Millemis
Forum Replies Created
Viewing 20 posts - 921 through 940 (of 1,258 total)
  • in reply to: Beovision Harmony 77 #43301
    Millemis
    I am afraid noone here can answer that question!
    Why would you get a better discount now than in 2-3 months?
    in reply to: Beolab 11 –> Connect to Non B&O source? #43305
    Millemis
    1. You should use that option, yes.
    2. Not 100% sure, haven’t tested that – but I’d say, yes it switches on with the incoming signal.
    3. (If I understand your question right) sure, that is how it is supposed to work – but you will need an adapter PL/RJ45 to PL/DIN.
    in reply to: BeoRemote One #43289
    Millemis
    I’d ask my dealer anyway.
    This is not supposed to be so, even after garantie.
    How old is it – has you had any fluid spilled on it or so?
    Also, you could buy a new insert/inlay and reuse the housing, if you don’t have success with glue.
    in reply to: Guidance on Masterlink system with 10 link rooms #43264
    Millemis
    I’d put the BV5 in Option 2 and the 3200 in Option 0 – all speakers connected to the tv…..means an integrated setup.
    (Move the Airport Express to the 3200).
    The BS4 should then be in Option 6 (= act as a link product) – you can only have one Audiomaster respectively one Videomaster in a setup.
    Even if you would want to make changes in that room, it should be worth it to try that out before.
    in reply to: BeoRemote One #43286
    Millemis
    Known issue – please contact your dealer
    Start at 5:00
    in reply to: Guidance on Masterlink system with 10 link rooms #43258
    Millemis
    The BS3000 should support Option 6.
    Read about that here on page 9:
    https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND_SYSTEMS/BEOSOUND_3000/BS3000_RB_EN.pdf
    N.B. Reading your plan, the 3000 does not seem to be masterlinked!
    Some of the linkroom devices might not support (and respond to) the A.Aux command – this depends on the SW version.
    Why would you want to get rid of the audiomaster/the BS4?
    Adding a NL/ML Converter brings the additional sources from a NL device (which you would also need).
    These can be played via the BS4.
    How are your BV’s option programmed – the BV5?
    You can not upgrade the BV5 – best buy a BV10 (be sure to have this updated with the PUC’s for the devices, you want to add, before you install it).
    You might also get the BV11, if you are serious about installing the NL/ML Converter.
    N.B.
    You are very lucky to have a plan of the setup!
    Many B&O setups in old houses are not or not well documented…….which makes it very difficult to give advice.
    P.S.
    If you want to know more about, how a NL/ML Converter works/the different setups etc, have a look here:
    https://cdn.webshopapp.com/shops/98396/files/334286248/beolink-converter-nlml-ver-14-beomac.pdf
    in reply to: BeoSound 3000 – Type Numbers #41531
    Millemis
    I would look for a later software version (or latest SW, like Carolpa’s) if I was looking for a BS3000, rather than worrying about clamper size. Obviously the earlier ‘small clamper’ versions are more likely to have earlier software, unless they have been updated. If you search BS3000 on UK eBay they often show photos of the labels so you can get a good idea of Type Numbers, SW versions and clamper size.
    I bought it then for two reasons 1) option 5 & 6 available and 2) N.Music & N.Radio accessible. ter info: now it is integrated in NL through a BLC.
    That is what I would buy…..if I needed yet another ML audiomaster ?
    in reply to: What are you listening to…..right now. #33192
    Millemis
    David Crosby – thanks for all the music – RIP.
    6E3946D5-BACC-4E39-9B10-1BCD210F8DC2
    in reply to: New product launch – beosound theatre? #38092
    Millemis
    The version mentioned on the B&O website is from last year and probably the initial one.
    Software 2.3.4.15123 – Release date 21st November 2022
    I guess the time is due for ‘some bug/stability fixes’!
    I wonder if what you/Sandyb got, is the same as what is called ‘beta’ by now.
    in reply to: Beolink Active 1636 PC Input #43104
    Millemis
    Steve used to make a cable for this!
    in reply to: New product launch – beosound theatre? #38090
    Millemis
    There is a Theatre software update today. Just installed my update, was pretty quick in case anyone hadn’t seen the release
    Nothing here….yet.
