Forum Replies Created
GuyModeratorA further thought – you could also use a Playmaker. There’s auto-sense on the aux in socket that will trigger connected Powerlink. Playmakers can sometimes be bought quite cheaply on the second hand market.
GuyModeratorI today had a response from B&O about the BBC radio stream:
We regret to inform that when BBC changes their streaming codecs, the Beoplayer will no longer be able to support it. We apologize for the inconvenience caused.
GuyModeratorHow to place the essence in IR mode?
To use Beo4, you must set the audio system in A.OPT 1.
To set A.OPT 1 with Beo4…
Point the Beo4 remote control at the IR-receiver of the audio system.– While holding down the • (red dot) button, press LIST.
– Let go of both buttons.
– Press LIST repeatedly until OPTION? is shown in the Beo4 display and press GO.
– Press LIST repeatedly until A.OPT is shown in the Beo4 display and then press the number button 1EDIT: Info from here: https://support.bang-olufsen.com/hc/en-us/articles/360041742571-How-do-I-activate-sources-using-BeoRemote-One-or-Beo4-
GuyModeratorMaybe email b&o asking for the stream to be updated for the beoport – Im guessing windows media player can play these streams as it appears HLS is nothing new?
Thanks Rob – I’ll drop them a line and see what happens. I will report back here.
Everything is now pretty much working apart from the strange muting on change of radio station (as mentioned in the other Beoport thread) so I am happy despite these limitations.
GuyModeratorSomething like this would probably do what you require: https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/4154-powerlink-aux-expander/
GuyModeratorMaybe try Steve at Sounds Heavenly at his sponsor link below ⬇
GuyModeratorIt’s great to hear that my Beoport/Beoplayer investigations have been useful! Apologies also to the OP, but he hasn’t been seen since 2 Oct so I hope I haven’t frightened him off with all my ramblings. To be honest much of my input has been to preserve the ‘knowledge base’ as some of these devices get older, and it’s great to see that XavierItzmann is looking at novel ways to use the Beoport to solve a particular problem – namely providing an ML audiomaster. Please keep posting back with your findings and suggestions.
My Beoport is back in the cupboard for the time being. Today’s task is to dismantle (and hopefully fix) my 16-year-old Brother printer that is malfunctioning – typically I am too tight to buy a new one!!
GuyModeratorDo you means the round one with timer button (or the earlier rectangular MCL sensor, with timer button). EDIT: I just read this thread and realised that you are talking about the newer round one!
https://archivedforum2.beoworld.org/forums/p/20517/168404.aspx
When you say that you ‘connected the cables as described’, did you replace the DIN connector with an RJ45 plug, and if so what wiring scheme did you use? That earlier thread suggests that if you just stick with IR data, 5v and Ground then the IR will work, but not the buttons.
GuyModeratorI bought mine from here but it was 12 years ago so I am not sure if it is still available:
https://www.avaservices.co.uk/
GuyModeratorI have attached a copy of the instructions that were included with the repair kit – they may be useful. PCB5 is the display PCB that you have rotated backwards in your picture. I assume that you disconnected the ribbon connector that you can see in your picture?
I can’t remember how far I dismantled the keyboard, but I think I managed to get to the stage where it looked like this (picture from internet):
The simplest solution would be to replace this complete piece from your other Ouverture., if that is in good condition. (EDIT: I think the 4 light units will unclip to save re-soldering if you swap the panels over)
However, as it says in the attached instructions, the official repair kit requires your to cut off those 8 plastic buttons so that you can remove and replace the foil. The repair kit then comes with 8 very small self-tapping screws to replace the plastic buttons and hold the keyboard together.
GuyModeratorSorry for replying in English. It is most probably a problem with the keyboard’s ribbon connector which also forms the contact pad behind the buttons. It will feel like it is working, but the contact pad needs replacing because some of the traces are broken.
I repaired my BC2300 (which uses the same part) by buying a repair kit from B&O as follows:
GuyModeratorHave a look at the last post here:
https://archivedforum2.beoworld.org/forums/p/36670/336791.aspx#336791
… or maybe join as a Silver or Gold Member for access to the Service Manual ?
GuyModeratorSo today out of interest I tried running Beoport/Beoplayer on a Windows 11 Virtual Machine. Beoport installed fine (including prompting to connect the Beoport’s USB), but I had to run the .reg file to get the radio stations to download.
However, Win11 exhibited the same muting problem when changing radio station, as shown below:
I have never used VMs much before, but they look to be a very useful tool to check the compatibility of various older PC programs before moving to Win11 on my main PC.
GuyModeratorThank you for your quick response Yes, I know this problem with glasses, but this is an electronic problem. I removed the glass the one that allows me to touch the plastic tips directly with my finger, but no effect! I did some measurements on the PCB 5V and 7V are OK. The integrated circuits are powered =>OK The fault being on the 3 PCBs (left, middle, right), I noticed on the electronic diagram that there was a common wire to the 3 PCBs. It is the wire marked I28 which supplies the 4 circuits IC1 IC2 IC3 IC4 on the “S” input of the CD4044 and MM5450. But I have no idea on which logic level (+5V or 0v I should find) Any idea?
I took the liberty of google translating your response into English!
I am unable to delve too deep into the circuitry, but BC9500 probelms are often caused by bad connectors between boards. This thread is a good example – sadly the pictures are missing but I think you will be able to work out what is being discussed): https://archivedforum2.beoworld.org/forums/t/44523.aspx
1 December 2022 at 10:03 in reply to: Was taugen die Beolits? Oder was würdet ihr als PC Lautsprecher nehmen? #41163 GuyModerator GuyModeratorIs the glass in the lower keyboard panel loose? It can come unstuck from the plastic surrounds and lift slightly – this means that the sensor do not quite reach the underside of the panel. There’s is lots about this issue on the old forum, and discussion about how best to re-stick the glass to the plastic.
Do you have the service manual?
GuyModeratorI have a new behavior though, changing station mutes the playback and I have to open the volume mixer to unmute, will investigate further.
I tried BeoPlayer on an old Vista laptop and it didn’t exhibit this muting problem. I then tried a Win7 SP1 Virtual Machine (running on QNAP NAS) and found that changing radio stations again caused playback to be muted. I don’t understand enough about VMs to work out if this could be related to a separate windows update!
Edit: I also just tried a Win10 (64 bit) VM, and it exhibited the muting problem before installing any 2022 windows updates.
(As an aside, the 64-bit VM also installed the newer 4.0.0.0 Beoport driver, so it looks like that is only used by 64-bit versions)
GuyModeratorAs above, plus:
- Double check that the remote is transmitting by viewing the end with a smart phone camera.
- Double check that the speakers are connected to the powerlink socket(s) and pushed firmly home.
- When trying to set the BS9000 to A.OPT 1, make sure that the system is at stand-by.
GuyModeratorNow that I have Beoport/Beoplayer working I have been listening to BBC radio occasionally. The stream is interrupted every now and then with a message to say that the service will end mid 2023.
I think that this may be related to end of BBC support for ‘Shoutcast’ as explained here: https://www.bbc.co.uk/sounds/help/questions/recent-changes-to-bbc-sounds/shoutcast-closure
I think from the old forum that the BBC did something similar with TuneIn. It would appear that they are trying to force users onto their ‘Sounds’ app and/or BBC’s Radioplayer on PCs.
GuyModeratorMany thanks Gary – very interesting reading. And many thanks also to Matador for the re-formatting.
