Tignum
Forum Replies Created
Viewing 20 posts - 301 through 320 (of 535 total)
  • in reply to: BEOMASTER5 Passwort Werkseinstellungen #51318
    Tignum
    GOLD Member
    Hi Ralf, you can set your own password in the service settings.
    Select “mode” on BS5, then focus on ‘settings’ (only focus, not select). On the BS5 press RIGHT RIGHT GO. Under ‘network settings’ you can find the option to set a password.
    Do you have the BS5 user guide? The B&O website offers it for download.
    Regards, Johan
    Tignum
    GOLD Member
    Hi, my usage of the app is on an iPad and a Samsung phone, actually only for selecting music from my DLNA library. Switching the (MasterLink) system on, volume control, changing radio station etc. I do mostly with remotes and/or  the buttons of an IR eye (kitchen).IMG_0067
    Interesting to see some of you dedicate a phone/tablet, even mounted in a fixed place. Somewhat like a BS5 or moment.
    Johan
    in reply to: Controlling an LG OLED TV using BeoSystem 3 #50942
    Tignum
    GOLD Member
    dmacri, what are all the video sources you plan to connect to the BS3?
    Leosgonewild got me thinking this idea: what if you connect an AppleTV to the LG, only make a PUC connection between the BS3 and the Apple TV. Now when you wake the BS3 with the Beo4, the BS3 awakes the AppleTV through PUC, and the AppleTV awakes the LG (using CEC). How it all shuts down I am not sure yet :-).
    You can (daily) control an Apple TV with your Beo4, it could/should be hat your BS3 already has an AppleTV PUC.
    To make this an option for you, your Apple TV should be able to run the content that your cablebox supplier provides (through an app). I would reckon that an AppleTV can get to your Mac mini content somehow.
    Just a thought!
    in reply to: Controlling an LG OLED TV using BeoSystem 3 #50932
    Tignum
    GOLD Member
    Hi, no CEC with BS3 I reckon – that is newer tech I suppose, not applied by B&O back then. I was hoping these new TVs could trigger on just any HDMI input signal coming in. I checked my LG C9 oled, and must admit that in the menu there is not really something that refers to that, apart from Simplink which indeed uses CEC. It would have been nice though!
    I confirm that it is possible to load a PUC file into the BS3 and to even ‘fully’ control an LG oled (not only on/off). At least with the C9. For me it was quite a journey and includes loading PUC files into the BS3. I have an Apple TV connected to the LG directly, using the BS3 only for processing the Beo4 (joystick)/BR1 controls and the audio coming in from the LG (optical to coax). No curtains :-).
    The PUC control uses an IR out socket, a specific splitter, and two IR emitters close enough to the TV (do the latest LG’s even have IR remote control?).
    Maybe check with your dealer if he can provide this service to you? If so, I am happy to help with some screenshots, cabling etc.
    in reply to: Controlling an LG OLED TV using BeoSystem 3 #50929
    Tignum
    GOLD Member
    Just another thought – would there be an ‘HDMI autosense’ functionality of the LG that you can use? So that the LG switches on when the BS3 starts to feed an HDMI signal? Not sure if that is fast enough to still show the curtains etc, but could be an easy option to explore.
    in reply to: Controlling an LG OLED TV using BeoSystem 3 #50928
    Tignum
    GOLD Member
    Hello dmacri, it should (also) be possible using PUC control. You will need someone (like a skilled and friendly dealer) that can write an on/off PUC file specifically for the LG and write it into your BS3.
    in reply to: B&O in Movies, TV Shows or similar… #34132
    Tignum
    GOLD Member
    Hi pepps, yep (or it is me!?): when they put on the record, it spins clockwise, but in the last seconds of the video I see the record spin counter clockwise!
    Johan
    in reply to: B&O in Movies, TV Shows or similar… #34130
    Tignum
    GOLD Member
    From the B&O website (where you might expect some B&O products :-)), there is something strange going on in the beautiful home of Malene and Nikolaj. https://www.bang-olufsen.com/en/nl/story/sounds-like-home-malene-and-nikolaj. In the video, at the end, the BG4000 is spinning backward! Does it need a fix? Are they trying to find hidden messages? Probably the editor prioritizing aesthetics.
