Guy
Forum Replies Created
Viewing 20 posts - 1,601 through 1,620 (of 1,844 total)
  • in reply to: Beoport/Beoplayer #39433
    Guy
    Beoplayer runs fine on my 32-bit Win10 PC, although I haven’t actually connected the Beoport/PC2 for a while for a fuller check.
    I have the impression, those softwares doesn’t scan all ripped CDs. Tehy are in st same folder, but can’t be seen on the Beoplayer interface. Scanning doesn’t help.
    What file types are your ripped CDs?  Beoplayer won’t find flac files – I think it may be limited to mp3s (and possibly wav) only.
    Some of my previous Beoport/PC2 experiments/investigations are within the following threads:
    https://archivedforum2.beoworld.org/forums/p/5529/49968.aspx#49968
    https://forum.beoworld.org/forums/topic/beolink-pc2-and-beo4-remote-on-macbook-pro-early-2015/
    in reply to: Three generations of link-system #39199
    Guy
    I can’t tell from those photos. Perhaps it will have to be opened to check.
    are there any RIAA preamps that can be built in a Beogram 9500?
    I really don’t know. There are lots of similarities between the RIAA and non-RIAA beograms (they share a service manual) but I am not sure if an RIAA (either B&O or third-party) will physically fit or be compatible.
    In the shared service manual there is only one circuit diagram covering BGs 3000, 3300, 3500, 4500, 5005, 5500, 6500, 8500, 9000, 9500 and TX2. This shows the RIAA as a discrete PCB (PCB4, part number 8005269) but annotated to say ‘only in Beogram 3500/4500 and 6500’.
    Perhaps other forum members have better knowledge of the Beograms; it could be worth starting another thread titled ‘Retrofitting RIAA in Beogram 9500’.
    EDIT: You can see pictures of an internal RIAA in this document – para 7:  https://www.condoraudio.com/wp-content/uploads/Projects/BeoGram-4500-Turntable-Restoration-Repair.pdf
    in reply to: Three generations of link-system #39197
    Guy
    it might have the RIAA and looks a lot like this picture.
    If there was an RIAA it would possibly be visible just to the right of the board with the two blue connectors, but the RIAA board would be mounted vertically but perpendicular to the rear panel of the BM.
    in reply to: Three generations of link-system #39195
    Guy
    If it doesn’t have a built-in RIAA
    If you do need to look inside the Beomaster, I now know where the RIAA board would be fitted! It’s rear left of the pre-amp PCB, fitted vertically about 5 cm inboard of the antenna socket. To see if you may have to pivot the Tuner board upwards into its service position.
    If you look carefully at this eBay listing, on the bottom left of the fourth photo you can see a row of holes labelled ‘RIAA’ (just visible!) into which the board would be soldered: https://www.ebay.co.uk/itm/255129827540
    Good luck with the move to Spain!
    in reply to: THE BEOWORLD AUTUMN 2022 PRIZE DRAW !! #39417
    Guy
    Many congratulations to all winners!!
    However, it was jolly quiet tonight ?
    Either:
    –   The cost of living crisis has bitten and people can no longer afford broadband, or…
    –   End of month, hence ‘millionaire’s Friday’ (payday) and everyone’s out on the town! ????
    in reply to: THE BEOWORLD AUTUMN 2022 PRIZE DRAW !! #39414
    Guy
    Hurry up! At least two people are waiting … ?
    in reply to: Three generations of link-system #39193
    Guy
    A further thought:  You have said that you will hide the BM6500 away.  One of the reasons that (in later models) B&O moved the RIAA from the Beomaster to the Beogram was to allow Beograms to be sited further away from the Beomaster. By fitting the RIAA in the Beogram, a stronger signal was sent and a longer cable could be used.
    With this in mind, you may wish to go for the Iconic-AV RIAA pre-amp and connect it quite close to the Beogram.
    There’s so much to think about!
    in reply to: Three generations of link-system #39191
    Guy
    How can I find out if the RIAA is already fitted?
    Not at all sure! I would hope that it is written on the label. The part number of the RIAA was 8001245.
    You could test it with your BG9500. If not fitted then it would simply be very low level sound.
    Or you could open it up and look for the small RIAA board which is plugged into the pre-amp PCB – I am not sure exactly where.  Perhaps someone esle on the forum knows!
    As an aside, I just found this FB post from earlier this year making reference to a chap called Søren Claudius who makes a retro fit RIAA module – he says it’s for BM7000 but I think the same module would fit the 6500. Have a look here: https://www.facebook.com/groups/2263448640/posts/10160172517103641/?comment_id=10160172597758641
    in reply to: Three generations of link-system #39189
    Guy
    No problem.  If you’re really lucky the BM6500 may have RIAA fitted!
    in reply to: Three generations of link-system #39187
    Guy
    Can overture control Beogram and command it to play, Stop, pause, skip forward or backwards?
