Forum Replies Created
Tignum
GOLD MemberHi libor, welcome!
I do not have these speakers but found a pdf catalogue that says they are 32cm high:
I trust they will need a bit of space around them to work correctly, that will for sure be written in the manual.
At the B&O website you can download an ‘.obj’ file of the BeoLab 3 that might give you the exact height of the base (using a CAD system).
Good luck, would be nice to see a photograph of the result in the ‘Flash your B&O’ thread!
Regards,
Johan
Tignum
GOLD MemberWith Billy Gibbons’ unmistaken guitar sound on this song
Tignum
GOLD MemberHello Stan,
No problems at all with my Core playing DLNA content from a Mac connected harddrive through Twonky.
Johan
Tignum
GOLD MemberHoly impressive! And same for me – the products that I was exposed to at first somehow remain favorite. For me those are the products of the 90s. Only a mini collection here though.
Tignum
GOLD MemberWith BLCs you will have more control options and simpler operation of the linked products I reckon.
Tignum
GOLD MemberVery WOW indeed, happy listening deaddruid!
Tignum
GOLD MemberYes please!
Tignum
GOLD MemberThey are so cool! Congratulations lass.
Tignum
GOLD MemberYou still can win some more kiiriin! 🙂 Lucky you!
Tignum
GOLD MemberLucky you!
Tignum
GOLD MemberGood prize! Congratulations
Tignum
I think it is a cool thing of B&O to make the various generations of BeoLink networks co-operate! I am not sure about the Spotify question (I don’t use that) but for the other questions:
2. yes, once passed onto ML, the NL audio sources can be listened to on all the ML devices, for the BL3500 you best use a (Beo4) remote control, though the button on the 3500 will work as a ‘join’ button or will activate the last chosen source. Still you will need a remote for volume control.
3. When the BS9000 is in the correct option, it will react to BeoRemote One (when it is used in IR mode if it is a BlueTooth BT model). You will be able to select NL sources that are passed through by the BLC
4. you can
5. there is indeed a specific mentioning in the manual, saying “The Source Center role can only be used if no BeoMaster 5 is installed on Master Link as Audio Master or Source Center (AudioMaster = No).” but as you have no ML TV in the ML network, I think there is no problem at all with using BM5/BS5
6. that means you can set the BLC as V Master
B&O is not updating software anymore afaik. I will see to send you a pdf copy of the BLC manual (I think it is not available on the manuals section of BeoWorld). Have a look into that, it might seem complicated but I trust that with a bit of help here you can join the products and enjoy them even more!
Regards, Johan
EDIT – I just saw Carolpa answering too! He has helped me to get my two BLCs working (thanks again!) and is very knowledgeable. Indeed I have bought two BLCs to overcome some command conflicts. I use one to purely pass CD onto NL (and avoid I have two devices reacting to PHONO = N.RADIO commands)
Tignum
GOLD MemberHello shanss and welcome.
Because of the tape failing with age, many of those glass plates fall and break. I had the same and was able to find a donor plate on a BM4500 that electronically died. That could be an option maybe?
I know that a member of the old forum, Leslie, made replacement plates some time ago. He is not active on the forum anymore, but it could be you can find him on facebook.
JohanLocation: Netherlands
Tignum
GOLD MemberWhen it is hot nothing beats the shadow of a tree and some cool music. Looks good Mbee.
Tignum
GOLD MemberThat is some set-up you have JensT. Looks great and must sound sublime!
J.
Tignum
GOLD MemberIt looks like it is brand new again! Very good job.
Tignum
GOLD Membersome funky music while preparing dinner
Tignum
GOLD MemberBrrrrr…
Tignum
GOLD MemberHello stotty1111, mine had the same issue (and probably many more speakers with such a metal grill like BeoLab 7-1 etc.). I decided to just take it off, clean the plastic frame and re-attach the metal plate with a good quality narrow and thin double sided tape.
Tignum
GOLD MemberHi Thorsten,
I might be able to help with settings that I have in my BLCs. I cannot help with settings in the A6 as I am not familiar with that (nice!) device. At ‘Settings’, have you got ‘ML enabled’ ticked?
If you did not get it working yet, let me know and we can exchange maybe some screen dumps of the BLC settings.
Regards, Johan
