Tignum
Forum Replies Created
Viewing 20 posts - 101 through 120 (of 535 total)
  • in reply to: BS Ouverture no sound to speakers #66807
    Tignum
    GOLD Member
    Maybe you have not been talking to it in French enough lately? 🙂
    Nice to see it works again!
    Regards, Johan
    in reply to: Masterlink to Powerlink #66771
    Tignum
    GOLD Member
    Hello Cass,
    Powerlink and Masterlink cables and -signals are not the same and cannot be mixed as such. So you will not find ML to PL adapters. Is it possible to run an ethernet CAT7 cable from the BS9000 to the Almando?
    Regards, Johan
    in reply to: Beocord 5000 repaired after 3 years #66568
    Tignum
    GOLD Member
    Beautiful! Nothing beats a pair of VU meters dancing to the music.
    Thanks for sharing!
    Regards, Johan
    in reply to: Beosound 1 (cone) battery level and health… #66516
    Tignum
    GOLD Member
    I feel a repair thread coming 😁. Nice find Matador, I could see one in my collection one day too!
    Best of luck, Johan
    in reply to: Welcome #66514
    Tignum
    GOLD Member
    Nice! Works now 🙂 I did not need to do anything.
    Thank you,
    Regards, Johan
    in reply to: Welcome #66509
    Tignum
    GOLD Member
    Hmm, I played around that post a bit and found that Safari opens a tiny representation of the image, but I can somehow toggle to a better view also.
    In Chrome it is not great either. Funny!
    in reply to: Welcome #66508
    Tignum
    GOLD Member
    Hello!
    Yesterday I made a reply (a silly one) with added screenshots, directly in the text (I am not a fan of the attachments). BUT they turned out tiny! What am I doing wrong?
    The images used are (modest 57KB) JPGs and seem ok in my viewer. Am I doing something wrong? I think also Millemis tried to add screenshots that also show tiny (at least in Safari on Mac).
    Thanks for any help 🙂
    Regards, Johan
    in reply to: Update of the B&O 6.6.3250519 application… #66485
    Tignum
    GOLD Member
    Shoot! I was too fast and did not read your question well, indeed my app version is 6.6.2.25041934192.
    in reply to: Update of the B&O 6.6.3250519 application… #66471
    Tignum
    GOLD Member
    Hello Vedet, nope not for me.
    My app is:
    in reply to: Beoplay S8 an BV9 (Beosystem 3) #66148
    Tignum
    GOLD Member
    I hope the BV9 sounds even better now.
    About the Pentas: no skills AND no time! I wish I had 😂. It is not me who is a Pentawhisperer.
    You could try contact member Beobuddy (Utrecht, NL). He has worked on Pentas a lot.
    Regards, J.
    in reply to: Beoplay S8 an BV9 (Beosystem 3) #66145
    Tignum
    GOLD Member
    Hi Beos, yes, you only need to add the 14 to the BeoSystem3. In the menu you will have to do role/distance/level settings. Hope this helps :-). Regards, Johan
    in reply to: Beoplay S8 an BV9 (Beosystem 3) #66056
    Tignum
    GOLD Member
    Hi Beos, you will need a PowerLink cable that has an 8 pin din connector on one end, and an RJ45 connector on the other end. Steve sells these as a standard product. See also below screenshot from the manual you can find on the B&O website. Good luck!
    (I do assume you want to use the BeoLab 14! You then will not need the S8 connection hub, let me know if my assumption is correct).
    Regards,
    Johan
    Tignum
    GOLD Member
    Hey Daniel, thanks for the kind words! And for writing the manual too. Happy to see that you enjoy using these fine products so much. The BL7s are very good value now I would say. You get them with a TV and a stand (and sometimes a Beo4) for 100 euro, where the speakers alone were 3K! I have two 7-4s in my garage 😁.
    Good luck in sorting the file quality challenge!
    Regards from the Netherlands, Johan
    in reply to: 2 Beolab 7’s in a hdmi arc Setting #65490
    Tignum
    GOLD Member
    Hi BOJ, the splitter is fully wired, so if one speaker gets it, both speakers will get it and turn on/off simultaneously. And also change volume simultaneously! But will one speaker ‘overshadow’ the other? Maybe just try :-).
    Regards, Johan
    in reply to: 2 Beolab 7’s in a hdmi arc Setting #65465
    Tignum
    GOLD Member
    Hi BOJ, if you manage to play from the LG to the 7-2 (and have a trigger signal somehow), this should not be a problem. Is this not something that you could use? https://soundsheavenly.com/bang-olufsen/26-129-powerlink-compatible-splitter-doubler-2-fully-wired-powerlink-compatible-sockets.html#/20-length-02m. Plug the male end in the 7-2 and both the source and the 7-4 in one of the female ends. How well it sounds will also depend on how loud these two speakers play relatively – you will have no separate volume control to have them ‘matched’.
    Regards, Johan
    Tignum
    GOLD Member
    Thanks for sharing the fix! I am sure someone someday will google this and benefit.
    And enjoy watching :-). Regards, Johan
    Tignum
    GOLD Member
    Hi Daniel, wow that sounds like a success!
    To your questions:
    1. there does not seem to be an ‘L-CD’ virtual button for the Beo4 button unfortunately (see the lexicon here: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/APPS_AND_ACCESSORIES/BEO4_(W._NAVIGATION_BUTTON)/beo4-navbutton_lexicon_multilanguage.pdf)
    2. will it help to add the L-A.AUX virtual button under LIST? (I am not sure if all types of Beo4 have this though).
    3. after storing (with S.STORE) the right volume settings in both the Ouverture and the BeoLink Active for the best listening experience,  you could try to put your BeoLink Active in option 6. My hope is then that both devices will react to normal Beo4 commands, as the IR receivers will accept remote control commands simultaneously. There is no need to use a ‘LINK’ prefix anymore, and it will also mean that you will listen to all speakers. Maybe worth a try?
    Hope it helps! Regards, Johan
    in reply to: Beolab Penta revidieren #65460
    Tignum
    GOLD Member
    Hi Beos, you could contact forummember Beobuddy, who is quite experienced in this. He is in Utrecht, Netherlands. Regards, Johan
    in reply to: KPN & B&O collab #65379
    Tignum
    GOLD Member
    Sorry, my impatience made me click too many times, perhaps a moderator can take away two posts? Thanks! Johan
    in reply to: B&O in Movies, TV Shows or similar… #65207
    Tignum
    GOLD Member
    What a place!
    I guess he did not have the time yet:
    This Kravitz art is what I found in an old BeoWorld post.
    Regards, Johan
