55 import duty (payable direct to UPS) if shipping to UK.
    Anyway, once I’d recovered from the shock I was very pleased with the performance of the SMMC4 (in my BG6500).  I did make a mental note for next time to check whether SoundSmith have a European agent/reseller, thus reducing costs a little.
    in reply to: Beosound 9000 mk1, mk2, mk3 data-link #36980
    Guy
    Even my (gen 1) BeoSound 1’s service manual shows the AUX datalink pins connected to its processor.  As I said, there seem to be several errors. (BS3000 service manual likewise)
    I would quite like to control my BG6500 via my BeoSound 1 ?
    in reply to: Beosound 9000 mk1, mk2, mk3 data-link #36976
    Guy
    I think that the early BS9000 may have datalink.  The service manuals on site show datalink present in the Mk1 (Types 2521 to 2530), but not present in the Mk2 and Mk3.  However, B&O service manuals have been known to be wrong in the past.
    I think datalink was dropped from most products as N.RADIO and N.MUSIC compatible products were introduced, such as BS3000/3200.  N.RADIO used the old PHONO IR command.
    The early BS9000s Mk1 were not N.RADIO/N.MUSIC compatible, hence required a SW upgrade.  Perhaps such a SW upgrade disables the datalink capability.
    in reply to: Beolab 3500 mit Beolink Wireless 1 plus IR-Eye #36941
    Guy
    Sorry for answering in English.
    The Beolink Wireless should only be used with an IR eye when it is connected to Beolabs (eg BL8000) by powerlink.  In such a setup it acts like a ‘wireless’ Beolink Active.
    Your BL3500 is correctly connected to the Beolink Wireless by Masterlink cable.  The IR eye cannot control it because it is further up the ML chain.  You will have to keep using the BL3500’s IR receiver to control it.
    in reply to: B&O’s amazing hoard of vintage products… #36949
    Guy
    Thanks Steve – great video as always!
    I think the 3 little TVs on the floor (2 mins in) are MX1500, not 1000. I don’t think there was an MX1000, but could be wrong!
    in reply to: Beolink 5000 E-Ink screen repair / mod #34611
    Guy
    For info, here are three of my failed screens, two of which are now in the post to pilatomic. Subject to his investigations, we’ll start a new ‘Beo4 Screen Failure’ thread with any findings!
    All the following are trying to display ‘RADIO’
    Screen AScreen BScreen C
    in reply to: Beosound 3000 MK1 vs MK2 #36762
    Guy
    By the way, what does A.OPT 5 and 6 mean and what is the functionality of these commands?
    Similar to A.OPT 1 and 2 but where the product is in a LINK room.
    See here: https://www.beoworld.org/beotech/mlsetups.htm
    in reply to: Beolink 5000 E-Ink screen repair / mod #34610
    Guy
    @matador – can you help, or shall I delve into my boxes???
    Hi Guy, I’m afraid I can’t help, I have no spare screen, all the faulty I have are mounted on remotes.
    No problem – I’ll dig one out!
    in reply to: Beolink 5000 E-Ink screen repair / mod #34608
    Guy
    If you still have one (or more) damaged screen in your possession, and are willing to ship them to France, please PM me.
    I do have at least one failed screen in a box somewhere. However, if matador (also France based) has one it may be easier to get from him.
    @matador
    in reply to: Beosound 3000 MK1 vs MK2 #36760
    Guy
    Further to the above, there is the ability to check the SW level of the BS3000 using Test Mode.  It’s all explained in the service manual, available to Silver and Gold members.
    in reply to: Beosound 3000 MK1 vs MK2 #36759
    Guy
    You can upgrade the SW of BS3000 to sw3.4 by purchasing a new processor chip here: https://shop.oneremote.dk/shop/69110-parts-for-bo/4074-firmware-bs30003200-v34/
    Their description would suggest that one of the later updates was to include A.OPT 5 and 6.
    To be safe, it could be worth checking that the upgrade works on all BS3000s, including the Mk1.
    (I haven’t purchased the sw upgrade so can’t vouch specifically, but I have bought other products from them that have worked well)
    in reply to: Beolink 5000 E-Ink screen repair / mod #34606
    Guy
    My experience is exactly as matador’s above.  I always try to clean/replace/retighten the zebra strip, and clean the PCB where it connects. I have also tried a new zebra strip with the old screen, which didn’t work (same lines missing), whereas a new screen with the old zebra strip did work.
    I have probably replaced about 10 screens.
    in reply to: A question on circuit board from my beolab 6000 #36639
    Guy
    You’d have to remove both the bridges (i.e below each 120V label) and replace across the 240V.
    If you consider that the transformer winding terminals are numbered 1 to 8 from the left, then for a 240V supply you need 1 to be connected to 5 (hence the bridge), with the input  supply connected to 4 and 8.
    (That’s from the service manual – avail to Silver and Gold Members!)
    in reply to: BeoCom 5 + BeoLine 2 #36594
    Guy
    If you know someone who has a Beocom 5 (or even a BC6000 Mk2) it could be worth trying to reset the base with their phone.  It could be worth buying a second hand BC6000 Mk2 – in my experience they are better phones than the Mk1.
    Also worth asking a B&O dealer for a quote – if they still have their Beocom test equipment it shouldn’t take long to re-flash the SW of the Phone and/or Base.
    Also, reading back through the thread I don’t think we actually tried a reset of the Beocom 5 itself.  I understand that can also be done using the 9#9#9*INT sequence, as discussed here: https://archivedforum.beoworld.org/forums/t/35637.aspx
    in reply to: Beosystem 2300 Doors Won’t Close #36499
    Guy
    +1 for the rubber belt – I replaced it on mine and it solved the problem.
    You can get the correct belt here: https://www.beoparts-shop.com/product/belt-for-beomaster-6000-ouverture/
    You could also try a little silicon lubricant in the runners (apply with q-tip) but to be honest all you are doing is making the belt’s job easier.
    in reply to: Update of Beovision 7 #36447
    Guy
    The only external box that I am currently using is Apple TV.  I have previously used Humax boxes, both Freesat and Freeview, but most modern TVs have DVB-T2 built in so I’d only need something if I wished to record.
    Here in UK the popular subscription services often have STBs, such as SkyQ, Virgin Media TiVO, BT YouView.  I don’t use any of these so I am not even sure if they all have IR remotes.
    There may be people with BluRay players that would want these included.
    If new STBs could be downloaded (like the later B&O downloadable PUC tables) I would image that users would find this very useful
    Guy
    Anyway, maybe a little out of topic do you know how to trigger A.AUX from the 5000?
    Does SHIFT RADIO not work (same as BL1000)? My BL5000 is in a box so I can’t check it!
    in reply to: Update of Beovision 7 #36445
    Guy
    Rudi,
    Another question: Any plans to add PUC control for STBs? Perhaps this could just be a software update as the hardware (IR receivers/transmitters) is already present.
