Mark-sf
Forum Replies Created
Viewing 20 posts - 421 through 440 (of 463 total)
  • in reply to: Beogram 1700 speed trouble #35040
    Mark-sf
    If you have access to an oscilloscope you should find a 500Hz sine wave on P1 of the motor connector when the speed is set to 33. It’s possible that the motor control chip has been damaged. Check the schematic available at https://beomanuals.com/manuals/Beogram/Beogram%202402/Beogram_2402-Schematics.pdf. While its a different model it uses the same motor control circuit.
    in reply to: Beocenter 7007 intermittent auto phono mute issue #34756
    Mark-sf
    Your problem is not likely an electronic one but a mechanical one. There is a muting switch under the tonearm that is activated by the arm movement. It likelly needs its contacts cleaned. The service manaul is at https://beomanuals.com/manuals/Beocenter/Beocenter%207700/Beocenter_7700-Service_Manual.pdf. The part is 1567 in the parts list but the diagram marks it as 1557. You open it by removing screws in the rear and it hinges from the front.
    Mark-sf
    I would not hold my breath given that B&O is out of the turntable business. You might try contacting Rudy over at https://beolover.blogspot.com/2015/01/beogram-40024004-apple-remote-controls.html and see if you can convince him to come up with an 800x version.  I have the one for my 4004.
    Mark-sf
    Your BeoSound stage manages remote commands only via BT, HDMI or Ethernet and your 8002 needs a wired datalink signal coming from a Master system. From my knowledge your BeoSound does not have a source Master system interface nor do those ML and MCL components.  The Master system is what decodes the output of your Beoremote One IR commands into the datalink control signals the 8002 receives via its DIN connector.
    The other issue you have is that you need to get the DL signal into a Master system component which do not pass through your phono preamp as they have their own DIN signal pins.
    in reply to: Custom Beogram SP10 Sp12 Sp 14 stylus #34935
    Mark-sf
    Excellent work. Having done something similar for the Beogram 4002/4 series and GRado Signature carts(which I sold many in the 80’s),  I fully appreciate the time and effort. I am confused by your statement that the cartridge is sealed in the shell as from your pictures you have omitted the cartridge body and its 4 pins that plug into the arm and are only displaying the SP stylus shell. In my case I re-wired the tonearm and built a special socket receptor for the pins. I don’t see any cartridge pins in your pics, hence the question.
    in reply to: Beogram 8002 motor control issues #34864
    Mark-sf
    95GU55 or 95GU56 should work fine as replacements for the PU51.
    in reply to: Beogram 1202 #34710
    Mark-sf
    In the bottom cover there are two holes that adjust the set down point for 7” and 12” records. It is easiest to place it on a stand or supports so that you can watch the arm without having to constantly flip it. If your bottom does not have the holes then you will need to remove the 4 corner screws and remove it first. These eccentrics should be marked and are in the from of the cam gear.
    in reply to: Beogram 8002 Diagnostics and repair #34670
    Mark-sf
    That model has many electrolytic caps that by now have started to fail. That is usually the cause of it spinning backwards. You should start by replacing them in the power supply and motor/coil section. Once you’ve confirmed correct and stable voltages then you can see if there are other issues.
    in reply to: BeoCenter 9000 troubleshooting #34501
    Mark-sf
    I would continue to check for the proper power supply voltages to the different modules. Even though all the fuses are fine, a unit this old can have failed or failing electrolytic capacitors. I believe the tuner section has at least one rail dedicated to it (12v) and you also will need +-33 to the chip power amps.
    in reply to: Beocenter 9500 #34300
    Mark-sf
    You have one foot still attached on the front right about 6″ in. I believe they are bigger than those for the Beograms but you can compare their part numbers in respective service manuals.
    in reply to: Beocenter 1 Replace Contrast Screen #34462
    Mark-sf
    While I have not done it myself, the screws as seen in the parts figures are not threaded but keyed. Since they depend upon gravity to drop down, they could be simply stuck and once in the proper release orientation be pried downward with a spudger.
    in reply to: Beomaster 8000 Beogram 8000 Colour #34331
    Mark-sf
    You may have not gotten an answer earlier because your question is confusing since the Beogram 8000 control panel is made of plastic so scratches do not reveal a different color. I know of no way to fill in and blend this that will not make it visually worse due to the matte finish.
    in reply to: DIN Cable Question on 4002 #34313
    Mark-sf
    If you want to get rid of the hum then you have to take action.
    1. Try the connection with/without the ground connection and report the results.
    2. The ground wire needs to be connected to a solder lug on a screw terminal under the back right top plate that you can remove by pulling the wood trim forward.
    3. From that same lug, there should be a connection to the black multi-pin connector.
    Please see the excellent video by Beolover
    in reply to: DIN Cable Question on 4002 #34310
    Mark-sf
    As I stated don’t even bother with sourcing a DIN cable. For the RCA one, they can either take quality bulk cable such as Mogami or Cardas and terminate one end with quality RCAs or you can buy a premade RCA-RCA cable and they can remove/cut the connectors on one side.
    in reply to: DIN Cable Question on 4002 #34308
    Mark-sf
    Unless you are connecting the table to a unit with a DIN input you do not need to put back the DIN cable. While that is a cheap RCA cable it is one that B&O used on later 4004s and many others. If the hum does not change when using the ground wire to your phono inputs it’s likely that it’s not properly grounded internally. I have replaced many of these and it needs to be done correctly since the DIN cable has a double shield system. Are you comfortable with soldering? If not a competent tech can do this but I would simply use a higher quality RCA cable.
    in reply to: BeoGram 6000 chassis suspension #33608
    Mark-sf
    Sorry, there was a typo in my response. I meant 88cm.
    in reply to: BeoBalcony – setup suggestions? #34239
    Mark-sf
    This is not recommended due to the risk of condensation shorting out or corroding the electronics. I would recommend you bring them out only when you are enjoying the good weather and views.
    in reply to: Beocord 5500 Drawer Closing Noise #34180
    Mark-sf
    Martin: Do you know what that preset time would be?
    This time is not adjustable and is only a few seconds sufficient to close/open the drawer. The issue is that the motor should not be continuing to run. Since it is seeing 13v when closed, the OpAmps are active. Since the drawer does open and close, the signals from the two pins of 1C8 are working, but may not be resetting.
    in reply to: Beocord 5500 Drawer Closing Noise #34178
    Mark-sf
    Thanks Martin. This then means you need to check how long those pins are active in each direction. If the go back low once the drawer closes then I would look at the OpAmp driver circuit to see if there is a bad cap for example that is keeping the output latched.
    in reply to: CDX repair problems #34225
    Mark-sf
    Those relays are not likely your problem as they only govern pre-emphasis and end up simply bypassing a resister. Your best bet is to try and trace a test tone from a CD. If you don’t have a scope an AC multimeter can work if your tone is a bass one.
