Guy
Forum Replies Created
Viewing 20 posts - 1,641 through 1,660 (of 1,898 total)
  • in reply to: Random eBay Stuff #39545
    Guy
    On the top view it’s a C7 power plug and there is only one “screw ear”, on the side views it’s a 12v jack and both “screw ear” are there.
    I’d missed that – well spotted!
    Great inputs – let’s find some other strange eBay B&O listings about which to ponder …
    Here’s one I actually bought. I now know what it is, but any guesses?
    in reply to: Random eBay Stuff #39540
    Guy
    One of the pictures shows part Nr 1638, with is Beolink Active.
    Yes I saw that on the casing, but I think the internals and end plates are bespoke for another function – or the modifier has done an excellent job of disguising the ML socket etc! The usual ‘raised’ socket labels and ‘BANG & OLUFSEN’ logo are also missing, and I have never seen such white lettering.
    Could it be a low pass filter, extracting the Subwoofer frequencies from the rest, like the Powerlink outs on Beolab 2 or 11?
    We’ll never know. Strange that the Subwoofer socket is an input rather than output? Perhaps it’s a dealer device like that speaker switch that has been discussed in the forum before.
    in reply to: Random eBay Stuff #39538
    Guy
    Quite a weird thing indeed, but I’l not a specialist…
    And more importantly, do I need one?
    Yes you do, to tell us what it is…. ?
    Ha ha ? That’s why I have so many boxes of B&O in my spare room!!
    in reply to: Beoport/Beoplayer #39438
    Guy
    Seems to be running fine on my 32-bit Windows 10 also
    bp1
    in reply to: Beosound Moment and Beolink Wireless #39528
    Guy
    The Beolink Wireless 1 will only distribute Masterlink, which your Beosound Moment does not have.  You cannot use the Beolink Wireless to bridge a PowerLink connection.
    Before we suggest solutions, is your intention to have the BL5s in the same room as the Moment, and are they the only speakers that you wish to connect?
    in reply to: Beosound Moment and Beolink Wireless #39525
    Guy
    Can I just ask whether you are talking about the Beolink ‘Wireless 1’ – the 2006 version with the little switch on the base where you chose whether it is a transmitter or receiver, as described here: https://www.beoworld.org/prod_details.asp?pid=1028
    in reply to: Beosound Moment and Beolink Wireless #39530
    Guy
    The good news for MisterBG is that the Beosound Moment has inbuilt WISA that will transmit to WISA wireless speakers – some of the newer Beolabs have WISA receivers built-in.
    In order to provide the WISA facility for older speakers, B&O introduced the Beolab Receiver 1, which acts as a WISA receiver and provides a Powerlink output to Beolab speakers.  One Beolab Receiver 1 is required for each Beolab (Left and Right).
    However (as Beobuddy has just pointed out) the BL5 is incompatible with Beolab Receiver 1.  This is explained in this thread, in which Steve also suggests a workaround making use of the BL5s’ Line inputs: https://archivedforum2.beoworld.org/forums/p/25222/201651.aspx#201651
    So MisterBG could either buy a couple of Beolab Receiver 1s and use Steve’s workaround, or stick with the wired solution.
    in reply to: Beo6 Best Practices #39387
    Guy
    If your windows is 64-bit and the Beo6 FW is 2.12a or older then that may give you problems.  Have a look at Keith’s post (and the attached diagram) here: https://archivedforum2.beoworld.org/forums/t/13349.aspx
    in reply to: Beoport/Beoplayer #39436
    Guy
    But you do have to tell it which folders to scan:
    Screenshot (85)
    in reply to: Beoport/Beoplayer #39435
    Guy
    This thread reminded me that I still have Beoplayer installed on my PC – not connected to anything else B&O (apart from the A2 Active that I use as a speaker for my desktop).
    Playing music on it now! (from my QNAP NAS)
    Screenshot (86)
    in reply to: Three generations of link-system #39203
    Guy
    Do you have any ideas about inspecting a pickup besides listening to it?
    Sorry but my Beogram/MMC experience is limited to my BG6500 (Beoworld Xmas Prize Draw win), its SMMC4 and a single LP – Dire Straits, Brothers in Arms ?
    I am sure that other forum members can help out and will be along to offer advice …
    in reply to: Three generations of link-system #39201
    Guy
    Good to hear; I think that fitting a compatible RIAA to the BM6500 is a good idea that keeps the system as close to standard as possible.
