Guy
Forum Replies Created
Viewing 20 posts - 1,381 through 1,400 (of 1,749 total)
  • in reply to: BeoVision 10-46 picture gets to much green #41204
    Guy
    Hi gerard,
    I deleted that previous response because the User (now blocked) added a spam link.
    Did the TV suddenly start behaving like that (in which case it may be a fault), or is there a possibility that someone has gone into the Picture or Service Menu and adjusted the settings?
    If you want to look in the Service Menu, the following is from the Service Manual:
    The Service Menu must be activated while the TV SETUP menu is displayed. From
    this initial state, the Service Menu is activated in the following way:
    Beo4: the Service Menu is activated by pressing 0 0 GO within 3 s.
    Be careful to note any settings before adjusting (maybe take a photo).  You may also want to try resetting the TV to factory settings, which is one of the options in Service Mode.
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    in reply to: BeoSound 3000 – Type Numbers #41518
    Guy
    As far as I know (from the Service Manual) type numbers simply relate to the country of use (and corresponding supply voltage):
    3000
    in reply to: Beoport N.Radio stopped working #40623
    Guy
    isn’t the decoding handled by windows media player though?
    I am not sure. I think I will just wait and see what happens.
    To be honest most of my radio listening is on good old FM, which isn’t due to be switched off until 2030, so I am good for a few years yet!
    in reply to: Looking for trigger box for Powerlink input #41338
    Guy
    Do you have a link to an example of the Playmaker?
    Presume you mean a link to one for sale?  There’s nothing on UK eBay at the moment. This one’s in Hungary: https://www.ebay.co.uk/itm/225263989300
    I have seen them go for as little as £50 on UK eBay in the past – as always with eBay the trick is to be very patient!  I usually save an eBay search and add email alerts.
    By the way, do you know of any DIY kits, or boards that I could use for self-build integrations?
    Sorry – none that I am aware of.
    in reply to: Looking for trigger box for Powerlink input #41336
    Guy
    A further thought – you could also use a Playmaker. There’s auto-sense on the aux in socket that will trigger connected Powerlink. Playmakers can sometimes be bought quite cheaply on the second hand market.
    in reply to: Beoport N.Radio stopped working #40621
    Guy
    I today had a response from B&O about the BBC radio stream:
    We regret to inform that when BBC changes their streaming codecs, the Beoplayer will no longer be able to support it. We apologize for the inconvenience caused.
    in reply to: Connect Essence MKII with old IR eye? #41324
    Guy
    How to place the essence in IR mode?
    To use Beo4, you must set the audio system in A.OPT 1.
    To set A.OPT 1 with Beo4…
    Point the Beo4 remote control at the IR-receiver of the audio system.
    – While holding down the • (red dot) button, press LIST.
    – Let go of both buttons.
    – Press LIST repeatedly until OPTION? is shown in the Beo4 display and press GO.
    – Press LIST repeatedly until A.OPT is shown in the Beo4 display and then press the number button 1
    EDIT: Info from here: https://support.bang-olufsen.com/hc/en-us/articles/360041742571-How-do-I-activate-sources-using-BeoRemote-One-or-Beo4-
    in reply to: Beoport N.Radio stopped working #40620
    Guy
    Maybe email b&o asking for the stream to be updated for the beoport – Im guessing windows media player can play these streams as it appears HLS is nothing new?
    Thanks Rob – I’ll drop them a line and see what happens. I will report back here.
    Everything is now pretty much working apart from the strange muting on change of radio station (as mentioned in the other Beoport thread) so I am happy despite these limitations.
    in reply to: Looking for trigger box for Powerlink input #41333
    Guy
    Something like this would probably do what you require: https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/4154-powerlink-aux-expander/
    in reply to: Looking for trigger box for Powerlink input #41327
    Guy
    Maybe try Steve at Sounds Heavenly at his sponsor link below ⬇
    in reply to: Beoport/Beoplayer #39491
    Guy
    It’s great to hear that my Beoport/Beoplayer investigations have been useful!  Apologies also to the OP, but he hasn’t been seen since 2 Oct so I hope I haven’t frightened him off with all my ramblings.  To be honest much of my input has been to preserve the ‘knowledge base’ as some of these devices get older, and it’s great to see that XavierItzmann is looking at novel ways to use the Beoport to solve a particular problem – namely providing an ML audiomaster.  Please keep posting back with your findings and suggestions.
