Forum Replies Created
matadorModeratorMaybe a hint,
Because of my setup (two Beosound Daisy-chained) and mu usage (once one, once the second, once both…) I need to fiddle with the “LINK” prefix key.
Sometimes when I need to shut all down I make a long press on the “Stand-by” key that turn all off.I wonder if this do not make the remote revert to two way mode., because to change the mode, process say you must turn off the remote with a long press on “STBY”.) barely similar to taking the batteries out and in the remote.
matadorModeratorBonjour Sylvain,
In the international part of the forum, the rule is to keep messages in English for everyone to understand and be able to help.
The message from MM made me realize than I dont know the BL5 that I use to consider as Classic Beolab but seems to no be.
Then you should take all I say with caution and maybe seek for a second advice.Yes today, as in the Usual B&O world, speakers are turned on by the source: there is specific trigger signal in the Powerlink connection that clics-in the Beolabs.
Some Beolabs have a line-in connection with auto sense that detects sound, turn on the speaker and turn it off after some minutes of silence.Also, Beolab 5 being a tremedous pieces, I would really take care to what I’m sending it to. Of course, the Playmaker is not an Hi-quality device but it is at least B&O.
Maybe you can also have a look at the Beosound Core, I think it has Line in.
matadorModeratoris it me?
Short answer: No, it’s not.
Long answer: it may depends from the kind of 8000 you have – Mk I, II, II.5, III or even 8002. I think I have MK II and I’ve always been dissapointed compared to 4000 or even the Beoplay A1!
matadorModerator matadorModeratorHave you tried with or without? What do you think?
Beograms 12XX had removable lid without hinges, actually the same lid that was use on the Beocord Open Reel tape players.
Those Beograms are actually and really nicer without cover than with.I really would not bother about this. But I’m curious to read other member’s advice.
matadorModeratorHi Giorgone,
With all due respect, to people that understand and hear better than me, that kind of question always make me smile.
open lids act as a resonance trap that can negatively affect sound quality.
Yes maybe, but what about the mileage of the tip? will it “never be the same again” once it has touched the record?
And what about the reflecting power of any frame in the room? Not talking about the density of the concrete your house is made of…
And your lacation on any tectonic plate. Doesn’t even your presence in the room affect the acoustical flow of the soundwaves?Just listen to the music and let the audiophiles make their things.
I, by the way, listen with the lid open, just because it’s a beautifull deck that has to be seen spinning.
Regards
matadorModeratorHi,
All below given your network is 2.4 Ghz and not limited at 5 Ghz.
I could be wrong but as much as the WiFi is really unreliable on those things, I believe the electronics are quite strong. I would advocate for a software error.
First thing I would try is to check the Playmaker shows up on the network when wired. You can use any tool built in on your system, any command line or any utilities around (Who’s on my WIFI, IP Scanner,…). If it shows up you’ll get the IP adress and you’ll be able to connect to it wired. That will tell you your Playmaker is working. Next you’ll be able to select a wireless network – While still wired – in the dedicated page. If no network shows up it’s maybe the wifi part of he PM. If it can see networks, and let’s say none of yours, the problem is in your setup.
All this given your network is 2.4 Ghz and not limited at 5 Ghz. 5 Ghz wifi is always complicated with old devices.
matadorModeratorRead the whole thread, there is something somewhere about scaling the parts.
matadorModeratorBonjour Sylvain, Yes I’m French.
I dont know how do works Beolab 5 about digital connexion and so so I’ll talk as if they were like usual Beolabs connected by Powerlink (the DIN cable between the BeoSound 3200 and the speakers.
First, in the the B&O world from this era the BeoSound was just a source (Radio, CD player, Aux-In, sometimes cassette) and the power amp was built in the speakers. Thats why they’re called Beolabs – Active Speakers – instead of Beovox – Classic Passive Speakers – and that’s why you don’t see any box between the BS and the BLs.
For your setup you have three scenarios:
Number One: you dont use the BS at all meaning it’s just a gateway to volume control the speakers and plus your airplay receiver. You dont use CD or Radio. The you can simply get rid of it and use only the Playmaker/Essence. Both have Powerlink connection. In that case the playmaker will be better because it responds to IR commands (Volume, Sound Setup and switching sources when the Auto sense is temparemental.
Number Two: you use the BS CD or Radio mostly and your phone or deck sometimes. Then connect the Playmaker/Essence as a source for the BS A.AUX in. You will be in a configuation close to yours today, except that if you start the deck (given airplay streaming is off) it will be select automatically and go to tha BL throught the BS A.AUX. The little Added Bonus is that you can then press ‘PHONO’ Insted of ‘A.AUX’ on the BS: Absolutely useless but hey, isnt the moto of the brand “Attention to details”?
Number Three: you use Airplay mostly and BS CD, Radio or deck sometimes. Then connect the Beosound as a source for the Playmaker/Essence A.AUX in.