    Yes, it can do all of these. You can select from the front panel with AUX and it will recognise that a Beogram is connected and show PHONO on the display. You can also select with a remote using AUX or PHONO (or N.RADIO on a later Beo4). Remember that skipping forwards/backwards isn’t a track search as such – you are just moving the arm.
    This thread describes Beogram control, albeit with a BG6500:https://archivedforum.beoworld.org/forums/p/28933/227854.aspx#227854
    Unlike with the BG6500, your BG9500 will still need that RIAA add-on.
    EDIT:  Don’t be tempted by a later Beosound 3000/3200.  Although these have a 7-pin aux socket, they do not have the datalink function hence will not control a Beogram.
    in reply to: Three generations of link-system #39192
    Guy
    And there are pictures of a genuine RIAA board attached to the first couple of posts here:  https://archivedforum2.beoworld.org/forums/p/7576/67094.aspx#67094
    I doubt that it’s still for sale!
    in reply to: Ouverture door problem #39317
    Guy
    All the belts that you need are available from Beoparts here: https://www.beoparts-shop.com/product-category/beosound/beosound-ouverture/
    in reply to: Three generations of link-system #39180
    Guy
    Further to the above, Iconic-AV do indeed still exist (based near me!) and also have a number of items listed on eBay here:  https://www.ebay.co.uk/str/iconicav?_trksid=p2047675.m3561.l2563
    I can’t see the RIAA pre-amp box listed but it could be worth getting in touch.
    in reply to: Three generations of link-system #39179
    Guy
    Great diagram – very clear!
    I do think that you will have to use a Beomaster in order to then adopt one of Carolpa’s options.  However, some observations:
    • If you decide to use a BM7000, be aware that not all (not many?) are fitted with RIAA amplifiers which will be required for your BG9500.
    • You could get rid of the BL1611 by using an audiomaster such as Beosound Ouverture, which as far as I know is the only Beomaster with both ML and datalink.  However, you would still need an RIAA stage.
    • In order to solve the RIAA requirement whilst still using datalink you could look for (or build) something like this (I am not sure if Iconic AV are still in business): https://www.iconic-av.co.uk/item/1321/RIAA+Pre-Amplifier+with+Datalink+for+BeoGrams/
    • If connected as shown, then in Room 2 you would have a phase difference (sound delay) between the Beolab 11 and the Beosound Levels.  The output from the Beomaster (and direct to the BeoLab 11) is analogue, but is converted to digital in the ML/NL converter (hence delay) and further converted back to analogue in the Levels (hence more delay).  This is the reason why mixed ML NL systems often use a NL/ML delay box to ‘delay’ the analogue part of the system (ML) to match the digital part (NL).  In your setup, such a box could only be introduced to match BM7000 output (to Beolab 11) to NL sources, not the other way around!
    in reply to: Objectionable behavior by member Henrik #32968
    Guy
    I think Beojeff has a valid point and was quite right to raise it.  However, I am not convinced that this Forum is the right place to discuss such a sensitive and potentially contentious issue.
    I am going to lock this thread temporarily, have an ‘offline’ chat with the other Moderators and then get back to Beojeff with some feedback and thoughts.  Please be patient while we look into this.
    Guy
    Actually it might be SHIFT then TEXT.   I’ll check in a mo. ?
    EDIT: Yes it’s SHIFT then TEXT. (SHIFT then LINK gives LIGHT)
    Guy
    Pressing SHIFT and then LINK is the same as MENU
    in reply to: Beovison 10 #39290
    Guy
    Thanks for posting this, Guy! I’m down to one remote, the greatest remote, my precious Beo4.
    No problem Evan – very happy to help!
    I hope that your Beo4 Apple TV PUC control works well. As you can see, my TV has the older ‘Apple Remote’ PUC which is fine for most controls, apart from having to press the Beo4 EXIT button twice to get it to switch on! Oh yes, and I can’t do the useful apple remote TV button ‘press and hold’ to get the Control Centre to show up.
    in reply to: Beo4 nav version works and does not work #39152
    Guy
    On the Navi remote you can adjust the IR power, so that may be the problem.
    Access the service menu by pressing stby + LIST at the same time, and then MENU + (joystick) at the same time. Press ^ several times until the display reads IRPWR: X.
    1 is the lowest and 7 is the max IR signal strength (default is 4)
    (EDIT:  It might be LIST instead of ^ (up) – I can’t check as my Navi is in a box somewhere!)
    in reply to: Three generations of link-system #39177
    Guy
    In order to look at other options, can you tell us what other B&O equipment (and with what connections) will be in the same room as your Beogram?
    Also, have you thought about RIAA amplification?  If connecting to a datalink-capable Beomaster/Beosound (or even 1611 converter) without an RIAA stage you will have to ensure that the datalink connections bypass your chosen pre-amp.
