Madskp
Forum Replies Created
Viewing 20 posts - 221 through 240 (of 1,495 total)
  • Madskp
    GOLD Member
    As for the buzzing noise in my Penta’s when the display changes – I’m now 90% sure it’s the 1611 Converter that is causing this.  When I used my Beosound 4 instead of Beocenter 9500 (and therefore did not need toe 1611), I never got the buzzing noise.  If I select a source on my Beovision 7 and change channel or volume etc, I don’t get the buzzing noise.  I only get the buzzing noise when an audio source is selected, so it’s coming through thew BC9500 and the 1611 converter.
    I have my 1611 connected by both A.Aux able and Powerlink (Mk3) cable.  I unplugged the Powerlink cable to test if that got rid of the buzzing, but it didn’t.
    It’ll take some effort because my cables are all routed and hidden, but I’ll try and switch out some of the cables between the 9500, the 1611 and the Pentas, in case one of them has a fault.  It’s also possible I suppose that my 1611 has a fault.
    Just to understand this issue correctly I asume that the Pentas are connected to the BV7?
    It could be good idea to try with different cables. For Powerlink cables note that MK2 Powerlink cables can be hard to identify. I have a cable I originally thought was a MK2, but turns out it is not as it does not have the Pin 1 connection.
    Btw for this setup you can also use a 1614 converter if you have one for testing (I think you mentioned it in another thread)?
    Madskp
    GOLD Member
    One thing I’ve noticed from this set up though – when I select a source, or change the volume, or press any button really, I get series of between 1 and 3 short quiet buzz noises coming from the speakers.  It seems to happen with any button press, whether by remote, or on the Beocenter panel itself.  Probably caused by the 1611 converter as I never got that before noise before I connected that, but I wonder if anyone knows the cause?
    Does this also happen when the Moment is not connected?
    I have noticed this behaviour in some situations where I have done some testing with unofficial setups, but that was cases where data was involved which I guess is not the case between the Moment and the Tape2 port on the BC9500?
    in reply to: Beomaster 3000-2 and Beogram 4500 #65116
    Madskp
    GOLD Member
    Thanks for the help.  My old eyes didn’t see that two were screws and I am not sure I would have drawn that conclusion even if I had seen them.  With some readers and an eyeglass screwdriver, I was able to remove the pins, plug the CD into the tape main port and play a CD.  I don’t get datalink auto controls, but at least everything works.  Which is mostly fine since I don’t have a Beogram turntable either.
    Great to hear that you worked it out 🙂
    Since I only have one tape port, though, I am starting to think I will want to upgrade to a later model so that I can get datalink, remote features, etc.  Maybe.   Plus have a dedicated CD port and be able to use the tape port for the Beocord 8004
    Since you already have the Beogram CD4500 a Beomaster 4500 could be a great candidate as it is the same design, but also because it has several inputs, datalink control, built in amplifier, but also Powerlink connections for active speakers, remote capabilities (with the right software version also 2 way remote control for Beolink 5000 and Beolink 7000 remotes), link capabilities for use in a system with a Beovision TV and/or the link rooms.
    Of course other models can also be used functionality wise.
    I got into the B&O world by accident.  I had gotten rid of my hi-fi equipment years ago because it was old and not working well and I never used it.  Many years later the kids got me a turntable for Christmas (because I got rid of the equipment but kept the media – go figure).  They didn’t realize I needed a receiver and speakers to make it work.  A buddy had the Beomaster 3000-2 that a client had given him.  He passed it on to me and after I found a set of speakers (Pentas that needed refoaming and that were a bit rough but only $50) I was off to the races.
    Sound like you already have caught the Beovirus share by many members on this site 🙂
    in reply to: Beomaster 3000-2 and Beogram 4500 #65082
    Madskp
    GOLD Member
    In some cases it is possible to unscree pin 6 and 7 in the din connector with af small flat  headed screw driver. That willsolve the datalink communication issue you experience because the datalink communication is shared between the Tape and Phono connection.
    in reply to: IR sensor does not work on Beocenter 2300 #65078
    Madskp
    GOLD Member
    If it has been used in a setup with a Beovision TV before it is very likely that it is setup to option 0 (no IR)
    So first thing is to try to set it to option1 instead.
    With a beolink 1000 it is done by pressing Sound, 1, Store
    If you have a Beo4 remote press the Standby button and LIST at the same time. Then press LIST until OPTION is shown in the display. Then press GO (centre button), and then press LIST to show A.OPT. Then press 1.
    The Beocenter will blink with the red LED to confirm the option setting change
    Hope this helps
    in reply to: Playmaker mk. 1 configuration issues #65075
    Madskp
    GOLD Member
    I’ve heard a lot of people complain about the playmaker over the years? What exactly is bad about it?
    Based on other threads Wifi stability seems to be an issue. It has only 2,4ghz wifi channels and only one antenna in the bottom of the unit so this might affect the performance.
    in reply to: Beogram CD-50 – Lower Disc Holder 9132 #65070
    Madskp
    GOLD Member
    Sorry I am not able to give you any further input as I have yet to start the repair in my own CD50, but am following with interest.
    in reply to: Playmaker mk. 1 configuration issues #65069
    Madskp
    GOLD Member
    I do no think it is possible to configure it through a app any longer.
    You might need to factory reset it to be able to acces the IP adress in a browser as it has probably been used with another IP where it was setup before.
    The factory reset procedure can be found in the manual here https://support.bang-olufsen.com/hc/en-us/articles/360041401332-Playmaker
    in reply to: Beolab 3500 with a beosound Core – possible? #65068
    Madskp
    GOLD Member
    im going to persevere I think. I have my beolink 1000 and the sounds heavenly.com instructions. My only problem is that the beolab doesn’t seem to respond to my beolink. Do I need to pair them or something?
