Forum Replies Created
Die_Bogener
BRONZE MemberDead?
No!
But close to it… not far away. Maybe 10 minutes? And bang!
The white lines are the runback of the cathode beam… and they should never be visible in standard mode…
Do not switch it on. It needs urgent repair of caps… power supply and deflection are not OK.
It still can be repaired, it just needs an old retired tv tecci and some parts…
Die_Bogener
BRONZE MemberThe beograms are very old hardware, they become lower and lower… quite normal, it can be adjusted easily.
And a new belt pulls on the left side additionally, lowering the left side of the platter.
There are 3 springs on the subframe. You only need a screwdriver and a good eye for adjustments.
Just remove the white platter cover and you have access to the springs. It is not necessary to open the deck like on the picture… just to show the springs…
Martin No.2
Die_Bogener
BRONZE MemberConfirmed, there is a lithium cell inside the cpu board. It is a CR2450 cell with pins.
Replacement is necessary, otherwise the cell can leak and destroy the board. The brown stuff on the battery is acid… it also can burn (seen in several VX5000…)
After the replacement the cpu needs a reset and a “clear CMOS” service. Without this procedure the offset of the FM counter may be wrong, the frequencies of the stations will be wrong and there will be stations you cannot reprogram or delete, this can also be a timer function… switching on or off, recording things…
For this it is necessary to start in service mode.
You have the service manual?
Die_Bogener
BRONZE MemberDie_Bogener
BRONZE MemberIs the MMC ok?
Sometimes the stylus is broken and the needle is bent upwards or even complete missing… then the MMC case slides over the record…
Die_Bogener
BRONZE MemberMachen wir’s mal einfach.
Das meiste Volumen muss vorne mittig und links/rechts vom Fernseher rauskommen.
Bei 10m Abstand… ok, das ist schon eine echte Ansage, macht auch der Beolab 2 Sinn.
Bei den hinteren Surround wird in aller Regel sehr viel weniger Volumen verlangt, egal ob 5.1 oder sogar 7.1… bei 7.1 wird es noch weniger pro Lautsprecher.
Bei einem Sofa an der Wand wird der 5.1 Effekt sehr stark beschränkt. Der Lautsprecher ist zu nah und plärrt einem dann auf kürzeste Distanz vorlaut ins Ohr. Das kommt nicht gut.
Das Sofa sollte schon etwas Abstand zur Wand haben, Wände machen unschöne Echos wenn zu nah, es wird dann schrill … mich irritiert das gewaltig, der Raumeffekt leidet erheblich.
Theoretisch sollte das Sofa ja in der Raum Mitte stehen… aber wer hat schon ein 20m Kino zur Verfügung? Mach also etwas Abstand zur Wand, 1-2m sollten es dann schon sein. Die Laufzeiten kannst du ja problemlos programmieren, richtig?
Die BL2500 sind in einem so großen Raum überfordert. Ich würde sie auch einzeln aufgebaut optisch nicht wertschätzen, als einfaches “L” sind sie ….hmmmm, fehlplatziert. Sie sind mit einer Overture kombiniert sehr dekorativ, einzeln aber nicht so der Hit.
Mit 4000ern auf einem Regal oder auf einer dekorativen Säule/Standfuß werden sie genug bringen, es wird auch optisch nicht zu wuchtig aussehen. Das kommt jetzt dann etwas auf die restliche Einrichtung an. Mit den 4000ern könnte man auch das “Höhenproblem” der hinteren Lautsprecher lösen. Stehen sie auf dem Boden, merkt man irgendwie dass da was nicht stimmt… hört sich an wie aus einem Grab. Nicht gut. Es sollte mehr auf Ohrhöhe sein, wie gesagt: 4000er auf einem Regal oder Ständer. Der Mittelpunkt des Austritts sollte in etwa bei 1,2m über Grund sein. Die BL8000 machen das schon richtig, die BL6000 sind dann etwas zu tief…
Wenn’s ein richtiger Kino Raum ist, wo wenig rumsteht: ok, 4x BL8000 sieht dann schon was gleich, das kommt gut rüber, optisch wie auch akustisch. Allerdings sind die hinteren Kanäle vom Volumen für die BL8000 eher sowas wie Unterforderung. Wenn man etwas dran sparen wollte, Platzbedarf usw… die BL6000 reichen da auch. Wobei die BL6000 vom Volumen/Bass eher der BL4000 etwas unterlegen ist, die BL6000 habe ich volumenmäßig immer eher als “dünn” in Erinnerung. Ich empfinde die 6000er als nützliche Helfer bei einem guten Fernseher mit ordentlichem Center im normalen Wohnzimmer…
Ich würde von der Einfachheit her auch 5.1 vorziehen, mit 7.1 wird es nicht so viel besser. Das 7.1 kann man machen, wenn der Raum wirklich sehr groß wird, also weit jenseits der 10m… aber dann muß man wieder über die BL8000 nachdenken, ob man dann nicht gemachte Pentas wählt.
