hcraig244
Forum Replies Created
Viewing 14 posts - 441 through 454 (of 454 total)
  • in reply to: missing BG4000 #33043
    hcraig244
    SILVER Member
    this is the input to the new voltage regulator from the centre tap of the the transformer, much improved though still a little high, this measurement was taken under load, this was previously sitting at 24v
    P1016745 (Copy)
    in reply to: missing BG4000 #33042
    hcraig244
    SILVER Member
    moving on…..got the dual outputs from the centre tapped transformer sorted out, after a good deal of head scratching….and glasses of wine! I removed the 6vdc bridge rectifier and reinstalled the smoothing capacitor, output from the centre tap connection of the transformer to the input of the new regulator and now get a decent full wave rectification.
    cant seem to get a jpeg loaded……..maybe later
    in reply to: missing BG4000 #33041
    hcraig244
    SILVER Member
    This looks like an issue with the centre tapped transformer, I have read on the internet that a common neutral on the DC outputs of dual supplies of different voltages fed from centre tapped transformers are not allowed, this may be my problem.
    When I disconnect the 24vac supply from the transformer to the 24vdc rectifier I get the expected 12vdc from the output of the 12vdc rectifier, so I know the 12vdc rectifier is working fine..I have no problems with the 24vdc side which is working fine, as this is the required higher supply im not surprised.  I cant see anything untoward except the common neutral to both rectifiers……..any advice regarding this would be welcome, as always ;¬)
    in reply to: missing BG4000 #33040
    hcraig244
    SILVER Member
    Ok…..cleaned the drawing up to include the actual transformer wiring details and took some measurements…..these are all with the turntable running and under normal load conditions…everything works fine though the voltage regulator gets hot…put a heat sink on it which helps quite a bit.supply3
    in reply to: missing BG4000 #33039
    hcraig244
    SILVER Member
    This is how the new power supply is tied in…supply
    in reply to: missing BG4000 #33038
    hcraig244
    SILVER Member
    However the 6vdc fell off when the regulator went into high temp cut off……it was getting very hot!….few measurements revealed that I am getting 24v at the input to the voltage regulator instead of the 12v i was expecting, the output from the transformer is 12v to the 6v rectifier…..
    in reply to: missing BG4000 #33037
    hcraig244
    SILVER Member
    This is the regulator 6vdc output under operating loadP1016727 (Copy)
    in reply to: missing BG4000 #33036
    hcraig244
    SILVER Member
    This is how it looks, I have the regulator connected on leads to allow measurments to be taken easilyP1016726 (Copy)
    in reply to: missing BG4000 #33035
    hcraig244
    SILVER Member
    timestamp is a bit of a challenge here……my replies are all jumbled up, however wired up the transformer and powered up….slowly with the variac and watched the output of the 6vdc regulator it came up nicely…..and as i wound up the variac the output started to fall back to 0vdc….like a capacitor charging up?
    in reply to: missing BG4000 #33033
    hcraig244
    SILVER Member
    This is the data sheet for the voltage regulator…Untitled
    in reply to: missing BG4000 #33032
    hcraig244
    SILVER Member
    just getting my head around the order of things here….I will try harder
    in reply to: missing BG4000 #33031
    hcraig244
    SILVER Member
    This is the data sheet for the transformer….yellow and black connected together to provide the 24v supply across orange and red to the 24vdc rectifier, connecting red and black (12v) to the 6vdc rectifier…..sounds straightforward enough 818By9byH9L._SL1500_
    in reply to: missing BG4000 #33030
    hcraig244
    SILVER Member
    230vac power cable and improvised fusebox connected up…..P1016723 (Copy)
    in reply to: missing BG4000 #33029
    hcraig244
    SILVER Member
    The replacement toroidal is a good fit dimensionally…..will fit above the fusebox nicely…P1016719 (Copy)
