Forum Replies Created
matadorModeratorThis still remain a mystery: how could the Powerlink work with wireless 1 and not with a true Powerlink connection. Not to mention that the wireless 1 only talks about Masterlink connection not Powerlink.
Retreive the MCL Behavior with a MK2 BL3500 could be interesting.
I’ve talked with a member of Reddit who use is Beolab 3500 daily with only a DIN connection with a 5V trigger. His Beolab is a MK1 with MCL engraved under the DIN.I’ll have to ty this…
I knew this speaker gonna be a lot of fun! I thought that he was saying that the Powerlink from MCL behavior was changed by software but was still physically there. But reading carrefully shows that thats not what he was saying. 🙁
EDIT: after reading RaMaBo’s post twice this seems not possible
matadorModeratorYes I think it does apply to Mk2 speakers.
I forgot to mention that part: yes it works. But what is the purpose of that command?
I think I’ve read something like “it allows to switch between MCL mode and ML mode” but that would apply to MK1 and LCS9000 units. On MK2 that has only ML and a frustrating useless Powerlink socket, what would be the use of turning off Masterlink?Location: Paris France
matadorModeratorOk, Morning Report:
Have connected My Beosound 2300 to the 1611 converter through a 7 pin DIN wire.
Powered up everything and after that the converter. At first it did not do anything, no rectin from the remote from the L.OPT 6 Beolab 3500 and of course none from A.OPT 0 BS2300.Tried frenetically a random sequence of power down power up etc, still nothing.
Then I tried to put everything in its previous state, meaning:
– Unplug everything from power.
– Unplug DIN and Masterlink,
– Plug back Masterlink only,
– Start the 3500 with AV+TV.Then I plugged back the DIN and “Pouf” it all worked as I believe it should, that is as it did work with a masterlink connection between my Ouverture and the 3500: source selection and volume control.
WIth the belief the converter was somehow “autoconfigured” in some sort of AUDIO mode, I un plugged power from the converter, the speaker, then unplugged the DIN, Plugged back an ordinary iPod cable, then power to the converter and finally power to the speaker.
And guess what? i saved a key! Now the speaker starts, still with a video source key (TV, SAT, V.TAPE, CDV…), but without the need to press the AV key before. Just what I was looking for.
After unplugging it all from mains and plug it back the same way: it work again with direct key selection.
Thanks to everybody who tried to help.
matadorModeratorHi Keith, thank you for chiming in.
That’s what I’m trying to avoid because for daily use this is not convenient.Location: Paris France
matadorModeratorWhen I first tried it was in option 6: only AV+TV did work.
Then I tried Opt 4 or 5 cant remember and it did work the same way. I think I let it like that. I will check.Regarding ML or MCL mode does this apply even to MK2 speakers?
matadorModeratorI will try to message FrançoisVL.
About OneRemote VSNUT, ASNUT (but there is also LSNUT and PCSNUT…) cables, I may be wrong but I doubt the cable will change something unless it is related with something inside their radio device. I mean how can anything that fit inside those plugs change four times the behavior of a cable and moreover without anyone on Beoworld knowing this?
Yes, having say A.V.AUX on the screen would be better than TV. But the source being in the Beo4 virtual button list defeat the whole purpose of a “one key start”. The screen will display what it will display: it will never be AIRPLAY or MUSIC, and if TV keeps showing up, I’ll rather put a black strip inside the display cover which would be a shame because I find this dotted display gorgeous.
I believe they’re is enought knowledge in this forum to hack that speaker: remember a member (maybe Keith?) that corrupts an ouverture firmware to make it display IPOD instead of A.AUX? Or that guy that upgrade a full white Beomaster 7000 with Airplay, Bluetooth, DAB+ and I dont know whats more, all in an perfectly integrated pizza box element? Or more recently, Pilatomic bringing back the Beolink 5000 from outer world ? Old times…
matadorModeratorIf I can find my 1611
It’s in a box somewhere…. 😉
Science project for both of us!
matadorModeratorStill investigating…
OneRemote sells a Radio Multi Receiver that connects to a Masterlink installation through a 1611 converter. But depending on the cable used to connect it to the converter, it seems it appears as audio source or video source. Cables are VSNUT and ASNUT. Cables being all the same price I wonder if it’s a marketing trick or if there simply something in the socket, like a resistor between the two datalink pins, that fools the converter.