    IMG_0066
    in reply to: Beovision 7-32 MK 2 & Chromecast /w Google TV #50788
    Tignum
    GOLD Member
    in reply to: Beovision 7-32 MK 2 & Chromecast /w Google TV #50786
    Tignum
    GOLD Member
    Yes, I got that (a bit late :-)). Still my obsolete converter could maybe be ignoring the EDID handshake that Guy mentioned, and a lucky shot to solve the issue.
    in reply to: Beovision 7-32 MK 2 & Chromecast /w Google TV #50784
    Tignum
    GOLD Member
    I used it with AppleTVs previously, but I could test it with a (regular) Chromecast as well. Needs a bit of time as I need to borough back that Chromecast I gave my brother :-).
    in reply to: Beovision 7-32 MK 2 & Chromecast /w Google TV #50783
    Tignum
    GOLD Member
    Would it be worth to try to connect audio from the audio extractor via spdif/coax instead of analog to the BV to get sound ?
    I think Guy’s hint to run video through DVI, and feed some random audio from a phone is a good idea to find out if there is something with the audio signal coming from the extractor.
    Where are you based BeoIce? I have an extractor lying around that I can send to you. I do not need it anymore. I just tested it with a BV6 using a laptop, and it works with the headphone out (audio connection set to ‘none’ btw). I could not get audio from the S/PDIF coax out. Let me know if you want to give it a go.
    Regards,
    Johan
    in reply to: Need help linking NAS with BeoLab 5+9 #50184
    Tignum
    GOLD Member
    Please see one proposed BO solution for main reception with BL5, BS9000
    Hi Ed,
    Seems ok when you plan to use a BS Core (requiring even three signal cable conducts for the BeoLab 5s)
    B&O Lisbon say: “Our experts are standing by to install the perfect, custom tailored Bang & Olufsen experience in your home. We will help you with everything from initial consultancy to final implementation. Seamless convenience with one touch of your Bang & Olufsen remote is our goal. When you buy a Bang & Olufsen product in our store, our competent in-store personnel will do their utmost to provide you with the best service possible. We review the work and knowledge of our service engineers and installers regularly to ensure that the quality of the work they perform is of the highest standard. All are certified by Bang & Olufsen.” Maybe ask them for some reference projects?
    Regards, Johan
    in reply to: Need help linking NAS with BeoLab 5+9 #50177
    Tignum
    GOLD Member
    Hello Hockey44,
    You can run either PowerLink, Masterlink or Network Link over regular in wall Cat7 S/FTP solid wire ethernet cables. Check also the handbooks mentioned top right on this site.
    You can terminate such cables using RJ45 keystones in standard wall (or floor) outlets at all places where you need such a connection. And only there use an adapter cable (when needed), like an off the shelf RJ45 to 8pin DIN (for BL3 or BL9) or custommade RJ45 to ML for the BS9000. You could even make custom RJ45 to mini jack adapter cables for the BL5 volume syncing connection if at all needed. This would mean that you can install very standard cabling, but use it very specifically for your (heritage) B&O equipment. The other advantage is that normal diameter tubing can be used as you do not need to pull (large) connectors through them. Normally the wall outlets (at least here in the Netherlands) can hold 2 tubes and two keystones each, the mounting plate for the keystones looking like this: 401177718-jpeg
    Apart from the mini jack cables I use all of the above connections. Example of the kitchen BL4000:20231128_234018
    For the digital coax connection to the BL5s there are S/PDIF coax keystones too, allowing to pull coax cables without connectors. Again standard cabling.
    In my mind it would be most elegant to use a central utility room to connect all the cables. In that room, the CAT7 cables can be terminated in a (clearly labelled) patch panel, ready to be used for a specific purpose. It will keep a lot of the inevitable cable clutter out of sight. Maybe even your streamer. And to some extent you can call it future proof as you can use the CAT7 cables when you upgrade, even your LAN, and the conducts allow for pulling other types of cables if ever needed. I must mention that some people will say that this use of a central utility room will give more connections in an even longer signal path, but my eyes are better than my ears :-).
    For all places where you could want to place a speaker (no Atmos plans?) I would advise to: a.) make power available, and b.) run two conducts to the central utility room (in most use cases you will need one tube only with CAT7, for the BL 5s 2 conducts is best: one for digital audio coax, one potentially for the volume leveling connection if required).
