Forum Replies Created
Madskp
GOLD MemberBeo-museumSomething like that 🙂 my little limited space for toying with those beatifull things.
According to service manual of BC6-23 MK1 type 9212-9218: Softwareprogrammering – Programmet M2 – STB-C-tabeller NB: Anden software end ovennævnte kan opdateres ved at udskifte EEPROM’erne i hovedmikrocomputerens modul 6.
Doesn’t say much about functionality though. I wonder what the program M2 is?
Madskp
GOLD MemberSpace constraints. From 26″ to 23″ – that must be a tiny space. Sorry for the off-topic answer. Couldn’t help it.
Yes it sounds weird I know, but here the 23″ is placed. The 26″ would be crammed in between the window and the angled wall
Since these TVs are worth 0 now a days… It might be easier and cheeper just to get another Beovision 6-22 or Beocenter 6-23 …
Thats true. Not many available on local adds at the moment though, but I might keep looking.
If anyone else have insights regarding the updates I am still interested to hear about it
Madskp
GOLD Memberyes, the beogram has a 7-pin Din connector and the cable looks original and cannot be unplugged. But you are right, the problem is somewhere at the beogram. Attached are two oscilloscope traces from the overture aux/pin 7. It sends 2 times the same ‘start’ signal. Interestingly, it is the same sequence – once triggered by pressing AUX in the overture or PHONO on the Beo4…. Looks like I have I have to open the Beogram……
Have you also tried to measure at pin 6? Pin 6 and 7 should be interconnected at the Ouverture, but just to be sure.
A beogram without RIAA use pin 6 for data.
Madskp
GOLD MemberThanks, I added Phono to the list on the Beo4, but still, the beogram 5500 does not react. Pressing AUX on the overture shows AUX on the display and I can hear sound when starting the BG anually – connection is OK. But from what I read in other posts, the overture should then show PHONO as it recognizes the beogram…..correct? IMHO – very strange, as it is reported to work. Arguably an HW defect…i.e. the cable does not have the datalink pin connected – but it looks original and is not removable from the BG.
Do the DIN connector on the Beogram have 7 pins or are some of them missing? Normally the 2 pins in the button can be unscrewed, and one of these carries the data control signal
Madskp
GOLD MemberHi, I have a similar problem. BS3/BV9 connected via masterlink to an Overture. BS3 – option2; Overture option 0 or 2. The Overture is (with the original Din 7-pin cable) connected to a beogram 5500 via the AUX input (in the moment without preamp – will be added later). Sadly the beogram cannot be remote controlled. Could be the reason, that the beo4-remote does not sent phono-commands, as it just offers AUX over the list button?
You should be able to add the command “PHONO” or if it’s a newer BEO4 “N.RADIO (the same command) to the list.
Press and hold “Standby” + “List” and the display on the BEO4 should show ADD
Now press “GO” and press list until you find the command you want to add. When you are on the command you want to add simply press “GO” and it should now be available in the list.
Hope this helps
Madskp
GOLD MemberMy friend opened up his V1 today and sent me some pictures from the inside.
Although the mainboard look a lot like the one in Guy’s V1 I not spot a component that could be a battery although the marking C304 suggest a capacitor.
And from a slightly angled view
There are no visible leaks from this component, but that of course does not men that it couldn’t be defect.
Any thoughts
Madskp
GOLD MemberWhen I first opened mine it was screen downwards on an old cot mattress. I re-inserted the top part of the bracket so it could pivot (unfold) upwards. I then reversed the tv so that the back was downwards and the screen carefully pivoted up.
Thanks. Thats a very helpfull view of TV opened up. I do not spot a battery here either, but could of course (why place it so it is easy to get to) be placed on the other side of the PCB. My best guess would be that it is placed on the large mainboard as the function is probably to keep data when the TV has no power.
Other possible culprits could also be capacitors on the PSU board. Your photo shows two large ones placed in openings in the PSU board.
I can only assume that those sheets would protect from scratches caused by opening the plastic ‘hinge’ beyond its normal range of movement.
Maybe it is more nessecary if the TV is opened up 180 degress. I guess that B&O’s description of it is to be 100% sure that a service technitian do not make scratches when he is working on it.
Madskp
GOLD MemberWell I found them for 2€ or so in a trift store where they did not know what It was. So if you pay the postage cost I think that will be fine.