Another lead: connecting it to an Audio Unit like Guy suggested, let him autoconfig and power it off. Then connect it to the Beolab 3500 but without letting him autoconfig, which would be something like powering the converter first and the Beolab after…
Will try this tomorrow and report.
matadorModeratorToo bad… Thanks Guy.
matadorModeratorThe 1611 auto-configures to a video- or audio-master when power is applied
Then I won’t! Now I’ve a converter (and I still need another one) I won’t lose it!
But I’ll still try how it works when the autoconfig detects and Audiomaster like the 2300.
That’s an interesting lead.That makes me also wonder: I’ve read the Powerlink socket just carry the trigger signal for use in certain configurations. What if I send him a 5v when powering it on? Wouldn’t make it think it is connected in an audio config?
matadorModeratorOk, Thank you Guy for all these details. The AV thing makes sense now.
It’s really sad there isn’t any “easy” way to use the Beolab 3500 MK2 (seems that MCL models can be trigger with 5V) as a simple standalone speaker.
I am quite impressed with the sound; of course not as much bass than Beolab 4000 but I expected a more thin sound.Location: Paris France
matadorModeratorOf course this would only potentially reduce button presses for a Beo4, and only if you can set it in permanent LINK mode.
Yes that could be interesting to have the Beolab 3500 with it’s own remote in a same room that use another “general” Beoremote. Even if the Beo4 is in link mode you can still send traditional commands right?
matadorModeratorOh, and another thing, sorry: when I press the mute button it goes straight to RADIO, not the last source, which was TV. Any chance to change that?
Thanks.
matadorModeratorwhy should a ‘pure’ audio command not work?
I think that too, but after reading old post from BW2, I must have confuse things.
The guy speaking of “any source” was RaMaBo and in fact, he wrote “any Video source like DTV, V.MEM, TV, etc…”Now what I still dont understand is why I need to press AV before.
Using the A/V function/button before you hit a video button however, means that you adress an audio source.
Ok I get that, I use this command on a BV6 to start just the sound without the picture.
But why don’t I hear the sound when pressing TV only? Shouldn’t it bring picture (on no screen) AND sound?That is a sophisticated setup – but probably a bit over the top of what Matador has aimed at.
Indeed!
PS: No MCL Master. A BC2300?
matadorModeratorCongratulations on the 1611 purchase – a very useful bit of kit!
Thank you Guy,
I know you’re quite a fan of all those mysterious (or not so) black boxes, but honestly, a Beolink converter is not the piece of B&O I was expecting to be congratulated for! 🙂
It’s not the LINK key that I must depress, it’s the AV. On the Beolink 5000, where there is a LINK key, I’ve tried LINK+TV. Didnt work, must be A/V+TV.
matadorModeratorThere could be a different solution for you.
Interesting. I too would like to hear how it turns. But for now, its a little bit over… me.
I’m not an NL or ever ML guy and right now I just want to go for the cheaper: a converter, the Lab 3500 and an airport base.But Id like to know more about the ML power box: would it work as an audiometer by itself or does it need the NL/ML converter ?
matadorModeratorYou’re right, after reading the manual again it looks like they are talking about the main systems.
I powered the converter last as you already mentioned it in various topics.
So for you, now way of triggering it with any key other than AV+TV, right?
matadorModeratorHi KolfMaker,
Thats the one I would like, Yes.
I’ve still not seen one for sale around but I was told they’re quite expensive.
There is a wall stand for sale in local ads and it’s around 60€, that is more that I paid for the two 3500.That’s when finding bargain B&O stuff dont helps you ! 🙂
BTW, stil no luck in fixing the powerlink input, but if the 3500 from your friend is an MCL model, you should try the 5V trick!
Regards.
matadorModerator matadorModeratorMerci d’être revenu nous donner la solution. Profitez bien de votre nouveau Beoviseur !
