Forum Replies Created
GuyModeratorI must have been busy with something else because I totally missed this draw – many apologies for not being there in support!
Anyway, many congratulations to all the winners; I am very envious of the Beosound Stage (well done @miniac) as it’s one of the products that could tempt me away from the Beo4 and onto a newer remote or two.
And ‘Merry Christmas’ to all Beoworld Members – thank you for all your support and contributions over the past year! 🌲🧑🎄🎅🎁❄️🎄
GuyModeratorHi Guy, I am having similar problems with my BeoCom 1 6000 phone. I have three of them and one lost base connection.
Thought it could be battery but still can’t connect with it. Tried all the suggestions I find on line and no solution. Not sure when B&O stopped
selling phones but would you know of BeoCom IT or help individual in New York City that could help? Thank you!
Early European BC6000s often developed an rf transceiver problem, where the only fix was replacement of the main PCB. I am not sure whether this problem extended to the US models.
If you have tried all the reset procedures mentioned earlier in the thread (including perhaps resetting the base unit) then it could be worth trying to find a B&O specialist who can look at it from a SW perspective, although it’s possibly hardware related. I don’t know of any NY specialists, but maybe an older established B&O dealer (if you can find one) could still have some Beocom test equipment in store. However, I am not sure that a fix would be cost effective, so you may be better off looking for a second hand replacement, making sure that it is a compatible US model by referring to the model and type numbers as mentioned in the table I posted earlier in the thread.
I hope that helps!
GuyModeratorAh, I should have checked – you registered nearly 4 years ago, and may well have been on the old forum too!
Here’s another device that will carry out the same function: https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/
Or you could look for a second-hand B&O Playmaker – they have auto-sense on the aux input: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND_SYSTEMS/PLAYMAKER/UG_Playmaker_EU_US_current.pdf
GuyModeratorHi and welcome to Beoworld!
The answer is ‘yes’ – the RCA line-in has auto-sense which will trigger the PL and Beolabs. You may well have to set up autosense (sensitivity etc) in the menu, accessible from most browsers or the B&O app. You will also have to set up whether the output should be fixed volume or controllable (via remote or B&O app).
GuyModeratorI just wanted to let you know that I tidied up the forum to reflect your change of username and have deleted the other thread with my erroneous response.
As I said in the deleted thread, your best bet may be to find a ‘spares and repair’ BC9500/8500 and move the parts across.
GuyModeratorAlso have a look in this thread regarding the AV mini DIN connector and the official B&O scart adapter
@Madskp Your link didn’t show, but you may have meant this thread (V1 has the same input): https://forum.beoworld.org/forums/topic/beoplay-v1-connection-old-stuff/Location: Warwickshire, UK
GuyModeratorHave you tried a handset reset? Process varies according to model, so is your a Mk1 (with dot to left of circle button) or Mk2 (with INT button to left of circle button)?
If Mk1 handset:
Reset handset: Press (dot) 7 000 9
If Mk2 Handset:
Access Service Menu by pressing 9#9#9✱INT then scroll to ‘reset handset’ and press centre button.
GuyModeratorThat sounds like a battery problem. Try swapping batteries between your BC6000s and see if the problem moves too!
GuyModeratorWelcome to Beoworld Michael!
It sounds like you have the Beovirus, like many members here including myself!
Feel free to post photos of your collection – either here or (preferably) in the ‘Flash Your B&O’ thread here: https://forum.beoworld.org/forums/topic/flash-your-bo-newer-thread/
GuyModeratorMy BV11 came with a Panasonic Blu-ray player which is mounted rather nicely on the back. I have set it up with the PUC cable but for some reason, it powers on whenever I power on the system, rather than only powering on when I set that source. It also does not power off when I put the system into standby, even though I have set it to do that in the BV11 settings.
Can you try selecting a different model of Panasonic Blu-ray to control? I haven’t used the downloadable PUC commands on a BV11 or newer, but on the older PUC system you sometimes had to experiment with different models to get the behaviour that you want.
