AdamS
Forum Replies Created
Viewing 20 posts - 101 through 120 (of 164 total)
  • AdamS
    Ah, now that’s interesting – thanks; I hadn’t spotted that!
    I shall investigate…
    in reply to: CX50 foam or rubber #47115
    AdamS
    The originals were foam, therefore I’d replace them with foam.
    Changing to rubber will alter the parameters of the drivers and make them sound different. Whether this is an improvement or not is purely subjective.
    in reply to: Max Input Voltage … setting recommendations #46581
    AdamS
    The D/A output is the digital output, which you’re not using, so ignore that.
    It looks like the Marantz has both RCA (unbalanced) and XLR (balanced outputs, so the easiest way to connect it is simply to use a decent RCA-RCA lead and set the input sensitivity to 2V
    in reply to: UK based repair needed #46653
    AdamS
    Tim Jarman is also in that area (Farnborough, Hampshire) and I can pass on his details if you’d like.
    However, I hate to break it to you but the brief flash of music at stylus drop/raise on a Beogram is a classic sign of failed suspension on the cartridge. Your MMC will need a re-build.
    in reply to: New Wireless Speaker Beosound A5? #45490
    AdamS
    Saw and heard one in the flesh in Harrods today.
    Not impressed by looks or sound, to be honest.
    in reply to: New Wireless Speaker Beosound A5? #45408
    AdamS
    I’m sure it’ll be very good, but the styling really doesn’t do anything for me.
    Still, lets hope I’m in the minority and that B&O sell millions of the things!
    in reply to: Beogram 4000 #45861
    AdamS
    Someone I know on another forum recently sold his mint Beogram 4000 with MMC20CL for £2,250. On this basis, £580 for a project doesn’t seem completely ridiculous.
    Don’t get me wrong, I’d love another one but I can’t afford it. 25 years ago I bought the one I owned for £4 and was thrilled when I sold it for £80 but, sadly, times change!
    As another thought – shouldn’t we be pleased that that people are finally working out that these are superb turntables and not just “style over substance”?
    in reply to: B n O gift given to me. #45842
    AdamS
    Superb system and well worth restoring.
    Whereabouts in the world are you located?
    in reply to: M100-2 crossover capacitor values #45652
    AdamS
    Normally I’d have said all you need to do if you have any concerns over the caps in your M100-2s, or their performance, would be to head to Beoparts and buy the correct capacitor kit for them.
    However, Martin doesn’t appear to do one for them that I can see.
    in reply to: Beocenter 2200 – no phono and smoking #45662
    AdamS
    A loud pop and smoke but with everything still working in any audio equipment usually means a failed mains suppression capacitor.
    Can’t remember if the BC2200 uses one – it’s been a while since I’ve been inside one!
    in reply to: Building a cheap BL50 set with 3 pairs of Penta’s? #45024
    AdamS
    It’s a crazy idea, which usually appeals, but it also seems like a waste of three pairs of Pentas…
    in reply to: Refoaming #44919
    AdamS
    I use standard PVA. Takes longer to set but offers fine adjustment capability.
    in reply to: Replace or refoam woffers on Beovox 80.2.? #44875
    AdamS
    @AdamS So you like your Redlines very much, I think? If you compare them with your other B&o Speakers? What do you think? Would you rate them above them?
    I’d rate them as better than Beolab 6000 and Beolab 8000, on a par with Beovox Pentas, not as good as Beovox MS150.2s and a long way behind Beolab 90s!
    Mind you, every speaker is behind Beolab 90s to a greater or lesser extent…
    in reply to: Replace or refoam woffers on Beovox 80.2.? #44870
    AdamS
    That’s fine. The most important thing is that the speakers are made to work again – I think we can agree on that!
    However, it’s interesting you mention RL140s. I acquired a pair last year and one was fitted with the original two woofers that needed re-foaming, and one was fitted with the two B&O-approved replacement drivers, which had rubber surrounds.