    Which version is it – any release notes?
    in reply to: Beovision Avant and Beolab speakers losing commection #43088
    Millemis
    WiSA connection can be challenging in an environment with lots of wifi networks.
    I would change to wiring with proper Powerlink cables.
    Start with the fronts/18’s and see, if that changes things.
    in reply to: internet radio for my BeoSound 9000 system #43065
    Millemis
    It says ‘out of stock’ because it is a product that has not been finished yest…..it still is being developed.
    I am looking forward to get one of them, once they are available.
    I had the opportunity to visit the Neomester a while ago for a demonstration of his products – and am pretty sure that the Neo Radio will be a great as an add-on for older B&O products.
    in reply to: internet radio for my BeoSound 9000 system #43063
    Millemis
    Yes, the Airport Express is a good starting point (if you can get one).
    Since you asked for internet radio….there are several apps providing lots of netradio station – one of these is TuneIN.
    Also most radio stations have their own netradio app.
    in reply to: internet radio for my BeoSound 9000 system #43059
    Millemis
    Hi Joost and welcome here.
    Costs – that is relative, as you know.
    You probably have the two masterlinked!
    The 9000 has an A.aux-in, where you can connect basicly anything, that produces sound…..from a iPhone, another smartphone, a bluetooth device, an Airplay device, a Chromecast dongle (there are many small devices with several options built-in), a B&O compatible device like those that OneRemote make or even a Core.
    However, you will not have the ease of controlling/changing stations like you are/were used to with the 9000 radio part.
    So it depends on, what you want to spend and on what you need – do you have a smartphone (could even be an older one) and are you willing to use that etc etc?
    in reply to: Beosystem 2300 mit Beovison 11 verbinden #42847
    Millemis
    Exactly my thoughts too.
    A BV11 definitely has the Mini-A/V port as shown……there is no other way to connect an analog source than this.
    Please tell us more about your actual BV model.
    Your picture seems to show the connection panel of the BV Eclipse
    In that case just use the method that Guy referred too.
    P.S.
    Netlink is here not involved – that would be another method (which would include two Beolink Converters), that probably is way too complicated for your purpose.
    A simple connection cable and some fiddling with the volume setting etc is all you need.
    in reply to: Beosystem 2300 mit Beovison 11 verbinden #42842
    Millemis
    The ‘Steve cable/solution’ uses the Powerlink output to get the sound out of the audiosystem.
    This might work with the Aux as well – however I am not 100% sure that the Aux port on the 2300 is output as well as input (this can be easily tested…….with the right cable).
    in reply to: Dirac Live in BS Theater? #42776
    Millemis
    Yes, but my point here is about using other speakers to improve the sound coming from a different speaker.
    I think Geoff mention something like this in the past for B&O, but Dirac launched it first?
    This principle is not new, not an invention of B&O.
    However, they were the first to implement this in a speaker concept (the BL90).
    Now this has become a part of the Theatre setup concept too – along with the other advantages that Mr10% summerized above.
    I am pretty sure that B&O had opted for Dirac, if that was better – if that could be the solution, that they need/wanted to offer.
    Obviously it isn’t!
    Millemis
    I do wonder if the LG’s home control could be added to the Theatre’s list on the Beoremote 1. Just trying to help a bit.
    Don’t get me wrong – I do appreciate that!
    I was just trying to explain my reasons for not knowing (or maybe not wanting to know) what LG Home Control is about.
    Apart from this it might be a solution for someone else reading here.
    P.S.
    If that could be added to the BROne, it might be interesting, though.
    So I am looking forward to your findings.
    Millemis
    @Beojeff
    No – I hardly notice anything LG, when I use my Theatre setup.
    My sources (which are connected to the Theatre) are my ATV, my bluray player, a Chromecast Ultra dongle (all devices that I had and used with the previous Avant 1st gen) and occasionally the internat tuner of the C2.
    And of course the usual Beolinked audio.
    I am comfortable with the apps of the ATV – it integrates well with my other ATV’s and my MacOS/iOS devices – I had/have no intention getting lost in the WebOS jungle. I never see that for my daily use.
    BUT – I will have a look at that anyway………curious as I am ?
    Untill maybe some day the Beoremote can take over from my new Hue-based solution, I and the wife are fine.