Could you drop me a PM with your location, and then I can find out the postage costs
Madskp
GOLD MemberA little update for usecase 8 where a Beomaster 4500 is used in a link room.
I found out in the Beolink system manual that when the Beomaster 4500 is set to option x.6 powerlink and MCL data is disabled, so only passive speakers can be used.
Madskp
GOLD MemberFor reference the lenght on my set is 7 cm
Madskp
GOLD MemberI have a set lying here.
I am not sure if there is a difference in size whether it’s for a 26″, 32″ or 40″, and I don’t know which size mine might have come from.
Could you measure the lenght of the recess for the feet on the bottom of the TV
Madskp
GOLD MemberThe oversight in the design seemed to be though,that you needed to switch the second pair of ‘speakers on/off via the transceiver manually,and could’nt ever have just the remote room ‘speaker operating.
Great with some info from one who had hands on experience with this link system.
When you say:
you needed to switch the second pair of speakers on/off via the tranceiver manually
Does that mean that you have to do that before you can use the remote control?
We used to get around this by reversing the speaker 1/2 connections,as the sockets are cabled in paralel.Speaker 1 (main)then can be switched off via the 2 switch under the cover.
That kind of break the idea of remote controlling in separate rooms. But fortnuatly that got better in the newer link systems 🙂
Madskp
GOLD Memberso I opened up the TV and searched the PCBs inside
How did you approach the opening of the TV?
The reason for asking is that the disassembly instructions mentions insertion of protection sheets, and I wonder if that is of a specific material or if it could just be a piece of paper or cardboard?
I guess the purpose is to avoid scratches on the painted surfaces
Madskp
GOLD Memberso I opened up the TV and searched the PCBs inside, and found nothing remotely like a battery!
A pitty. It could be nice to know where this battery is placed, and if it could be DIY replaced.
Worst case if it is like some batteries used on 30 year old computeres, the PCB traces could be destroyed by the battery acid.
Madskp
GOLD MemberAnyway, on testing, the CD player burst into life and worked faultlessly, for about 20 minutes …. Then the same fault re-appeared and I couldn’t get it to play any CD again! I ran the test mode and am still getting the same ERR 2 focus error.
Pitty that it was not enough. I might have to do some more playning for a longer time to see if my BS Ouverture is stable for a longer period of time. I never got the ERR 2 focus error though.
Note the note about cable and socket matching here: https://www.beoparts-shop.com/product/cdm12-4-laser-module-beocenter-2300-2500-beosound-3000-4000-ouverture-a-o/ Martin
@Martin: The text you are linking to also mentions laser units with F8 <> 2 printed on the cable. If this text should be there would it be in this place (from one of my replaced lasers where the text is different):When I next have time to disassemble I will double check that the ribbon is pushed fully home and will also have a look at the alignment of the contacts.
I might also look into this the next time I look at my Ouverture.
Madskp
GOLD MemberDoes it show up in the B&O app or in the Beotool app (assumed it is online)?
No unfortnuatly ha has not configured the V1 in the app before this happened
The leaking battery issue is probably more common than one might think. I know that in Denmark any serious dealer will replace the battery before selling a V1. All you can hope for is, that it has not already caused too much damage. I’d let a dealer or a skilled technician have a look, if it was mine.
Do you know if the leaking battery can cause issues like this?
Also, do you have any idea if the battery is placed in the power supply or the Video engine PCB?
Madskp
GOLD MemberPicture updated with correct wiring for 40+ people ! ?
Very nice. Thank you Matador ?
This thread is still going strong
Madskp
GOLD MemberYeah it might be a little hard to search for it as it seems do depent a lot about where spaces are set in the search phrase and whether you use . or , for decimals.
I will send you a private message linking to the one I bought.
Madskp
GOLD MemberI found the diagram for the BM3000 and I can see that the speaker connectors (both speaker 1 and 2) are three pin connector where the third pin for the right speaker carries 5V power and the third pin for the left speaker carries a data signal.
So probably the remote control can operate the BM3000 via the tranceivers IR eye.
The other text I linked to before might just describe the function of the button on the transceiver which the does have a very limited functionality, especially if the BM3000 is not on.
Madskp
GOLD MemberAccording to the Beotech page linked to earlier in this thread the MCL30 is simply and on/off button ( or mute if you will) for the speakers connected to it
So the operation of volume and channel switching etc. Will have to be done on the BM3000.