    No need for pairing
    Since you are mentioning the sounds heavenly.com instructions I guess you mean the MENU MENU 0 4 PLAY combination? This should work regardless of how the Beolab 3500 is setup.
    Normal source commands like CD and Radio however will not always work unless it is connected with a B&O Masterlink sound system.
    Can you confirm that the Beolink 1000 is working? You can should be able to se the IR light when a key is pressed through the front camera on a phone.
    in reply to: Beovision AV9000 installation #65065
    Madskp
    GOLD Member
    Hello Sergio. I have tried contacting you a couple of times through the private message function regarding sending the package with the Audiokit for the AV 9000. So in case you haven’t got any notifications about these messages here is a heads up.
    Madskp
    GOLD Member
    I guess it comes down to the number of available sources in a Masterlink setup, and the workarounds we tried in that other thread is not enough to overcome this fact.
    One extra possible workaround that comes to mind is if the Moment can be set to something like Option 4 where it only responds to Link + commands. I do not know if that is even a thing since it is a NL product. But if that works you could use it through the Tape 2 input without double commands.
    I know other members have taken the more equipment heavy route with seperate NL/ML converters for each ML source. An example of this is this post where user Tignum has a drawing of his system with several NL/ML converters https://forum.beoworld.org/forums/topic/possible-to-use-two-ml-nl-converters-instead-of-ml-cable/#post-62861
    That way it is possible to rename sources across the converters and choose which sources are available where, still with the limitation of the max number of available ML sources in each ML subsystem.
    I have not tried this myself, but there are several threads with examples like this on the forum
    Hope this helps solving the issue
    in reply to: Beogram CD-50 – Lower Disc Holder 9132 #65048
    Madskp
    GOLD Member
    You might be able to find some hints in this guide that also has a lot of pictures and recommandations for capacitor replacements
    https://beolover.blogspot.com/2021/06/beogram-cd50-typical-restoration-steps.html?m=1
    in reply to: Masterlink to rca #64997
    Madskp
    GOLD Member
    Use Masterlink to connect the BS4 to a Beolink Active 1636 (and IR sensor – the ‘hockey puck’ type) co-located with the Denon amp.  Then use a cable like this to connect the BL Active’s Powerlink output to the Denon amp’s aux input.  If the BS4 and Denon amp are in the same room, put the BS4 in A.OPT 0 and remote control it through the BL Active’s IR sensor.  You will have a double volume control situation, able to control volume with either the B&O remote or the Denon amp (but not via the volume buttons on the BS4).
    I would also suggest that spolution as a possiblity. One way to avoid the double volume control is to use the fixed audio output in the PC connector on the Beolink active (only type 1636). This will need some custom cabling at the pinout of this conenction is not the same as the Powerlink outputs. See this thread for more info about the pinpout https://forum.beoworld.org/forums/topic/beolink-active-1636-pc-input/#post-43100
    in reply to: Beosound Ouverture CD not working #64956
    Madskp
    GOLD Member
    Hallo friend
    I have exactly the same problem. I have changed the optical laser, nothing has changed, this time test code shows the “7” wich means data transfer problems.
    CD spins but doesnt play. Next thing I’m going to do is to recap but I’m not sure if it’s gonna work.
    Hello. I did not have any error codes as far as I remember, but changing only the laser did not solve my initial problem that it could not play a CD.
    After recapping it started playing CD’s again, and based on other members experiences a combination of both recapping and laser replacing might be needed.
    Did you have any success in the mean time?
    Well my problem where I have to press CD twice has re appered. I have tried to clean all the gears and reapply new grease, but that did not change anything.
    I have found out that one of my other defect Ouvertures has the same servo board so I might try to make some mix and match to see if anything changes.
    in reply to: Beovision AV9000 installation #64770
    Madskp
    GOLD Member
    Also I recently found a servicemanual on Archive.org that among a lot of MCL2 link equipment also cover the Audiokit for AV9000.
    Here is a direct link for the servicemanual on archive.org https://ia904506.us.archive.org/11/items/manual_MCL2AV_SM_BANGOLUFSEN_EN/MCL2AV_SM_BANGOLUFSEN_EN.pdf
    It describes how the Audiokit should be setup in regards of option settings
    in reply to: Today’s B&O has lost me! #64673
    Madskp
    GOLD Member
    Not sure if you are asking for help or just being frustrated.
    But regarding the PUC list for Beovision 10 this has never been user upgradeable to my knowlegde, so you might need to find a dealer who can help with upgrading the PUC list to get the Apple TV PUC on your set
    in reply to: Beovision AV9000 installation #64630
    Madskp
    GOLD Member
    The manual library on site is not yet fully updated. But if you contact @multicare I am sure Mark will look if any other AV9000 documents are available
    in reply to: Beocenter 9500 vs 9300 #64582
    Madskp
    GOLD Member
    Also worth noting is that the BC9500 has both a phono and a tape2 connection where the BC9300 use the same connection for both of these commands
    in reply to: Beocenter 9500 vs 9300 #64579
    Madskp
    GOLD Member
    Take a look at his thread that seem to have a lot of info regarding differences between the two
    https://archivedforum.beoworld.org/forums/t/31120.aspx
    I have a BC9300 and am very satisfied with it. Might miss the 2 way though as I acquired a Beolink 7000
    Link capabilities are the same (MCL and datalink) so should make no difference compared to your BC8500
    Some of the BC9300 has the newer linear CD mechanism which might be more prone to laser failure than the older types.
    in reply to: Powerlink Comptability #64532
    Madskp
    GOLD Member
    Actually never tried to get a source from NL to ML, only the other way. If I find the time I might try how it workswith a source from my Beoplay V1 TV to some ML equipment