Das wären meine 5 Cent dazu…
Die_Bogener
BRONZE MemberClean the manual switch, it’s oxide and old grease … L … R … Auto
Use the switch, many, many times…
Die_Bogener
BRONZE MemberI think the BG4000 had a muting system.
The muting system closes the loop to ground, so there is no noise.
When the needle plays, the loop is opened and there should be sound.
So it looks like a wrong DC level on the sound channels…
Die_Bogener
BRONZE Memberdeleted
Die_Bogener
BRONZE MemberYes, it could be a broken ground connector or track on a board, broken solders.
When all sources have this problem, it is inside the (pre)-amp.
If possible and if the preamp can be disconnected: apply a different source carefully to the amp. If gone, it’s the preamp. If not, the amp.
If it is more a 50Hz humming sound: defect power source, dead caps.
Die_Bogener
BRONZE MemberDie erste Version von der BL4000 hatte keine ICE-Technik drin. Spielt aber auch keine wesentliche Rolle.
Was man im Video sieht, ist die pillepalle easy Version. Da pappt nix, da reisst nix, die Platinen sind nicht grün verätzt … des is a bisserle leicht bappig und sonst nix.
Wenn’s mal so ausschaut, dann ist das ein ganz anderer Level…
Oder Gummiriemen von Laufwerken so rauskommen… das ist dann nur noch eklig…
Und trotzdem funktioniert alles wieder wie neu. Das ist alles wieder sauber zu bekommen… es ist nur Arbeit. Viele Stunden vor dem Fernseher so nebenbei… dann geht das.
Die_Bogener
BRONZE MemberÄhnliches gilt auch für die BL2500 bezüglich Schaumstoff… schwarzer Baaaz, alles bapt, alles dreckig…
Allerdings ist die gute Nachricht: man muss nichts mehr von dem Schaum reinstecken, sie klingt ohne sogar besser.
Die schlechte Nachricht ist nur: es kann ein Haufen Arbeit sein, diesen Dreck rauszubekommen, denn er ist ätzend und zerstört Leiterbahnen.
Die_Bogener
BRONZE MemberThe LM324 is just an opamp … no power at all…
The L272 is controlling the motor, that is the power source.
Check the axles of the 2 spindles. Clean it… the grease is very sticky after this time. Like glue… check it by hand, you can turn it or not.
Disassemble the C-Clip on the top of the axles, then you can pull the wheels. Be carefull not to break it or loose it…
Die_Bogener
BRONZE MemberRemove the black cover… 4 bolts on the backside.
Remove the small plastic c-ring on top of the wheel.
Clean with alcohol isopropanol. The grease can be very sticky…
Die_Bogener
BRONZE MemberDesolder/remove TR17.
Use a seperate power supply and send 14V with limited current instead TR17… and check wether there is a short in the system or why it needs so much power.
Dont blow some transistors, use a regulated power supply instead. Try less than 14V and limitied current…
Die_Bogener
BRONZE MemberJust guess…. B&O compatible, not standard.
Just connect a Beocord 6500 or 7000 … just B&O. It will work on play and record.
Die_Bogener
BRONZE MemberThe radio is hardware coded depending to the area/country… usually the cpu should read the correct type of tuner board and configure the software.
Either there is a software bug… or the type cannot be read or the lithium cell is dead. This happens also when some caps in the power supply have problems.
Die_Bogener
BRONZE MemberHow much time can you spend on a cap around 10-20 Cents? 10 seconds? ESR & Leakage & Co?
That will not work. And then you have a checked cap that is still a risk or is really defect without notice.
Replace every cap on the board, 100%.
Everything else is a waste of time and money.
If you cannot do it in the requested qualitity… find an old retired radio/tv man with time. They can do it.
Die_Bogener
BRONZE MemberThe amplifier and all electronics of BL3000/4500 are quite the same. The 4500 is just bigger… and more loudspeakers.
Sometimes bigger is better… it depends just on the size of your house.
But…: there are only a few survivors of the 3000/4500. They are prone to fail with bad solder connections, broken wires, defect boards and bad caps. Also the displays are hard to find in working condition, they are identical to early Pentas. Without a specialist checking these old hardware it’s very frustrating… 90% are simply dead ore unusable.
But if its done and they are working: NICE! 🙂
