Forum Replies Created
matador
Moderatorwould it also be possible for you to design (stl files) those clamps for the 6000 series?
In theory, yes. But I don’t have Beolab 6000 to take measurements, do the adjustments and figure out how to fix them using the speakers hooks.
matador
ModeratorHi Tuttivini,
Thank you.
Interesting point you raised, that allow me to add some comments.
I’ve asked my brother in law (the father of the kid who printed the clamps for me) if he would do the same thing and he smiled at me saying “no”. What I understood is “if you have 8000’s keep 8000’s, don’t make them look fakes 18’s or even worse, fake B&O”.
It made me think. But just the pleasure of trying was enough (and the grills were already made at that time). That said, I can’t swear that the fabric covers will never return.All this to say that I rather the 18’s “hommage” over the 18’s “copy” or “makeup”.
On top of that and more grounded, rounding the lamellas would have been a lot of manual work I’m not sur to be able to do. So I went for another way of doing it:The ears are half rounded, and the rounding leads to the angular front-end, making all this quite pleasant in real. Enough to me.
Another detail I like every day when looking at them (and I must say, over other commercial alternatives) is that the chrome top cap of the column stick out of the wood top line. I’ve always thought that the wooden grill on Bl8000’s makes them look weird because our eyes are so trained to “wood=ALT”, they were always missing something. To the point of thinking to add a falser ALTs with Liliviken caps!
And then, I can see this little chrome ring sticking out the wood and it’s enough to me to balance de speaker design.Now, more seriously, the important part is the clamps (and even more, the back part of the clamp), as a piece or as an idea.
It’s open to anyone to make it better, with thinner lamellas, different angles, better wood or wood work. I did go for cheap, that’s why I’ve advertised a total cost of 50€.See this as a proof of concept and make it better, I’m sure it can.
Next work: the black 80 denier Woolford fret!
Cheers and thank you all for your comments.
matador
ModeratorIt would look like a little box with line-in and line-out sockets and a 5V input (or whatever is need to start the Beolab AND power the box circuitry.
Inside there will be a relay or something similar that would be triggered by the amplified Line-in signal (sound). The relay would have an auto hold loop with some sort of timing circuitry (I.E it would stick for “some” time when no sound is present and then open).
Output of the relay will trigger or not the 5V to the Beolab.
Now, Please note that I’m totally ignorant of how it could impact sound (since we’re playing with the main audio feed, but as far as I remember my electronic classes, this is not NASA technology here.
matador
ModeratorIt seems like the trigger is going on as soon as a line signal is received and turns itself off after 6 minutes with no signal.
I’ve always wonder why no “electronic Guru” ever made that kind of thing: a box that amplify audio signal enough to trigger a relay with a timed auto hold that could power up any Beolab from a line in signal.
I say this as an ignorant but theoretically it doesnt seems so from an outer world, no?
Even by retro engineering the RCA line in part of a Beolab 4/6/8 x1000.
Just a thought.
matador
ModeratorHi alls,
The STL’s are now attached to this post.
Credits and big thanks to Keith who add this feature so fast.
matador
ModeratorI am looking for a second cartridge to use while servicing the turntable. I don’t want to take the risk of something unexpectedly happening and damaging the MMC1.
More seriously, I understand the fear of damaging a so valuable cartridge. Really, I was there before.
But we’re not talking about a cheap thing that can easily be found in different qualities and price ranges.
Unless you’re (very) lucky, an MMC4 will cost, whatever the way you get it, around 200$/€.
It can be a broken MMC plus refurbishment, a refurbished MMC, a NOS one (beware of NOS), or even a useless one sold as good.Refurbishing a Beogram is a long, careful, and meticulous process. When you’re there, taking in an out the cartridge for tests isn’t the big deal, moreover with an MMCx (compared with an MMCxx where your always afraid to break the bridge).
And if I’m not mistaken, there is plenty of work to do before even needing to plug-in the cartridge and when you need, then it’s just a matter of adjustments than can be done carefully.
Whatever the price of a cartridge, it may be better used in components or spare.
Even if an MMC1 is legendary, I reckon.
matador
Moderator… plus $55 shipping and packing. Plus about £55 import duty (payable direct to UPS) if shipping to UK.
Thank you for pointing that, absolutely true, import duty are not their fault but true anyway, and 55$ shipping and packing? C’mon on…
Glitch wrote:
I’ll have a hard time justifying the purchase to my wife.Seems we’re all doomed with the same curse! 🙂
matador
Moderatordo you work for the swedish furniture company with the blue/yellow logo?
Like everybody in the world, I’m a customer.
But not a worker! Thank you for seeing the “hommage”. 😀
matador
ModeratorHi,
Have you read this?
https://archivedforum2.beoworld.org/forums/p/36279/270046.aspx#270046
matador
Moderator matador
ModeratorThank you Soren.
I would like to say that I, also like things to be 101% originals.
But the temptation, of having something close to, or just to try to mimic and maybe succeed, won.
The funny part is now it’s done I may soon revert to the original frets or even previous speakers.
I like the result, but for a so called “enthusiast” it will always see them as a fake thing, not 8000’s anymore and never 18’s. I had fun copying the fancy Beosystem 72-22 like for common people but I still see it as an experiment, and nothing more.
But to me it raised some questions, like the one you answered, that’s the fun of it.Anyway, theses speakers are in my office, where I spend most of (99%) of the time seated in the same place. Will check about directivity.
Thanks for stopping by…
matador
Moderatorit just needs an old retired tv tecci and some parts…
Like everyone of us…
matador
ModeratorHi Olivier.
Thank you, all you linked to worked and it was indeed an answer if I understood it well.
What I understood is:- The effect of the grill may or may not be negligible.
- Speakers are tuned with the grill.
- If the grill has an effect, changing it may affect the rendering of the speaker.
- That change may (scientifically) or may not (perceptibly) obvious.
- I reckon for, say a level, it’s not important if you change the grill — fabric for wood or the other way around — aftersale.
- But for an high end speaker like the BL 50 or even 28, what happend when you change the original setup? Beliviing that client for them are “aware” of rendering.
Thanks again Olivier.
matador
Moderator… and how is the weather at your place?
Hot but manageable, there is air in the house…
Thanks for asking.Location: Paris France
matador
ModeratorIn terms of sound I would prefer a redline 140 speaker over a pair of 8000 any day.
I never listen to Redlines, but the Beolabs have replaced a pair of P50 who already had replaced S45’s, so I know what you mean and I’m… Not happy!
(Well, in fact I’m slowly getting use to them, I cranked up the bass a bit in the playmaker and compensate the mids and highs wit a pair od C40 in the rear, I start to like them)
matador
ModeratorHi guys,
Thank you all or your interest.
As suggested by a member I’ll upload the file to thingiverse or similar platform for public access. I’ll also try to contact Christian Leicht who as a portal with printable B&O parts.
Will do it in the next days, along with a quick notice for assembly.
matador
ModeratorMessage sent to both of you.
matador
Moderator matador
ModeratorCould anybody make a quick recap of the different headphones and their differences?
I can’t see clearly in the lineup and struggle to understand the difference between an HX and a Portal. I mean, I know one is intend for music and the other for games but what does it mean in real life if you listen to music with a Portal or watch TV with an HX?
In the case of the H95, I believe it’s all about finishing and sound quality certainly above the average lineup but even that I’m not sure.
A pensum would help, Thanks in advance.
matador
Moderator@Stereomensch: Yes! And the fir is perfect to tint.
# Spassmaker: of course. I just dont know how to add an stl file to a post.
