Forum Replies Created
TignumGOLD MemberHi Joris,
Don’t expect too much technical expertise from me here! I was in the same situation as you are, hoping to improve the speed of the BM5 with a move to SSD. I followed Jens Renboell’s hint for purchasing the specific Western Digital SSD, and the info from this thread https://archivedforum2.beoworld.org/forums/t/49873.aspx for purchasing an external cloner, and with the WD drive it was not very complicated at all. I took the SSD to my brother who (on a PC, I use a Mac) helped to stretch the 500GB partition on the SSD (that was the result of the cloning0 to 1TB). I do remember the BM5 needed a few recovery cycles, but since then worked well. I did place the WD SSD in an interface frame to be able to secure it well in the place where the much larger HDD was – see the images.
I saw you trying to contact Jens Rendboell over the forum already, maybe you can send him a private message?
I would say that the risk is low when you keep your original HDD, you can always put that back in.
Regards,
Johan
TignumGOLD MemberHi, I am in contact with the support team too. I reported that the button to add an album is there, but that I have not been able to make it work.
Furthermore that returning to the player, a lot of ‘<‘ clicks are needed.
Keep you posted.
J.
TignumGOLD MemberHere are some images of my SSD installation: https://forum.beoworld.org/forums/topic/difference-between-source-sugnals/page/5/#post-39255
J.
TignumGOLD MemberHello Joris, I did that a few years ago. I was able to go from 500GB to 1TB. Beoworld member Rendboell shared a lot of detail of how he has been doing so, and I followed his description carefully. It involved taking out the HDD and cloning it to the SSD with a cloning device. And also using a specific type of SSD. Check this thread carefully: https://forum.beoworld.org/forums/topic/beomaster-5-motherboard/.
Hope this helps!
Regards, Johan
TignumGOLD Member TignumGOLD MemberV7.0.0 also removed:
1. Ability to play an entire folder of songs via UPnP DNLA.
2. Ability to close the Music Browser from any view. Now one must back out all the way to the root view to close the music library browser.
3. Adding a song to the Play Que no longer closes the Add Song dialog -nor is there any audio or visual confirmation that the selection was added to the Play Que.
It also was necessary to re-add my Home Media server to all IOS devices after the v7.0.0 “update”.
The app still appears to have no means of clearing the Play Que other than one song at a time.
Not sure why there is so little effort made regarding DNLA integration. Happy to hear of any solutions found for any of the above
Joe M in WV
Hi all, missing the above (simple) playlist management features is very annoying!
I will also drop a note at support, will report what they say now.
Regards, Johan
TignumGOLD MemberHi Joris, see maybe this thread: https://archivedforum2.beoworld.org/forums/t/46773.aspx
I am sure there are more threads that you can find by hard googling :-). Using a tag editor can help you out. Album cover images should not be too large.
Let us know your progress!
Regards,
Johan
27 August 2025 at 19:07 in reply to: Beovision 8-40 screen damaged and want a non B&O replacement. #69118 TignumGOLD MemberOr go for a nice luxuriously looking BV10-40, connect the BL8000s and have 3.0 surround sound!
Hoping this cheers you up a little maybe 🙂
J.
27 August 2025 at 18:52 in reply to: Beovision 8-40 screen damaged and want a non B&O replacement. #69115 TignumGOLD MemberHello paddy2042, that is a bummer! I guess finding a second hand replacement BV8 is the easiest and cheapest way. Here in the Netherlands they get sold for sometimes just 50 euro.
Regards, Johan
TignumGOLD MemberI am a fan of the Beomaster 1900, the first B&O product that I got close to at my parents in law: I now own a 4500, the last one of the series. Very nice product with lots of connectivity (and remote controlled).
Furthermore the BeoSound 5 – so different from anything else!
One more thing I really like B&O for: their careful design approach and use of aluminium and wood (I once saw photographs here of a modern BM5000 prototype with only the lower part of the sides in veneer, I might one day make a mod :-))
This one:
Regards, Johan
TignumGOLD MemberFront row is not far MM! How is the mood?
Regards, Johan
(that Shape on the right 😍)
TignumGOLD MemberHi CharlieWednesday, for best menu-control of my BeoSystem 3, I bought a BR1 BT. I think it is very elegant but a bit vulnerable for dings. It died once but I got a replacement (inner part) on warranty. The BR1 indeed is more difficult to use in the dark with its smooth buttons. I still think it is way better than a lot of plastic squeaky and flimsy plastic remotes other brands offer!
I bought a Beo4 ‘joystick’ later, and that is the one I use every day. Perhaps it is also because of the other 6 Beo4s around the house :-). I keep a couple of 1000s for spare in a drawer, and I have a Beo6 that I should get to work one day coming winter 🙂
TignumGOLD MemberThe wallpaper looks good too!
TignumGOLD MemberHi nitro2, do you mean these: https://www.dksoundparts.com/product/door-lock-catch/?
Regards, Johan
TignumGOLD MemberIncorrect post edited!
TignumGOLD MemberHello Ryan, good find!
Yes you can daisy-chain BL3s (edit: with a splitter), they have (edit) one Powerlink socket each. Direct or daisy-chained should not make a difference.
If you set up the 11-46 with the BL3s as front L/R, the TV will act as the centre speaker in a 3.1 surround sound system.
Regards, Johan
(Thx Beouser 19 – I was too fast on a quick google image search)
TignumGOLD MemberHello Anders, the Core does not support any surround sound options. Your 7-2 would play the same stereo sound as the 8000s when connected in parallel to the PowerLink of the Core.
Check also this thread perhaps: https://forum.beoworld.org/forums/topic/beolab-7-1-als-mono-center-speaker-an-ouverture-anschliessen/.
Hope this helps! Regards, Johan
TignumGOLD MemberHello James, nice purchase! Capacitor kits can be found here https://www.dksoundparts.com/product-category/beovox/beovox-2400-from-series-12/ (be mindful of what series your 2400s are). The forum has a lot of threads about fixings speakers. Depends on what you need/want to do. Hope this helps already. Regards, Johan
TignumGOLD MemberHello Patrick, the regular 10-40 documents are on the B&O website too: https://support.bang-olufsen.com/hc/en-us/articles/360041518732-Beovision-10. For service manuals you need to be silver/gold member. Good reason!
Regards, Johan
TignumGOLD MemberMaybe you have not been talking to it in French enough lately? 🙂
Nice to see it works again!
Regards, Johan
