Guy
Forum Replies Created
Viewing 20 posts - 561 through 580 (of 1,820 total)
  • in reply to: Connect Essence MKII with old IR eye? #57038
    Guy
    That does not sound right. I just double checked on a MCL2AV, and the voltage between ground and IR data is normally 4.95V and drops to some place between 4 and 5 V depending on the key pressed. I have also seen this behaviour on other setups.
    So is the 5V at the IR data produced by the powered IR eye or does it come from the source (Essence or MCL2AV)?
    One thing you could do is to meassure on the bare ends of the rest of the wires in the network cable if any of them have a voltage arround 5V. That could indicate if the Essence has a different wirering.
    Just checked whilst just +5V and ground connected to IR eye.  All connections at 0V with the exception of Pin 2 which reads -5V (which makes sense at that would be data Rx in a fully wired sensor).
    I wonder if the Essence needs the correct ‘JOIN’ type IR sensor with data Tx and Rx also connected in order to carry out some sort of handshake and work properly?
    in reply to: Connect Essence MKII with old IR eye? #57033
    Guy
    Back home now!  Answers in bold below:
    Have you used a cut over network cable to make the connection? I have seen some network cables that do not follow the standard color coding for example what comes first the white/orange or the orange.  Yes a cut network cable, but used a magnifying glass to look through the clear connector to check colour coding against pins.  Pin1 White /Orange, Pin 4 Blue, Pin 7 White/Brown
    If possible can you check the connection between the RJ45 connector and the screw terminal in the IR eye for continuity?  Checked and fine for all three connected pins
    When connected can you measure 5V between Ground and +5V in the screw terminal of the IR eye?  Yes
    Also when connected can you meassure a voltage around 5V between ground and IR data screw terminal of the IR eye?  No, it’s about 0.4V
    If yes can you see the voltage changing when pressing a key on the BEO4?  Pressing transmit shows momentary change from 0.4V to about 1V
    in reply to: Connect Essence MKII with old IR eye? #57032
    Guy
    Sorry madskp I posted without seeing your post – got to go out now but will have a look later!
    in reply to: Connect Essence MKII with old IR eye? #57031
    Guy
    I am still unable to work this out!  I have checked the Essence RJ45 and there is 5V between pins 1 and 4, so the  IR eye is receiving power.
    There is a menu setting in the Essence’s settings remote control menu that has a tick box against ‘Match mode 4 and mode 0’ – anyone know what this is for?  I have tried on and off, to no avail.
    I have tried a second IR eye in case the first is faulty – no change.  I will try a BeoSystem 3 IR eye next, or maybe an MCL eye.  With just IR, +5V and gnd connected, either should work.
    I can’t help feeling that there is a setting in the Essence that I am missing, but I am struggling to find any guides regarding IR control.
    in reply to: CD listening – in search of advises #57017
    Guy
    +1 for FLAC.  I used Exact Audio Copy to do mine.
    One good thing about FLAC is that it’s then easy to use that high quality FLAC copy to convert to other (‘lesser’) files types if needed in the future.  eg My last car wouldn’t play FLAC from SD cards, so I converted a playlist of FLAC files to 320kbps mp3.
    in reply to: Connect Essence MKII with old IR eye? #57015
    Guy
    Old thread I know, but I too now have an Essence Mk2 and am trying to connect a older hockey-puck IR eye with the timer button, exactly as jelop attempted unsuccessfully above.
    I have connected exactly as in the diagram above, with just +5v, Gnd and IR data connected, but I can’t get any response from the Essence, even when trying to put it in A.OPT 1.  There are no indications from the IR eye, not even a red light when the IR is transmitting.
    Does anyone know of any tricks to get the Essence Mk2 to respond to Beo4, IR control?
    in reply to: MCL2A and MCL2AV troubles #57003
    Guy
    Ah, pity we didn’t try the other BM7000 first!
    Does the ‘faulty’ BM7000 accept the Option setting without problem?  I can’t remember if there is an indication on the front panel when you set A.OPT 1 or whatever.  Maybe compare it with your ‘working’ BM7000.
    There could well be an internal fault in the BM7000 – other than checking for broken data connections to the extra pins of the Speaker 2 sockets I don’t know what else to suggest.
    in reply to: Beolab 3500 and Beocenter 8500 – possible? #57002
    Guy
    Great news about the Beoport/PC2.  You may wish to have a read of some of my experiences in this thread: https://forum.beoworld.org/forums/topic/beoport-beoplayer/page/3/#post-39476
    Mine worked a lot better once I realised that I needed to install he Beoport software, rather than the Beoplayer software!
    There are still a few problems with internet radio – mine won’t play BBC radio stations for more than 30 seconds which is annoying, but I think it’s a BBC format problem.  BFBS, Classic FM and Danish stations (eg DR P1, 2 and 3) are fine.  There is still some strange windows behaviour where it mutes the BeoNetRadio sometimes when you change stations – you have to open the PC’s volume mixer to unmute. It happens on both Win10 and 11 (but not Vista!) and I haven’t found a fix.
    Will you be using it with a PC or Mac, and if the latter what operating system does you computer have?
    in reply to: CD listening – in search of advises #56992
    Guy
    Thanks Guy. Yes, I am thinking of another Ouverture or a BS3000. Would they automatically be older than a BC2 or a BS4?
