Mark-sf
Forum Replies Created
Viewing 20 posts - 241 through 260 (of 463 total)
  • in reply to: Beocenter 7700 power supply problem #45534
    Mark-sf
    Either FM jack is fine as it depends on the type of antenna. If using a dipole wire type you should use the 300 ohm. 75 ohm is for a coax-based external antenna.  Regarding your cassette, have you replaced the belts and check the idlers/pulleys for freedom of movement? As to the display, unless you have bad solder joints if those segments never light up then it is likely the LEDs.
    in reply to: Beogram 4002 Type 5513 45 RPM Not Functioning #46594
    Mark-sf
    Setting the tracking force is a 2-step process adjusting the counterweight for balance and the knob controls the force via a spring. When adjusting the counterweight it can get skewed by binding on one of its support slots. The same bracket has a V-support that the lift solenoid engages governing its cued alignment. Either of these can skew the arm.
    in reply to: Signal generator help #46744
    Mark-sf
    Such a device will work for this particular setting assuming your multimeter supports RMS readings to 1K. An alternative would be to use an app on your phone or tablet such as AudioTools that actually provides a cleaner output and offers more functionality.
    in reply to: Signal generator help #46741
    Mark-sf
    As a former B&O service tech, I have always used RMS as the AC voltage measurement unless it was annotated as p-p. This is standard across the industry because it is equivalent to a DC measurement for example when computing current draw.
    in reply to: Signal generator help #46739
    Mark-sf
    It generally refers to RMS for such adjustments and you can use a multimeter wit RMS support to measure.
    in reply to: Beogram 4002 Type 5513 45 RPM Not Functioning #46591
    Mark-sf
    Assuming the LED is getting power, I would check that the collector of 1TR17 transitions from 0 to 20v when a black stripe goes by. BTW, the service manual has a troubleshooting flowchart for this specific issue.
    in reply to: Beogram 4002 Type 5513 45 RPM Not Functioning #46589
    Mark-sf
    There is a clear right-angled plastic piece that has black lines on it that moves with the tonearm There is a lamp in a black plastic housing that illuminates a photodarlington transistor. I would check that that lamp is working. If it is, the the transistor may be bad. The detection of those black lines are necessary to find the edge of the record, switch to 45 and return after playing.
    Mark-sf
    The 7000 has active cooling using a fan. Is that running? Are you measuring this at idle? I believe the fan kicks on at 50 degs.
    in reply to: Beogram 4002 Type 5513 45 RPM Not Functioning #46587
    Mark-sf
    Only the 33 button will cause the platter to spin for cleaning purposes. Once you have the arm moved over and paused, then pressing the 45 button should change the speed and illuminate.  Can you move the arm over using the Play button and push the Cue buttin to cause it to lower and begin playing. If that doesn’t work, there may be an issue with the solenoid circuit or its mechanicals. The area should go up and down with the Cue button at any point except rest.
    in reply to: Beogram 4002 Type 5513 45 RPM Not Functioning #46585
    Mark-sf
    First focus on it not finding the record. The lamp+Photocell handles this at the end of the fixed arm. Do you see the B&O logo at the end lit up? If not that bulb needs replacing. If you are, then the lamp’s and photocell’s alignment may be off. The black insert pulls out of the arm enough to allow it to drop down in most cases or you can remove the arm screws under the cover.
    in reply to: Beogram 1600 cartridge adjustment #46549
    Mark-sf
    How are you connecting it? Type of cable – DIN or RCAs? Phono Input on what component?
    in reply to: Beogram 1600 cartridge adjustment #46546
    Mark-sf
    That could be multiple adjustments. Go through the adjustments detailed in the above service manual.
    in reply to: Beogram 1600 cartridge adjustment #46543
    Mark-sf
    Not sure which adjustment you are seeking. Take a look at this service manual for all. https://beomanuals.com/manuals/Beogram/Beogram%202400/Bang-Olufsen-Beogram_2400-Service-Manual.pdf
    in reply to: Styli for Beogram 1000 #46534
    Mark-sf
    Yes you can use an SP9 which has an elliptical diamond.
    in reply to: Beogram 5500 LH channel not working #46335
    Mark-sf
    The fact that you got both channels working albeit at a low level into the Sonos points to the Beomaster phono inputs. You stated you have the RCA DIN adapter. I would try that as it allows you to switch channels to see if the bad channel follows. If it does not then it’s a Beomaster problem.
    in reply to: Beogram 5500 LH channel not working #46331
    Mark-sf
    When muted all pins are connected. That’s where the 0,2-0,3 Ohms come in. When unmuted, the L- and R- are still connected (signal ground), so when measuring between L+ and R+ you are measuring the two coils in series. Their common center connection to ground doesn’t matter, seeing as you are not measuring with respect to ground.
    Martin, I was not commenting on the first diagram. It’s the second that is wrong. It should read
         *    1480      *
    740.              740
    *.     .0.2      *
    in reply to: Beogram 5500 LH channel not working #46329
    Mark-sf
    Those do not look right. Measure the cartridge pins when it’s not installed. The pins are looking from the back: L+. R+ L- R- The 740 ohms should exist between L+ to L- and R+ to R-. There should be no resistance between R+ and L+.
    Unmuted; When the cartridge is fitted to the arm, the two coils have their respective negative ends connected to signal ground. This means that if you measure from L+ to R+, you measure the two coils in series (2x 740 = 1480). All fine. Muted; All cartridge pins are connected to signal ground. All fine. Martin
    Martin, I agree but the diagram is still wrong as a single pin cannot have 1480 and .2 ohms. It would be 1480 and 740 ohms.
    in reply to: Beogram 5500 LH channel not working #46323
    Mark-sf
    L+.    R+
    L-      R-
    in reply to: Beogram 5500 LH channel not working #46320
    Mark-sf
    The muting switch shorts the signal to so your ohm readings are correct. What you need to measure is when the cartridge is plugged into the arm and the switch unmuted you should see around 800 ohms on both channels.
    in reply to: Beogram 5000 #46218
    Mark-sf
    I’ve not worked on one but I believe from the manual that there is a snap on LED cover that you remove to release it and the wire stays attached to the LED.