    My Beoport is back in the cupboard for the time being.  Today’s task is to dismantle (and hopefully fix) my 16-year-old Brother printer that is malfunctioning – typically I am too tight to buy a new one!!
    in reply to: Connect Essence MKII with old IR eye? #41320
    Guy
    Do you means the round one with timer button (or the earlier rectangular MCL sensor, with timer button).  EDIT:  I just read this thread and realised that you are talking about the newer round one!
    https://archivedforum2.beoworld.org/forums/p/20517/168404.aspx
    When you say that you ‘connected the cables as described’, did you replace the DIN connector with an RJ45 plug, and if so what wiring scheme did you use?  That earlier thread suggests that if you just stick with IR data, 5v and Ground then the IR will work, but not the buttons.
    in reply to: Tastatur/Keyboard Beosound Ouverture #41276
    Guy
    I bought mine from here but it was 12 years ago so I am not sure if it is still available:
    https://www.avaservices.co.uk/
    in reply to: Tastatur/Keyboard Beosound Ouverture #41274
    Guy
    I have attached a copy of the instructions that were included with the repair kit – they may be useful.  PCB5 is the display PCB that you have rotated backwards in your picture.   I assume that you disconnected the ribbon connector that you can see in your picture?
    I can’t remember how far I dismantled the keyboard, but I think I managed to get to the stage where it looked like this (picture from internet):
    s-l1600-2
    The simplest solution would be to replace this complete piece from your other Ouverture., if that is in good condition.  (EDIT: I think the 4 light units will unclip to save re-soldering if you swap the panels over)
    However, as it says in the attached instructions, the official repair kit requires your to cut off those 8 plastic buttons so that you can remove and replace the foil.  The repair kit then comes with 8 very small self-tapping screws to replace the plastic buttons and hold the keyboard together.
    in reply to: Tastatur/Keyboard Beosound Ouverture #41272
    Guy
    Sorry for replying in English.  It is most probably a problem with the keyboard’s ribbon connector which also forms the contact pad behind the buttons.  It will feel like it is working, but the contact pad needs replacing because some of the traces are broken.
    I repaired my BC2300 (which uses the same part) by buying a repair kit from B&O as follows:
    IMG_1952
    in reply to: Beocom 5 battery exchange #41283
    Guy
    Have a look at the last post here:
    https://archivedforum2.beoworld.org/forums/p/36670/336791.aspx#336791
    … or maybe join as a Silver or Gold Member for access to the Service Manual ?
    in reply to: Beoport/Beoplayer #39485
    Guy
    So today out of interest I tried running Beoport/Beoplayer on a Windows 11 Virtual Machine.  Beoport installed fine (including prompting to connect the Beoport’s USB), but I had to run the .reg file to get the radio stations to download.
    However, Win11 exhibited the same muting problem when changing radio station, as shown below:
    Win11VMWare_20221201 (1)I have never used VMs much before, but they look to be a very useful tool to check the compatibility of various older PC programs before moving to Win11 on my main PC.
    in reply to: BEOSOUND 9500 Lower keyboard issue => doesn’t work #41170
    Guy
    Thank you for your quick response Yes, I know this problem with glasses, but this is an electronic problem. I removed the glass the one that allows me to touch the plastic tips directly with my finger, but no effect! I did some measurements on the PCB 5V and 7V are OK. The integrated circuits are powered =>OK The fault being on the 3 PCBs (left, middle, right), I noticed on the electronic diagram that there was a common wire to the 3 PCBs. It is the wire marked I28 which supplies the 4 circuits IC1 IC2 IC3 IC4 on the “S” input of the CD4044 and MM5450. But I have no idea on which logic level (+5V or 0v I should find) Any idea?
    I took the liberty of google translating your response into English!
    I am unable to delve too deep into the circuitry, but BC9500 probelms are often caused by bad connectors between boards. This thread is a good example – sadly the pictures are missing but I think you will be able to work out what is being discussed):  https://archivedforum2.beoworld.org/forums/t/44523.aspx
    Guy
    in reply to: BEOSOUND 9500 Lower keyboard issue => doesn’t work #41168
    Guy
    Is the glass in the lower keyboard panel loose?  It can come unstuck from the plastic surrounds and lift slightly – this means that the sensor do not quite reach the underside of the panel.  There’s is lots about this issue on the old forum, and discussion about how best to re-stick the glass to the plastic.
    Do you have the service manual?