Now you can keep the BS off when streaming and just need to turn it on for Radio/CD or phono with your deck connected to the A.AUX of the BS.
If Airplay is not streaming, selecting any source on the BS3200 will trigger the PM and send the sound to the Beolabs.If any of that make sens, think of what would suit you and we will advise you of cables, options and remotes subtelties to have it working flawlessly.
By the way I use a similar configuration with Playmaker, a Beosound 9000 instead of 3200, Beolabs 8000 instead of 5 and a record player.
Good luck.
matadorModeratorHi,
Not BV6-22 but I’ve got a BV6-26 (actually a BC6-26).
I’ve also around the house BL4000, BL8000, BL6000 and some third party Airplay speakers.
Between all, best and amazingly sounding to my ears are: ex-æquo BL4000 and BC6 and all the rest far after.Now I believe BV22 and BV26 have different speaker setup (one way vs two way) but anyway, what I want to say is those thing have to be seriously considered. And also they could be very usefull for more that just sound.
Hope this helps.
matadorModeratorHi,
Find yourself a Playmaker or Beosound Essence MK1, both cheap second hand.
In a nutshell it’s a B&O airport express like device with added Line-In terminals with auto sense switch-on.
It will autodetect the source between Airplay and your deck and will avoid you the manual switcher.
matadorModeratorI’d like to add tha I’ve some Beo 4 that exeperience similar issue: not reverting to one way of course, but stopping to work after some time. Dont know if it could be related.
matadorModeratorThank you Steffen,
I use Ladda batteries: I like to keep it all “nothern”!
And I’ve add aluminium foil pads to secure the contacts.
matadorModeratorHi,
I’m not an IT specialist but have experienced some of issues like yours more or less. So whatever I said could be stupid or not.
What I would do would be to disconnect some items: All but the 8’s or “crescendo” just to check that it’s a problem related to the Beolab network connection or just what I would call “broadband pumping” – too many clients on one network.
Then, if the 8’s success in a stable connection, I would try to give everybody a Static IP and wire whatever coud be wired.
Last thing I would do is carefully access the wi-fi Mesh network; I’ve seen Airplay speakers just next to a relay connecting by default to one that is two rooms away, thus making the connection instable.
Hope this helps.
matadorModeratorHi,
Maybe worth checking the A.AUX jumper plug? Continuity may be broken on one side.
matadorModeratorIt’s like I wanted to start the same topic but didn’t dare to.
So all respect to the OP and sincerely merry christmas to everyone here.M.
matadorModeratorThen this how it ends so far…
I specify I’m using a Beolink 5000.
BS9000 in A.Opt1 (IR control enabled).
Playmaker in A.Opt4 (needs “Link” button prefix).Pros:
Full IR control on the 9000 allowing to control CD and select sources like radio (I’ve discover the very fancy RDS display with song names, etc…), but also and most important, “Phono” that allows me to open the path to the BG4002 and enjoying the “Phono” display…Allows me to get rid of the external source selector I used to use to switch the line in from the Playmaker between BG and BS.
The “+link” gymnastic to control the PM needs a little training but doesn’t seems like intolerable: I don’t change volume every second, and when you add “+link”, the device seems to remenber it for a few time so volume control often do not even require that sequence.
Full standby works with a long press, whatever the whatever.
Cons:
Sometimes I need to read again this post to understand how all this really works.
(Edit to add cons) Sometimes the Beolink 5000 loose the one way setting and, messing with the limits, its annoying.(Cable management in progress)
matadorModeratorWhen Laser problems, first always check in the technical datasheet that your’s is a genuine kyber crystal. Sometimes it may ruin your CD but it is well know to last long – Like 6 or 10 iterations plus spin-offs.
More seriously, if your CD lens is one of the common ones – Meaning 20$ on the bay – don’t bother but be ready to try one or two before the right one comes. All details on BW II or there.
And in any cases, try the “deep clean method” widely discussed in our colums.
It does not work everytime but has a fair amount of success.Finally, in my experience, the weak link in a CD mechanism is the lens, so CD not spinning, no motor noise, etc… Is in most case due to laser fault.
Someone did once explain me the full CD start sequence and it did make sense.Clean or change the lens.
Good luck.
matadorModeratorThank you to the Men In Black Boxes Team!
I’d like to not add another box to the setup. It already has a Beolink passive that drives Beovox C-40 in the back from the Playmaker Powerlink out.
The less bad option would have been using a Beo4 to command the 9000 and the Playmaker in Option 4, not the more convenient but at least just one remote.
The problem is that I dont use Beo4, I use a Beolink 5000 I find nicer.Another solution would be a fine programming of a Beo6 but I keep that for later.
Thanks again to you both.
matadorModeratorWhen in A.Opt 4, does all command need “Link” pressed before or do some commands like Volume and Mute work as usual?
