hcraig244
Forum Replies Created
Viewing 20 posts - 361 through 380 (of 454 total)
  • in reply to: BeoGram 4000 tone arm problem… #40698
    hcraig244
    SILVER Member
    in reply to: BeoGram 4000 tone arm problem… #40697
    hcraig244
    SILVER Member
    Ok…..check this set of switch contacts also…I know i keep banging on about switches but if nothing else you will eliminate them from the search. If these contacts dont operate your motor wont operate as a servo, the contacts should open when the solenoid energises.
    Untitled
    in reply to: BeoGram 4000 tone arm problem… #40694
    hcraig244
    SILVER Member
    A very high percentage of problems experienced with these decks result from switches, either on the control panel or the transport slider. A switch out of position be it open or closed will play havoc with the boolean logic control gates, I have chased my tail for weeks trying to locate a problem that turned out to be nothing more than an intermittent sticking contact on a transport slider switch……an issue that had been identified as a possible cause by Dillen at the outset….however as it was intermittent when I tested the switch it worked fine…turned out that the silicone grease i had blobbed onto the plastic nipples (which I thought would help keep them free) was causing them to bind due to the viscosity……thorough cleaning and has worked fine since…….I’m rambling I know ;¬)
    Craig
    in reply to: BeoGram 4000 tone arm problem… #40692
    hcraig244
    SILVER Member
    Ok…..start by checking the switch contacts on the carriage transfere mechanism, sounds like this unit has been stood idle for a while, they are a little awkward to get at but sounds to me they will need cleaning even if they are not responsible for your problem. Dont adjust any of the position screws.
    Craig
    in reply to: BeoGram 4000 tone arm problem… #40690
    hcraig244
    SILVER Member
    Dont force it…..let it soak, WD40 isn’t popular on this site (I think the popular term for it is snake oil ) De Oxit is the cleaner of choice, however i would go for something like 3 in one penertrating oil…..leave it overnight.
    Craig
    in reply to: BeoGram 4000 tone arm problem… #40686
    hcraig244
    SILVER Member
    Read/view this rom beolover
    https://www.youtube.com/watch?v=IxIxHb8sZdg
    in reply to: What are you working on now? #33329
    hcraig244
    SILVER Member
    in reply to: Beomaster 4400 – Sudden drop in sound? #40305
    hcraig244
    SILVER Member
    Are both your tuning lamps working fine?
    in reply to: Beogram 4000 Restoration Issue #40268
    hcraig244
    SILVER Member
    Where did you get that lovely Beo Hub board from? I did have to replace a reed switch and a blown transistor on mine (TR6 I think?).
    I have also had to replace the reed switch on a couple of these units, usually after i have invertedly grounded the 6vdc circuit…..its happened a couple of times when the carriage slide has moved too far in when i have been testing with the slider switches removed (schoolboy error)…..
    in reply to: Beomaster 4400 – Sudden drop in sound? #40299
    hcraig244
    SILVER Member
    You haven’t said if your measuring a voltage drop when the volume falls down….have you monitored this yet…i so is it falling off?
    If you upgrade your membership to silver you will have access to the service manuals for mostly every B&O amplifier available…….
    in reply to: Beogram 4000 Restoration Issue #40265
    hcraig244
    SILVER Member
    Firstly….is the existing fuse blown? no need to replace it if its good….I would buy a couple because often when you take these out the end cap becomes detatched and the fusewire pulls out of the glass holder, the fuse is 0.4A and sits in approx 14vac circuit.
    The high temperature that has discoloured the yellow sleeve is heat generated from the voltage regulator circuit 2D4 (ZF6.8) 2R22 and 2TR6…..the fuse isn’t responsible for generating heat, this discolouration is very common as the regulator circuit does run hot…before you reconnect the fuse check you have the approx 14vac measured between the blue wire connected to the fuse and the blue wire connected to the PCB just above the rectifier…..this will confirm you transformer is giving the required voltage.
    Craig
    in reply to: Beomaster 4400 – Sudden drop in sound? #40296
    hcraig244
    SILVER Member
    Made a mess of that…..the table shows the voltages that should be present at TP14 for mute on or off.
    in reply to: Beomaster 4400 – Sudden drop in sound? #40294
    hcraig244
    SILVER Member
    in reply to: Beogram 4000 Restoration Issue #40263
    hcraig244
    SILVER Member
    What do you measure on the input and output of the bridge rectifier 2D5 ? and have you checked the fuse hiding inside the yellow sleeve from the transformer to 2D5 ?
    Craig
    in reply to: Beomaster 4400 – Sudden drop in sound? #40290
    hcraig244
    SILVER Member
    If your only input is currently the FM tuner your problem may be the muting circuit?
    Craig
    in reply to: Beomaster 4400 – Sudden drop in sound? #40288
    hcraig244
    SILVER Member
    One way of determining if the 15v rail is falling off is to monitor the power ON lamp as this is fed from that supply.
    Craig
    in reply to: Beomaster 4400 – Sudden drop in sound? #40286
    hcraig244
    SILVER Member
    And incidentally one way of testing the thermistor is to blow a hairdryer over it and the fault relay should  activate and shut the amp down.
    Craig
    in reply to: Beomaster 4400 – Sudden drop in sound? #40285
    hcraig244
    SILVER Member
    Bert
    You dont say if the falling volume is occurring on all inputs i.e. FM tuner/phono/tape ?
    Craig
    hcraig244
    SILVER Member
    Fascinating stuff……I have always thought it best to shy away from this subject due to the test equipment required and also the expertise required to perform it, but would love to learn more and explore the use of the TinySA piece of kit, I do have a BM4400 that has a less than perfect reception.
    Craig
    in reply to: Beogram4000 behaving erratically #39650
    hcraig244
    SILVER Member
    Couple of things here….firstly take out OTR4 and check it, if this is good you need to look at the power limiting part of the circuit….the set of contacts (those leaf spring contacts again) that need to be closed, thus shorting 7R1 to ground,  when the solenoid is initially activated allowing max current to pull in the solenoid coil before opening up when the armature moves to drop the tone arm…..its possible you dont have a good connection at these contacts..
    Craig