    For all places where you could want to place a TV or other AV equipment, I would advise to run more conducts to the central utility room: for Ethernet 2x (TV & e.g. Apple TV), (for Masterlink?) and best one per two of the potentially connected  surround sound speakers (note that it is not easy to pull 2 CAT7 cables through a standard tube, Dutch ones at least), the good thing is that one PowerLink cable carries the signals for two speakers (like L&R).
    For the places where you want to place the BS9000, best is to have (next to power) two conducts with CAT7 cabling, one for potential use of MasterLink, one or two for PowerLink, and one for the digital coax out if required.
    To connect everything you will need someone that understands the B&O BeoLink logic, (maybe make) some specific cables, perhaps a few PowerLink splitters.
    I think you will get my general advice: bring power and sufficient conducts to the places where you want speakers or AV equipment, and tie it all together in a utility room.
    Hope this helps a bit! Best of luck, let us know how you get on. When you are not up to doing all this yourself, best is like MM says, to find a good B&O installer to make the plan and do the installation. Perhaps someone here in the UK can give you advice on that. I doubt it will be cheap, as nothing is with B&O, but at least it should be good value.
    Regards, Johan
    in reply to: Beolab 8000 grilles #50640
    Tignum
    GOLD Member
    Hello McRib,
    The frames are made of plastic. See also this thread (where I posted some pictures of me putting new cloth on). https://forum.beoworld.org/forums/topic/changing-cloth-on-beolab-8000-instructions/
    I would say that it will not be easy to make the flanges and the top part align perfectly as on some (stock) images, especially when redone.
    BO_2004-5_UK_Catalogue_-59-745x1024
    The original cloth was welded to the frames. Mine are not 100% flush. The flanges stick out a bit. I think it is because of the added thickness of cloth and tape. Still they are now much better than before!
    Regards,
    Johan
    Tignum
    GOLD Member
    Yep!
    Johan
    in reply to: How to remove Beo 9000 from wall mount #50443
    Tignum
    GOLD Member
    Hello George, on the sides of the wallmounts you should be able to see a (bit of) the red latch through hole C (see below). Pushing with a suitable pin will release the hatch, and you should be able to slide the speaker off.bl4000
    As a sidenote, are the 4000s not aiming too much at the floor? Part B of the wall bracket can be positioned using the ribs on the back in case you want them to be tilted more upward.
    I hope someone else can help with the BS9000!
    Best of luck, Johan
    in reply to: TV Recommendation #50310
    Tignum
    GOLD Member
    Hello pestria, all,
    I do use a BeoSystem 3 with an LG Oled. The LG is used as the ‘video hub’ (AppleTV 4K connected), and the BS3 as the ‘audio hub’ (MasterLink connected to BM6500/CD7000, BS5, Core) with BL2/7/6000/8000.
    I feed the LG’s optical audio output, via an optical/digital converter, into an S/P DIF port of the BS3. It carries Dolby Digital.
    The audio signal of the TV does get distributed over ML, it must be that the BS3 does some digital/analog converting for that.
    Maybe this helps in your decision-making. Regards, Johan
    in reply to: Beocenter 6 with Beosystem 3 and Beocenter 2: How? #50216
    Tignum
    GOLD Member
    Hello Johan, yes, the Beosystem 3 manages the HDMI inputs (Streamer, Blu-Ray…).
    What if: BC6 (option 4) DVI connected to BSys3; command Link-PC to start PC source on BC6. BC2 (option 0) and BSys3 (option 2) ML connected and Scart connected; the BSys3 then is the ML leader; BC6 is solemnly the monitor. Now the only thing: what about sound coming from the BC6 speakers, maybe a cable from Steve; PL to RCA will do the trick
    A BV 7-32 would be simpler in this set-up, with the BL7 connected to the BS3 using PowerLink. It would also avoid double reaction to volume commands (both BS3 and BC6-26 reacting).
    in reply to: Beocenter 6 with Beosystem 3 and Beocenter 2: How? #50207
    Tignum
    GOLD Member
    Hello TWG, what is the reason you want to use the BeoSystem 3? For its HDMI inputs? Regards, Johan
