Forum Replies Created
Madskp
GOLD MemberIt is the 230V power plug I suggest you rotate 180 degree, not the DIN plug pins
Madskp
GOLD MemberAlso one other easy thing to try: Try to rotate the figure 8 power plug in the Beolab 3500 180 degrees.
Madskp
GOLD MemberI have also received mine now and got it up and running.
Very nice and very good quality. and attention to detail for easy assembly.
I have testet it on both a Beosound Ouverture (Tape2), a Beomaster 4500 (Tape1 and Tape 2) and a MCL2AV (Tape), and from my little testing it seems to work flawless with the Beotooth 5500 activating all of the above when playing music from my phone, and also all of the systems being able to control the music (start, stop and skip) via the B&O remote and local control on the music systems.
Based on my little time with it till now I can only reccomand it.
Thanks to Pilatomic for making our old systems even more usefull 🙂
Madskp
GOLD MemberI was leaning in that direction after reading this post from B3OHACK3R: https://forum.beoworld.org/forums/topic/universal-link-adapter/page/4/#post-25565 But perhaps I misunderstood.
Not entirly sure, but in option 2 a TV should be able to get the local volume control signals from an audio systems volume buttons sent via datalink. Not sure if that will also work the other way as there has not been any datalink/masterlink compatible TV’s with local volume control. Hope you can get some more info from the real datalink experts
Madskp
GOLD MemberThnx Madskp.
I have ordered a 7-Pin DIN plug, to include pin-7 in the grounding.
Will come back with feedback when I have received and tested this.Hope that will solve it, and please report back. If that works I will make an updated pinout diagram for this
Madskp
GOLD MemberHere in Denmark they are available at most hardware stores / building centers.
That said the loose connection is not because of the brittle plastic. The screws are sitting in a metal piece which the cable ends are pushed into. It could be that the cable ends are not pushed long enough in, or that the terminal block is not big enough for three cables at the same time
Madskp
GOLD MemberLooking good ?
Madskp
GOLD Memberyou could try to connect to pin 7 also. When the BL3500 is used in an MCL system all three are connected via the cabeling. Also pin 7 is the only one with direct connection to ground in the speaker
Madskp
GOLD MemberDo you run 2 separate ground wires from the minijack to the Din connector? Then maybe that could be the issue.
On my testing cables I have connected pin 3, 5 and 7 (ground for MCL data) with a solder blob and just running one common ground
Madskp
GOLD MemberWould metadata also be possible on the BL3500?
It was mentioned as a feature for the Linkplayer software for Beoport back in the old forums.
Madskp
GOLD MemberFound one on Ebay and ordered it. Should be nice to have for things like this
Nice! I think most of these cheap ones still work with the Saleae application. It’s a straight forward to use tool.
Looking forward to get my hands dirty on some datalink ?
You can also try to measure voltage on pin 6 and 7 on your devices just to see if you also have the 5V on pin 6
I just checked – same results for me (exactly as in your first post).
Ok so at least consistent results
Madskp
GOLD MemberYou have an MK1 which has a different pinout. Have a look at little down in this thread that has the pinout for both the MK1 and MK2
https://www.hifi4all.dk/forum/forum_posts.asp?TID=32157&PN=1&TPN=30
Menu, 0, 4, go is the right operation. Note that when this mode is activated any remote command or button command on the BL3500 will make it go to standby
Hope this helps
Also you might take a look in my thread about these connections on the BL3500
https://forum.beoworld.org/forums/topic/bl3500-and-the-mcl-pl-connector/
Madskp
GOLD MemberThere are some pretty inexpensive logic analysers available. Search on Amazon for 8CH logic analyser. Should be more than enough for anything that might get send on the Data Out pin.
Madskp
GOLD MemberAny idea of your parents’ BS1 SW version?No, did not check that. Will do next time I am there.You can also try to measure voltage on pin 6 and 7 on your devices just to see if you also have the 5V on pin 6Location: Denmark
Madskp
GOLD Memberbut it could be an interesting test nevertheless.
Indeed
Perhaps we should try connecting the BS1’s Data + and Data – to a Masterlink device Data in/out (pins 1 and 2) and see what happens? If I am feeling brave I could try it with my BV10-32, but I wouldn’t know what to connect to the ‘ML sense’ pin 3.
Maybe not a good idea as the Masterlink data is something like 0.25V and I measured 5V in one of the pins on my parents BS1. But maybe @B3OHACK3R can elaborate on that
Madskp
GOLD MemberHi again Sorry – I might not have been clear on my earlier post. I wonder the a Beoceter 9500 could be used as the slave unit instead of the Beomaster 4500? Thanks Alan
No unfortunately not. The first software versions of the Beomaster 4500 is the only units I know that are able to get the right option settings to works as a slave unit.
Madskp
GOLD MemberHi Your examples are great – really helpful – thank you. Your 8th .pdf shows a Beomaster 4500 in a link room connected with a special aux cable – I assume this works as a slave unit only. Would this setup work with any other audio products that would normally be an audio master, eg Beocenter 9500? Thanks Alan
As far as I can tell it should work with other Audio master also. However there might be limitations since B&O never made it official. Note that it will only work with an older software revision on the Beomaster 4500.
In this other thread https://forum.beoworld.org/forums/topic/beosystem-4500-option-settings/#post-24550 I have tested it with a direct connection to a Beocenter 9300 with the crossed cable.
Madskp
GOLD MemberI ‘won’ a spares-or-repair BeoSound 1 (my second!) yesterday on eBay, and collected it to avoid the risk of damage in the post. The listing stated that the CD player wasn’t working, so I was quite looking forward to stripping it down and attempting a repair.
Nice one, But now you will need an extra room for that in your new house 😉
Strangely I can’t help being disappointed that it wasn’t more of a challenge to fix!
Yes sometimes some of these fixes are just a matter of disassembling and re assembling. I have sometimes bought an item on the assumption that it wast just a matter of turning something on or adjust something, and been lucky more than once with that strategy
Madskp
GOLD MemberNow that I have my second BeoSound 1 (see here), I wondered if it could be worth making a 7-pin DIN ‘crossover’ cable and joining the two together. Thus ‘audio out’ would become ‘audio in’ in the second, and more interestingly data-out would connect to data-in and vice versa. I don’t have time for the next few days but it could be worth a try!
I a pretty sure that the audio part will work, but more interesting if the data will.
For one thing which commands should be used? But you could try something like Link + CD or AV + CD.
Another thing is that it can only be set to option 0 or 1, so no way to select which is a link room. However if this is/was an attempt of a new type of link system, the role definition might not be the same as in the older systems
Madskp
GOLD MemberIf I get a chance this week I will connect my OneRemote radio to my BS1 aux and do some further tests using my adaptor to switch data between the two pins, plus trying the OneRemote in ‘AAL’ mode as if connected to a BL1611 (I don’t think that I tried that before).
I experimented with various permutations of settings yesterday. I tried the OneRemote radio in various different cablelink ‘modes’, both for normal datalink and AAL and tried most of the source triggers (incl video, audio and PC). Each mode was tried with data to pin 7 and then separately to pin 6. There was no response in any of these setups.
Thanks for taking the time to test this. I think we can begin to rule out datalink as the format for this data in and out connection if it is actually active