    Ouverture was produced 1994-2003
    BeoSound 3000 was produced 2000-2006  (There was also the BS3200, similar but with a built in hard drive – I have read many reports about problems with the hard drive, hence probably best avoided)
    BeoCenter 2 was produced 2004-2012
    BeoSound 4 was produced 2006-2010
    With all the above, I would look for condition rather than age.
    in reply to: Beosound 1 faulty CD player #56991
    Guy
    So I have ordered a new laser for the faulty BeoSound 1 – it’s on the way from China and I’ll let you know how I get on.
    I wanted to start using the new SW2.5 BeoSound 1 with the clock, so I removed the CD mechanism from one of my working SW1.3 (no clock) BeoSound 1s and fitted it in the new one – despite being a slightly different CD module (VAU1255/01 rather than VAU1255/21LF, it works well.  When swapping the laser modules I was careful to keep the display module (PCB3) with the original main board to avoid any SW incompatibility or Pin Code conflicts.
    Here’s the working mechanism that I moved:
    IMG_8632
    The ‘donor’ BeoSound 1 now needs a good internal clean – a job for tomorrow:
    IMG_8630
    in reply to: MCL2A and MCL2AV troubles #56989
    Guy
    I have a BL1000 and a beo4 and doesn’t really remember how to set option
    Option setting is easiest with the BL1000 (the remote without the screen).
    With the entire system shut down (at standby):
    In the main room with the BM7000, just press SOUND 1 STORE
    In each MCL link room, press LINK 2 STORE and then LINK 6 STORE – each time you press store a red light should blink in the transceiver.
    in reply to: Beolink Passive upgrades #56984
    Guy
    My only accessible Passive is Type No 1657 with SW1.4.  It does have the switch and the serial number is 162812XX.
    Also, I think that the SW versions may have similarity with BL Active – i.e needs SW1.5 for A.AUX and SW1.6 for MLGW compatibility (There’s probably SW version details in one of the archived forums)
    in reply to: MCL2A and MCL2AV troubles #56982
    Guy
    What kind of option settings for the BM7000 ?
    A.OPT 1
    If you are unsure how to set Option settings let me know what type of remote you are using and I will let you know how to set.
    Did you check that MCL cable was connected to BM7000’s Speaker 2 socket? Not speaker 1.
    in reply to: MCL2A and MCL2AV troubles #56980
    Guy
    Another thought – check first that the MCL cable is connected to the Speaker 2 sockets on the BM7000.  (Your symptoms suggest that they may be in speaker 1 sockets!)
    in reply to: MCL2A and MCL2AV troubles #56978
    Guy
    You say that you have tried a different MCL cable – does that mean that you have also checked the connections inside each MCL2A and MCL2AV box – I would check that all the connections are secure.
    Second thing that I would check is the option settings, for the Beomaster and each link room – re-do the whole system with the correct options, and make sure you do so with the system powered down.
    EDIT:  If no video products also connected, options should be set as follows:
    Main Room (BM7000) – A.OPT 1
    Link rooms:  L.OPT 2.6 (set L.OPT 2 then set L.OPT 6 afterwards) – check that each transceiver blinks to acknowledge setting.    An additional requirement may be to hold time the Timer button on each transceiver and send an AV command with the remote – I think that the transceiver should again blink to acknowledge.
    in reply to: CD listening – in search of advises #56921
    Guy
    What about. BeoSound 3000?  It would keep the same aesthetics alongside the Beolab 2500s.
    I would also try harder to fix the Ouverture. Is the repairer experienced with vintage B&O?
    in reply to: BeoLink Converter 1611 Innovative Configurations #56919
    Guy
    Try this link for the manual – you should be able to view as a Silver Member:  https://beoworld.org/?a=download&key=6bbded9353242b53701819d219f48699
    EDIT:  Sorry, that was the Reference Guide – this should be the manual:  https://beoworld.org/?a=download&key=11cd18ccf1894f3bde4ebd45642b98e8
    in reply to: BeoLink Converter 1611 Innovative Configurations #56835
    Guy
    I have another question, in the BC930 Is there a function that turns the unit on to radio when there is a news broadcast? Sometimes I find the device turned on on the radio and no one has turned it on. does it have a life of its own?
    There is no function that will deliberately turn the radio on for a news broadcast, so there must be another cause.  Either:
    • The remote radio button is transmitting on its own – unlikely but not unheard of, but you can test by putting the remote in another room and see if re-occurs.
    • There is a timer set.  On the BC9300 press Programming and then Call.  If the top right display just shows ‘?’ then there is no timer set.  If it shows a source (Radio) and start time then a timer is set – this will have a ‘-‘ before the start time if it is set to repeat as yours may well be.  When a timer start time is showing, simply press Clear to cancel/clear.
    in reply to: sales & discounts announcements #56684
    Guy
    The B&O store at Bicester Village still have new Beoplay M3s in stock and are selling them for £225. Both colours are available.
    (This was my first trip to Bicester village for about 20 years, and I only nipped in for a quick coffee whilst dropping my wife off.  Shocked to pay £3.80 for a cappuccino!)
    in reply to: Beolab 3500 and Beocenter 8500 – possible? #56615
    Guy
    The Beoport/PC2 will be good fun to experiment with whatever.  To avoid the conflict mentioned by madskp, you could always have two independent ML networks – one with Beoport/PC2 and TV, the other with BC8500 and BL3500/BL2000.  Or have a ML Distribution box in the middle and swap it around as you see fit!
