hcraig244
Forum Replies Created
Viewing 20 posts - 341 through 360 (of 454 total)
  • in reply to: BeoGram 6000 – Tonearm/Tracking problem #44194
    hcraig244
    SILVER Member
    Gravity….
    Martin (the oracle of all BG4000 knowledge) would frown on replacing the tantalum capacitors with electrolytics, he did explain the reason for this in a previous post of mine when I performed a similar restoration on a BG5000, I do know there are advocates of the replacement with electrolytics (Rudi) however I went with Martins advice and put new tantalums in. You should replace the old electrolytic capacitors with new as they will have dried out and as Christian says change out the skeleton trimmers for new piher sealed trimmers, do this one at a time measuring the settings of the existing one (as best you can) and run the deck, adjusting the trimmer if required, to ensure all is well before moving on to the next one….that way you will know just where to look if things stop working (poor solder joint etc)……so far so good ;¬)
    Craig
    in reply to: BeoGram 6000 – Tonearm/Tracking problem #44190
    hcraig244
    SILVER Member
    Some pics would be good Graham….
    in reply to: Not sure what to try next with my 4002. Help please! #43375
    hcraig244
    SILVER Member
    Sounds like a problem with the servo…..the shutter adjustment could need adjusting. Silver members can access the service manuals which describe how this can be carried out, I haven’t done much work on the 4002 many in here have….im sure someone will advise you further, my advice is to go silver and download the service manuals
    Craig
    in reply to: Mr Roasts BG4000 #41886
    hcraig244
    SILVER Member
    Dave
    I will run it periodically before you come and collect….if it happens during those tests I will document it here ;¬)
    Craig
    in reply to: Beogram 4002 – Pressing STOP button #43035
    hcraig244
    SILVER Member
    Never use WD40 for anything other than blinding burglars ;¬) deoxit seems to be the solvent of choice in this forum….I used to use servisol until  I converted…….
    Craig
    in reply to: Boegram 4000 tonearm problem #42781
    hcraig244
    SILVER Member
    “The first is at the base of 1TR14 and the collector of 1TR17”
    Looking at the schematic I dont see a point showing a scope reading at the collector of 1TR17 ?
    schematic
    in reply to: Boegram 4000 tonearm problem #42780
    hcraig244
    SILVER Member
    The main forum product section contains manuals for the BG4000 and also some training notes donated by a member who was a one time repair engineer who went on a training course and reatained the course notes…..these notes identify the abbreviations and are a very usefull guide…..they are available to silver members and above, take a look…..do you have a transistor tester available?…….seems like your machine is only a short way from being sorted…..
    in reply to: Boegram 4000 tonearm problem #42778
    hcraig244
    SILVER Member
    Is the platter spinning with the tone arm over the rotating ribs in the scope readings?…..looks like it is….so the photovoltaic cell looks like its still working, good news.
    Are you sure the readings are taken at the points you identify above? and as the tone arm will drop under some conditions then the solenoid and associated linkages/damper pot etc are all working, more good news.
    I think the potentiometer  you refer is the one installed to enable playing transparent disks? does the tone arm stop at the correct place when a disk is played….or just run to the left side then run back to the rest point?
    Craig
    in reply to: Mr Roasts BG4000 #41884
    hcraig244
    SILVER Member
    All reassembled and functioning flawlessly………very odd. However I will fire her up again from time to time and see if the issue returns…..I still suspect a sticking switch or switch nipple on the control panel.
    Craig
    P1016862
    in reply to: Mr Roasts BG4000 #41883
    hcraig244
    SILVER Member
    Had a look at the leaf spring contacts and they look clean, gave them a squirt of Deoxit non the less…..once dry I will re install the control panel and try it again….I do recall having issues in the past once the panel screws are tightened down, i think if they are not evenly tightened they flex the PCB causing erroneous signals…….P1016859
    in reply to: Mr Roasts BG4000 #41882
    hcraig244
    SILVER Member
    Well……..got to this today, removed the control panel for a visual inspection and all looked fine, ran her up and she works perfectly?…….
    P1016856
    in reply to: Beogram4000 45rpm issues #42165
    hcraig244
    SILVER Member
    Whats the best way to do that?…..
    Craig
    in reply to: Beogram4000 45rpm issues #42163
    hcraig244
    SILVER Member
    Alf
    The service notes say “speed switching (33-45rpm) is performed by altering the values of R1 and R2 so that the oscillator frequency will be approx 42 and 59hz respectively” seems to me if everything works fine on 33rpm that the oscillator is working fine, could be wrong of course…….have you checked the trimmers and associated solder connections?
    Craig
    in reply to: Beogram 400x spring contact switch #41348
    hcraig244
    SILVER Member
    Send me a picture ?
    in reply to: BeoGram 4000 tone arm problem… #40709
    hcraig244
    SILVER Member
    Dillen (Martin) from this site is your man……he can supply the correct lamps for you, send him a line.
    in reply to: Bg 4000 tonearm behavior #41000
    hcraig244
    SILVER Member
    Just spotted this post justin, picked up a chest infection from soewhere ;¬(
    The tone arm dropping sharply sounds like not enough dampoing, try winding the srew in very slightly…..and I would check out the down switch contact…..if its playing up the tone arm will dot stay up when ^ is pressed
    in reply to: BeoGram 4000 tone arm problem… #40706
    hcraig244
    SILVER Member
    Found this in a 2012 – 2022 archived post “justins BG4000”
    Powered up and this is what transpired:
    unit sat powered up with no actions
    upon hitting Start the platter drive started up at 33rpm
    the panel ilumination lamps came on
    the 33rpm speed selector lamp cam on
    However the transport drive motor didn’t run, I could change the speed from 33rpm to 45rpm but no other functions responded. Time to look at the circuit diagrams……
    This is what I found….the following components where shot:
    1D11 Diode
    1TR33
    1TR31
    1TR30
    1TR32
    All of the components on the opposite side of the motor tested good.
    Untitled5
    in reply to: BeoGram 4000 tone arm problem… #40704
    hcraig244
    SILVER Member
    You may consider checking out diodes 1D8/1D14 also, you could also try exchanging the inboard drive transistors with the outboard drive transistors one at a time and testing as you go….if it is a failed transistor you will get to a point where you lose inboard and gain outboard travel.
    2917877-40
    I invested in one of these…….it has been a very usefull tool over the years, can test transistors and diodes
    in reply to: BEOGRAM 4000 “Training manual” problem #40958
    hcraig244
    SILVER Member
    Read on through section 3.21….this gives a full description of the three functions associated with the drive for the transport system, you should be able to test the voltage levels at the associated transistor points when the control panel switches are operated, the notes are a little truncated and “solder ron” may be able to fill in the missing information as they where kindly donated by him.
    Craig
    in reply to: BeoGram 4000 tone arm problem… #40700
    hcraig244
    SILVER Member
    Sorry…..i misunderstood your problem, didnt realise everything was fine when playing a record.
