Forum Replies Created
MillemisBRONZE MemberOh no!
A (Mozart) Core with a HDMI/eARC connection.
With only 2 channels support ?
Where did the most important speaker for tv viewing – the center – go?
Not that I expected TrueImage processing built-in – but this really is too ordinary.And the CEC support – will that bring control of the tv/the connected AppleTV….
….as Mbee asks?
Or is the future two remotes on the table?
Only a visit in a B&O store can clarify that…I guess.P.S.
I’ll stick to my trusted Essence MK2 boxes for 2 channel music/radio listening and my Theatre for tv/movie watching with great multichannel sound.MM
MillemisBRONZE MemberThe volume gain for individual sources is accessible under “… / Sources / Source Behaviour /”.
The select a source, scroll down the resulting page and there is a Volume Gain setting.
I’ve tried it, and it’s not obviously making much difference (I’ve set gain to +4 for one specific source so far).
Thanks Sandyb
Got it now!
MillemisBRONZE Member3.4.1(8) update for my Theatre today – the regular update.
Can’t say much yet – had to restart my AppleTV (unplug/replug) to have it activated as I started watching this evening.
I guess the ‘individual start up volume for sources’ thing is only relevant, if you use the app of the LG-tv (which I do not do), or?
By the way, I do not see where this should be handled in the app.MM
MillemisBRONZE Member MillemisBRONZE MemberShould not be hard to find in Denmark.
But the shipping costs would be gigantic, I guess.
Have a look on this site (equivalent to ebay in Denmark).
MillemisBRONZE MemberVery well, yes!
I have done that for 30 years now.No going back…..it has gotten better and better – especially since I got the BS Theatre.
And, by the way – music is not limited to two channels (usually called stereo)……the more channels, the better ??????
MillemisBRONZE MemberPlease send my regards to the ‘she’….getting rid of the door is an excellent idea.
The setup needs more room to ‘breathe’.
You (and ‘she’) won’t regret it!MM
MillemisBRONZE MemberMaybe 8s as front and 8000 as rear will perform better in the surround system , 80% sound come from L C R,and 8s is technically better than 8000
I’d second that…..didn’t you think of that?
I guess that would also be a better solution optically, since the setup is pretty squeezed in the front due to the placement.Only reason not to do so, could be that you’d have to have a PL cable running to the back.
That might be doable, though (?)
Otherweise you could use a Receiver 1 for WiSA connection to the BL8000 in the back.MM
11 March 2024 at 10:52 in reply to: 3 generations of the B&O app – which one would you prefer? #50559 MillemisBRONZE MemberWhile each version brought improvements, the latest iteration stands out. Its sleek interface, intuitive navigation, and seamless integration with B&O products make it my top choice. With enhanced functionality and a user-friendly design, it truly enhances my audio experience.
That could be a quote from an official B&O PR announcement!
Can you really ignore the flaws, that a lot of users have described?
However – if it is true in your case – no doubt, you are one of the very few content app users.
MillemisBRONZE MemberDid you do a reset?
MillemisBRONZE MemberIMO streaming via BT is a handy solution, when you e.g. have guests in the house and you are not interested in giving them the password for your home wifi network.
Streaming via Airplay or Chromecast / Deezer, Spotify Connect (or Tidal Connect) is the better solution.
MillemisBRONZE Memberbut now I have a question :
I’ve been through eclipse settings , and beolab settings on app , and can find no setting for using the 19 sub with the 8s for music streaming .
is it possible to do this ?
or will the sub only turn on when the tv is on , and the 8s will only stream Bluetooth when tv is off ?
You can not add a sub to the BL8’s.
Only way is to make a Speaker Group with the BL8’s and the BL19 in the BV Eclipse – which means that the BV Eclipse will turn on for processing the sound.
You can not use the BL8’s for BT, when set up with the BL19 as a Speaker Group.As far as I remember you can stream via BT to the BV Eclipse directly and this way use the BL8/19 Speaker Group for listening.
MillemisBRONZE MemberA lot of NL/ML Converter users have this question.
I haven’t heard of any explanation yet.MM
MillemisBRONZE MemberYou could use airplay and technically they will be fully in sync ?
That would be the most expensive Airplay device ever ?
MillemisBRONZE MemberI’d say 2.
Keep it simple!
MillemisBRONZE MemberMy only memory from such a job years ago was….back pain ?
MillemisBRONZE MemberI guess that would be with the sliders in the middle position…..neutral value.
MillemisBRONZE MemberHow about a “pair” of Theatres?
I know that this isn’t practical, but I’m curious if the software could handle this. (Hopefully this question isn’t too off-topic)
Glitch
This would be kind of like wanting to be the driver of two cars at the same time ?
MillemisBRONZE MemberHi Mjoelnir
The BS Core has one input port, which is combined mini-jack analog and toslink.
In your case you will only need an adapter cable between the turntable and a male minijack connector.
There is no option to control the volume on a Beogram itself (the output is fixed) – this is done in the Core.
Once you have connected it there, the Core turns on to that input (i.e. autosense), when the turntable has started.
You can use the B&O app for volume controlling like with all other sources like B&O Radio etc.The turntable will show up as an AUX-connected device.
You will not be able to remote control the turntable (pause, play etc) – that must be done on the turntable.Alternatively you can control the volume with the Beoremote One, an Essence Remote or the Halo remote.
MillemisBRONZE MemberYou can find a list of the ASE in this explanation of new and old way to use ‘Join’ here:
So yes, the Core is an ASE product.
ASE stands for ‘Audio Streaming Engine’ and was the first generation of the NL platform, which replaced the old ML platform.
There have been some minor updates of the ASE platform along the way.
