AdamS
Forum Replies Created
Viewing 20 posts - 121 through 140 (of 164 total)
  • in reply to: Beogram 4000 Service Multicare Electronics #42748
    AdamS
    Not specifically Beogram 4000 related, but Multicare came and visited us last year to carry out a safety recall upgrade to our Beovision Eclipse and I got them to update our BL90s to the latest software version while they were there.
    Excellent communication and service all round, so a thumbs-up from me.
    They’ve also been very helpful in contacting B&O HQ regarding an issue I have on the B&O iPad app with the Lab 90 control, but this remains unresolved as yet.
    in reply to: Beogram 4000 and Beolab 5s #42753
    AdamS
    If you’re using the digital output of the Beosound 9000, then the CD is the only source you will hear as that’s the only one that has a digital output.
    You will not be able to output the radio or anything plugged into the AUX socket through the digital output as these are both analogue signals, and the 9000 does not have an inbuilt ADC to digitise these.
    in reply to: Beogram 4002 Type 5513 Tracking Sensor Issue #42658
    AdamS
    In addition to the point above, some ‘continuity’ meters only beep when below a certain resistance. The filament of the lamp will have a resistance and if it happens to be above this point, then your meter won’t ‘beep’, giving the impression that there is an open circuit.
    in reply to: The RX2 TT : tell me about yours plz #42117
    AdamS
    No big issues on these in my experience. The motors can make ticking noises but this can be remedied, and I’ve had a similar Beogram 2000 do some odd things when dirt got behind the front panel and into its start/stop switch but other then that, they’re pretty reliable.
    Lovely decks – go on, treat yourself!
    in reply to: What are you working on now? #33335
    AdamS
    I’m working on a big speaker drive unit re-foaming session currently.
    The two drivers at the left rear are from RL140s and I’m sure you can all work out where the SIXTEEN midrange drivers at the front came from!
    in reply to: Beolab28 vs Beolab5 #42097
    AdamS
    I was hugely impressed by the Beolab 28s when i heard them – one of the best speakers B&O have developed in years (outside of the 90s or 50s, obviously).
    However, I would say personally that they still fall a fair way short of the Beolab 5s’ performance.
    in reply to: What are the speakers, b&O lovers use? #41687
    AdamS
    My main loudspeakers are Beolab 90s and I also use Beovox MS150.2s regularly.
    Hi Adam, that is indeed superb! which amp do you use for the MS150.2s? ps/edit: how to get out of the quote mode?
    edit 2: ah it works, thanks Guy!
    I obviously have a Beomaster 8000 but I mainly use the MS150.2s with a Yamaha C-5000 preamp and M-5000 power amp
    in reply to: THE BEOWORLD CHRISTMAS 2022 PRIZE DRAW !! #41759
    AdamS
    What a wonderful selection of prizes and hearty congratulations to all!
    Very envious of  Martin’s boot bag!!
    in reply to: Beovox M75 #41627
    AdamS
    I know the chap who made the original post, and he and I have been in conversation about these. I hope he won’t mind me reproducing part of a text he sent me last night here:
    “….these things sound fantastic!”
    Looks like we may have another convert… :o)
    in reply to: What are the speakers, b&O lovers use? #41657
    AdamS
    in reply to: David Lewis would be spinning in his grave #41590
    AdamS
    I agree that the Theatre does look a bit odd but, in contrast, of the items that the OP mentions  that he likes, I’ve always found the Beovision 5 to be an odd looking thing that permanently seems to be about to topple over backwards. Even worse, I think that the Beolit 12 is one of the ugliest things ever to bear the B&O name!
    Horses for course, as they say…
    AdamS
    When I worked in loudspeaker design, we would often buy competitors’ speakers for evaluation purposes.
    When done with them, they were either donated to charity, or offered to staff for a nominal sum.
    in reply to: Poll – Beogram 4002 detail… #41569
    AdamS
    I think the first picture looks better, too, but it’s irrelevant as the cartridge is the wrong colour in both pictures!
    :o)
    in reply to: Decoding early model numbers #41153
    AdamS
    Looking at the two pictures, ‘B’ could stand for ‘Brown’!
    in reply to: Beogram 2000 motor (1983 – 1987) #40502
    AdamS
    Whoops – yes, sorry I should have said that.
    And don’t worry – we’ve all done it!
    in reply to: Beovox S-120 Fault #40879
    AdamS
    If the relay is the same as that used in the MS150.2 loudspeakers that I own, then I believe it is no longer available.
    However it”s not difficult to pop the case off the relay and clean its contacts with some fine emery paper, which should do the trick.
    It would also be worth replacing any electrolytic capacitors in the protection circuit – if they have aged and dried out then they can cause problems with the circuit’s operation.
    in reply to: Beocord 8000 breaking a cassette tape #40920
    AdamS
    I’d say it’s a poor quality cassette shell that has allowed this to happen. You’ll probably have to break the shell apart to fix it, then glue it back together.
    in reply to: Beovox MS150 re-foam surround on woofer and subwoofer #40916
    AdamS
    They are just an interference fit. Once the drivers are out, give them a tug or a gentle tap with a hammer and they’ll pop off.
    AdamS
    I have always struggled with descriptions of audio systems that “sound like the band is there”. I see quite a bit of live music of many genres, and rarely does it sound nearly as good as my home system. The mix isn’t perfect, it’s too loud, the venue has weird acoustics, the audience is noisy, etc. .
    As the English comedian Jack Dee once said – “I listen to the Pogues; I don’t WANT them in my lounge…”
    in reply to: Beogram 2000 motor (1983 – 1987) #40495
    AdamS
    I’m afraid that’s the classic noise of a common fault!
    The magnetic ring for the FG servo is just above the commutator and when the plastic “tyre” that holds it in place cracks, the loose end gets mixed up with the brushes and makes a noise. Normally just removing the offending loose piece is all you have to do, the ring seems to stay in place by itself.
    To do this you have to remove the bottom of the motor, unsolder the PCB and then take off the brush plate. It is much easier to put it back together if you take the pulley off first, then you can insert the rotor into the brush plate before sliding the complete assembly into the stator. Be sure not to lose any of the spacers and washers on the motor shaft, their positions are important. A tiny spot of oil on the two bearings is also a good idea while it is in pieces.
    If that sounds all too scary, though, another motor from a turntable of the same range will fit and do the job. Don;t throw the old motor away, though – pass it onto someone for fixing!