I do have one question – I like a bit or retro gaming and I would like to connect my old Nintendo GameCube to it. I have a S-VHS cable for the GameCube but found that it does not fit into the little round AV socket on the BV11. Could anyone tell me what kind of plug that AV socket takes?
It’s a mini DIN 9-pin connector. Sounds Heavenly sell a cable but that may just be for audio input – worth checking with Steve.
EDIT: From the service manual:
GuyModeratorYou think a mk2 board would fit into it if my dealer cannot help?
Yes. If you have a look at this thread you will seen where I mixed and matched parts, eventually putting the Mk2 innards in the Mk1 case: https://forum.beoworld.org/forums/topic/beocom-2-repair/
GuyModeratorMy own Mk2 is a mixture of parts from a Mk1 and Mk2, both bought ‘not working for spares’. I wouldn’t read too much into the battery clamp and base that it came with. I think the SW version is probably the best indicator of the actual type.
GuyModeratorThe format of your date and SW version makes me think that this is an early, original Mk1 Beocom 2 that will only register to its own original base (that was built into the charger base).
Have a read of this thread which sounds like a similar problem: https://archivedforum2.beoworld.org/forums/t/23438.aspx
Some Beocom 2 Mk1s were modified by dealers so that they could be registered to other bases. I think that this was just a SW change.
When I check my Beocom 2 Mk2, the SW version simply says: ‘Ver 1.2‘ with (on the next line) the date ‘May 8 2006‘. Production date is further down the list and states: ‘Sep 22 2008‘. ‘Reset base’ is also one of the available options.
It could be worth asking a dealer if they still have the equipment to update the SW.
GuyModeratorYou can view the latest SW updates here: https://update.bang-olufsen.com/products
GuyModerator GuyModeratorGreat news – have a good weekend!
GuyModeratorThe Build type in RED is strange. I searched using AI and it came up with:
The red text for the “Build Type” in your BeoVision 10’s service menu indicates that the television is currently running on engineering, prototype, or non-standard service software, rather than the official consumer release.
This status is an internal flag used by Bang & Olufsen technicians during development, testing, or specific repairs. It is not typically seen on a standard retail unit with regular software updates.On the Monitor page is there anything listed against the DVB-T/C field?
Or is there a DVB service menu page with DVB CONNECTED shown as YES/NO?I would double check your satellite connections at DISH and TV end – can you check it with another TV?If all else fails I would be tempted to note all your settings (if you can view them) and then try a Factory Reset.Location: Warwickshire, UK
GuyModeratorAll the relevant BV10 documentation is available from B&O in various languages here: https://support.bang-olufsen.com/hc/en-us/articles/360041518732-Beovision-10
Make sure you follow the instructions in the ‘Connections’ sections, and hopefully all will become clear!
GuyModeratorFirst two in your list are quite probably due to failed battery (hence not storing start up volume).
Third problem may be mute relay failure, but not if happening with powerlink outputs (if that’s what Penta 3s use).
Mute relay failure is usually confirmed by connecting speakers to Speaker 2 sockets, as the mute relay only effects speaker 1 outputs.
16 November 2025 at 11:16 in reply to: Removing a Beovision V1 from a swing opening wall bracket #71206 GuyModeratorI’ll try to attach the instructions as I am not sure if they are on the site elsewhere.
As you can (hopefully) see the metals rods slide into the casing of the TV, and are release with little hidden catches top and bottom (diagram 10 on the pdf). The TV then needs separate rod assemblies to replace the bracket parts, if that makes sense!
It may be best to unscrew the whole assembly from the wall and then remove the bracket part.
EDIT: The manual is also still listed on B&O’s support page: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOPLAY%20V1/Wall_Bracket_BeoPlay_V1.pdf
You must be logged in to view attached files.Location: Warwickshire, UK
