Forum Replies Created
Any special way to take it off the bracket or just tilt and lift off?
They should be screws in the top and bottom side like 30 cm from the side edges.
On the top side I think I remember they go through the bracket into the unit.
On the bottom side they are just like pegs sitting in a groove in the stand.Location: Paris FranceModeratorThanks all for the kind words.
About the sizing: long time since I did this but the right size is somewhere around this thread. It’s usual to have to scale the STL mesh from 10x to 100x.
Please read all the thread!
About plastic: I don’t know enough. I think mine were printed in PLA because I’ve heard this term somewhere but I’m not sure, so I can’t really help there.
Location: Paris FranceModeratorTo second Pilatomic’s advice and with the same advices on personal expertise, I would say I remember a thread on the previous forum about reflowing some connections around the eye or something like that. Sorry to have no time to find it for you but IIRC it should pop up with obvious key words.
Hoe this helps or may I’ve time to help you soon.
Location: Paris FranceModeratorThis is the usual B&O table stand hooked to the wall.
Tilt and lift the main unit to separate it from the wall hooks part. See Below.Location: Paris FranceModeratorAbsolutely stunning development. This is Beoworld! Thank you, tank you, thank you!
Except for the name… BeoTooth? Honestly, it scares me like an MLGWNL (whatever) box profoundly dug in my human body.
Jokes apart, you just made raise BM 5500 prices (jokes not so appart after all…).
Location: Paris France4 November 2023 at 20:00 in reply to: Help!! Just bought house with 11 MCL speakers/transceivers #50202Moderatorthat looks like it has about 11 MCL transceivers
Remove them carefully, sold them for a little or give them away to someone that will need them (I did tears ago…), and move on.
Those things are good things to anyone who like them. For anyone coming from the “non-B&O world”, what you have doesn’t worth the hassle to understand it…
… Unless there is something more in the closet!
Location: Paris FranceModeratorHad this once. Somebody replied with the “boot” sequence of a CD Mechanism. In short as far as I recall, if the laser don’t focus the motor will not spin.
The best technique to perform a deep clean is to do a search on this very same forum!
Tell us how it went.
Location: Paris FranceModeratorthen ‘boom’, it just died.
that’s the way death happens: it’s alive and then ‘boom’, it’s dead!
Try a deep clean of the lens first, in the process look at the eye reference and then report.
Location: Paris France3 November 2023 at 18:31 in reply to: Beomaster 5000 cuts out after 20seconds – what are the trimmers? #50082ModeratorTo answer the basic question of the title of the topic, trimmers are the variable resistors used to, in that case, adjust the idle current.. Find the service manual, the process is detailed and almost possible to anybody with a multimeter.
The beomaster 5000 is a complicated piece but it really worth working on it.
Godspeed.
Could you tell us where you get your batteries? Unfortunately all, I’ve tried an various Beo6 led me to no charging or very short (few seconds) battery lifetime. Even after reprogramming and with wifi turned off. So far I suspect a problem with the thermistor or worse with some weak component on the power circuit on the remote side but really I don’t know. And I also doubt all my four Beo6 would have the same defect.
Thanks.
Location: Paris FranceModeratorAlso it is VERY IMPORTANT to note, the Beo6 does not charge very well when connected to the USB on th PC. Make sure it is fully charged before to connect it to the PC.
I would say this is the major issue with Beo 5/6: powering.
If your remote battery is fine, which will be rare nowadays, no problem.
But if it is weak or old, whatever you do will be complicated and useless.
I own a lot of these remotes and “pretend” to know how to use and program them.
The problem is just that their battery management is so mysterious they dont work for more the a couple of seconds.AFAIK, no answer was given anywhere on that matter.
Sad to say but to me Beo 5/6 are dead.
Location: Paris FranceModeratorAll those question are answered and well documented in this forum or the old one (see archived forums).
Please make the effort to look at it and then come back and share you own experience.
Godspeed.
Location: Paris FranceModeratorIf you have time and are willing to investigate please take care on that “sporadic” scheme : He also told me that his Beosound read some discs and always refuse some others, whatever where they are placed. So maybe your sporadic behavior his related to some specific discs and therefore something can be learned from this. Thank you.
Location: Paris FranceModeratorUnfortunatly, My brother in law told me today that the deep cleaning of his Beosound 9000 laser was not “that” successful. Maybe I’ve overestimated the cure it could be.
Would like to have said something better.
Location: Paris FranceModerator@matador is there a specific way to mount these speakers on a wall? I’ve searched but can’t find any specific info on brackets, fixings etc.
Hi Mr Roast.
This is the very first question I had before having my pair, see the start of this thread.
I think there is an installation guide around that basically says: if you’re installing them in a lower fashion, use the top holes (wedged back against the wall, speakers tilted, woofers facing upward). If you’re installing them in a upper fashion, use the mid and lower holes (flat back against the wall, speakers parallel to the wall, woofers firing front).
The other thing is if they sounds on a wall better than by themself. I’m not golden hear, but I’ve tried on the floor, against a wall, on a sort of stand, vertical and horizontal and to me they always have sound, euuuuh, let me find the word… ah yes ok, that one: AMAZING!
The glue I’ve used is two component epoxy glue, Araldite maybe or whatever know brand but nothing specially selected. The first that I found by that time.
Hope this help. Please keep us informed!
Location: Paris FranceModeratorIf sound, operation and backlight of the panel are OK, then a BV10-32 has almost always a defective Pcb. 15 MEMC (Part 8005458) and not a defective Panel. This module is responsible for the image feed to the panel.
Ok, sounds like good. What would this mean in terms of reparability?
I’m ignorant in that matter but I suppose any TV has a module that is responsible for the image feed to the panel. So would it be possible to replace the electronic from there? Dont know if I’m clear…
Location: Paris FranceModeratorThe 3D models for the project are available to download in the first post. It’s written in bold and can easily be seen (I’ve stopped counting the numerous PM I receive asking for the STL’s).
So, just download them and have them printed by a friend or a printing service.
Just DON’T BUY THEM. Someone as open a B&O shop just near where I leave and is selling the clamps I designed and that are available here for free without any added value.
Good luck for your project.
Location: Paris FranceModeratorModeratorgiven that the maker of these products was more or less banned from this forum.
If I remember correctly, the maker of this product was openly advertising for his product to be sold without kindly asking to the forum runners. Absolutely nothing to do with this unless it would be an underground noise with B3OHACK3R selling his box under the hood in PM, which I doubt.
Location: Paris FranceModeratorI think there are commercial software solutions available that can act as a airplay sender. For example the one for Windows that can send audio to any airplay enabled speaker.
Yes, I know about software, computer based solution. They are not convenient at all.
Not practically, or event environmentally: having a computer running to airplay a 33′, really?The Arduino or similar are not easy for anybody, as you perfectly said it.
This is a thing I never understood: why nobody made a little black box to stupidly airplay broadcast any analogue signal, even under the coat. The same way I’ve never understood why nobody made the same thing for light control.
Anyway, I wish you good luck with your project and in any case it made that forum shiver again and only this is a beautiful achievement. Welcome to Beoworld B3OHACK3R.