    According to the service manual, when the RIAA is installed there are three links on the original PCB that need to be cut to ensure that the phono signal is diverted via the RIAA.  (EDIT: Actually one of these that needs to be cut is the connection to datalink pin 7, because non-RIAA-equipped Beogram use pin 6 for datalink)
    I bought my ‘S’MMC4 from Soundsmith in the US.  They also do SMMC1, 2, and 3 if your budget stretches further than mine!
    in reply to: Beo6 Best Practices #39382
    Guy
    is the software “open” to access without a temporary login as the on e the installators used to have?
    When you open the configuration tool, you tick the ‘work offline’ check box and then you won’t need a password.
    in reply to: Changing cloth on BeoLab 8000 > instructions? #39498
    Guy
    This thread may be of some help:  https://archivedforum2.beoworld.org/forums/p/10043/87230.aspx#87230
    If only the pictures were there too!  It could be worth asking Keith if he can find them, but I am not sure if this is possible.
    in reply to: Beoport/Beoplayer #39433
    Guy
    Beoplayer runs fine on my 32-bit Win10 PC, although I haven’t actually connected the Beoport/PC2 for a while for a fuller check.
    I have the impression, those softwares doesn’t scan all ripped CDs. Tehy are in st same folder, but can’t be seen on the Beoplayer interface. Scanning doesn’t help.
    What file types are your ripped CDs?  Beoplayer won’t find flac files – I think it may be limited to mp3s (and possibly wav) only.
    Some of my previous Beoport/PC2 experiments/investigations are within the following threads:
    https://archivedforum2.beoworld.org/forums/p/5529/49968.aspx#49968
    https://forum.beoworld.org/forums/topic/beolink-pc2-and-beo4-remote-on-macbook-pro-early-2015/
    in reply to: Three generations of link-system #39199
    Guy
    I can’t tell from those photos. Perhaps it will have to be opened to check.
    are there any RIAA preamps that can be built in a Beogram 9500?
    I really don’t know. There are lots of similarities between the RIAA and non-RIAA beograms (they share a service manual) but I am not sure if an RIAA (either B&O or third-party) will physically fit or be compatible.
    In the shared service manual there is only one circuit diagram covering BGs 3000, 3300, 3500, 4500, 5005, 5500, 6500, 8500, 9000, 9500 and TX2. This shows the RIAA as a discrete PCB (PCB4, part number 8005269) but annotated to say ‘only in Beogram 3500/4500 and 6500’.
    Perhaps other forum members have better knowledge of the Beograms; it could be worth starting another thread titled ‘Retrofitting RIAA in Beogram 9500’.
    EDIT: You can see pictures of an internal RIAA in this document – para 7:  https://www.condoraudio.com/wp-content/uploads/Projects/BeoGram-4500-Turntable-Restoration-Repair.pdf
    in reply to: Three generations of link-system #39197
    Guy
    it might have the RIAA and looks a lot like this picture.
    If there was an RIAA it would possibly be visible just to the right of the board with the two blue connectors, but the RIAA board would be mounted vertically but perpendicular to the rear panel of the BM.
    in reply to: Three generations of link-system #39195
    Guy
    If it doesn’t have a built-in RIAA
    If you do need to look inside the Beomaster, I now know where the RIAA board would be fitted! It’s rear left of the pre-amp PCB, fitted vertically about 5 cm inboard of the antenna socket. To see if you may have to pivot the Tuner board upwards into its service position.
    If you look carefully at this eBay listing, on the bottom left of the fourth photo you can see a row of holes labelled ‘RIAA’ (just visible!) into which the board would be soldered: https://www.ebay.co.uk/itm/255129827540
    Good luck with the move to Spain!
    in reply to: THE BEOWORLD AUTUMN 2022 PRIZE DRAW !! #39417
    Guy
    Many congratulations to all winners!!
    However, it was jolly quiet tonight ?
    Either:
    –   The cost of living crisis has bitten and people can no longer afford broadband, or…
    –   End of month, hence ‘millionaire’s Friday’ (payday) and everyone’s out on the town! ????
    in reply to: THE BEOWORLD AUTUMN 2022 PRIZE DRAW !! #39414
    Guy
    Hurry up! At least two people are waiting … ?