    After repairing the original woofers, the sound was distinctly unbalanced, with the speaker with the ‘new’ woofers producing noticeably more bass. To restore a balanced performance I ended up putting one new and one old woofer in each speaker.
    As an aside, I almost wish I hadn’t bothered. I’ve always been secure in my opinion that I didn’t really like RLs. Trouble is, no-one told these RL140s – I haven’t listened to anything else since I finished them over a month ago. I had originally planned to sell them once repaired, but that’s not happening now!
    in reply to: Replace or refoam woffers on Beovox 80.2.? #44868
    AdamS
    Im not totally agreed. You had beovox rl60 who had foam surrounds, after that rl60.2 with rubber surrounds. For durability i would take rubber surrounds. But that is my opinion. I would not re-do the process each 15y because it’s time consuming
    Yes, but they were different drivers with different performance and, as a result, the RL60 and RL60.2 crossovers are different to account for the drivers’ different sonic characteristics
    I personally feel that it is always best to replace foam surrounds with foam and rubber with rubber.
    in reply to: Replace or refoam woffers on Beovox 80.2.? #44865
    AdamS
    Agreed – re-foam not repair! But do not opt for rubber surrounds if your originals were foam – stick with the original foam material otherwise you will alter the characteristics of the driver.
    The correct foam surrounds from Audiofriends are here:
    https://www.repairyourspeakers.com/en/foam-rubber-surrounds/bang-olufsen/bang-olufsen-beovox-s80-2-1x-foam-surround-for-repair/a-2048-10000016
    I’ve not used Audiofriends personally – I usually use Good Hi-Fi and they also do the correct S80.2 surround here:
    https://speakerrepairshop.nl/en/foam-surrounds/bang-olufsen/foam-surround-for-bang-olufsen-beovox-s80-2-woofer/a-977-10000013
    in reply to: The Prize Draw – Thoughts Please… #43889
    AdamS
    Firstly, I would like to add my voice to all those above in thanking Lee and Keith for the running of Beoworld, and to Steve for sponsoring it. The site is an invaluable resource for B&O nuts like me but I have also been well aware that traffic has been reducing over the years, which is very sad news. I’m active on many hi-fi forums and, predictably get asked lots of questions about B&O which I’m more than happy to answer, but I always try and point people in the direction of the site.
    As to Gold membership, it’s something I consider essential for access to the magnificent repository of service and user manuals. The prize draw is a lovely bonus and I have been lucky enough to win on several occasions, but if this were to drop to once a year or even vanish altogether, then it wouldn’t affect my membership decision – I’d still stay Gold. Like chartz – I’m not going anywhere!
    I would also personally be more then happy with an increase in the cost of membership but I do appreciate that this may well have the effect of putting people off – you can’t win in this one!
    In my own small way, I’d like to help by making a donation to the coffers and Lee – if you do decide to continue with the draw, please drop me a line as I have some items in the Smith Beocollection that i would be more than happy to donate for the next one.
    in reply to: Beovox MS150.2 crossover schematic #43335
    AdamS
    Thankyou Jens; that’s very kind!
    in reply to: Beolab Penta1 crossover smoke #43455
    AdamS
    I would also not use the speakers again until you have given the amplifier unit a thorough once-over. Two blown tweeters and smoking resistors in a passive crossover suggest to me that the amp could be putting out DC.
    If it is, then it’ll just keep blowing your tweeters and crossover components every time you replace them.
    in reply to: Beovox MS150.2 crossover schematic #43333
    AdamS
    Just an update – I found pictures of the MS150.2 crossover online and it appears that mine have been half re-capped! However, one of the original capacitors has broken and one of the replaced caps appears to be the wrong value.
    Consequently, I have done what any sensible person would do in this situation and ordered a full capacitor kit from Beoparts!
    Would still be keen to know if there’s a service manual out there, though.
