Tignum
Forum Replies Created
Viewing 20 posts - 121 through 140 (of 532 total)
  • Tignum
    GOLD Member
    Nice, keep us posted! 😀
    Theoretically you could directly ‘split’ the audio signal from the Ouverture, the only thing is then, that you cannot control how loud the 7-1 plays vs. the 2500s of the Ouverture.
    With the IR controlled Active between the Ouverture and the 7-1 you can control the volumes independently, or even play the speakers separately. The only thing you need to be aware of is that the IR receivers of both the Active AND the Ouverture might react to remote control commands simultaneously (when they are in the same room). This could be managed by putting the Active in Option 4 and by using the LINK ‘pre-fix’ when controlling it. To help crack the nut!
    Regards,
    Johan
    Tignum
    GOLD Member
    Hi Daniel, good news! You do not need any ‘mixer’. The PowerLink cable contains both L&R signals, and the 7-1 is a stereo speaker. One PowerLink cable from the Active to the 7-1 is enough. You do need an IR eye connected to the Active to (independently) control the volume for the 7-1.
    Note that you will not achieve any ‘surround sound center’ effect: the 7-1 will exactly play the same stereo sound as the Ouverture.
    Hope this helps! Regards, Johan
    in reply to: Your latest addi(c)tion? #63932
    Tignum
    GOLD Member
    Hi, I bought a truly as new BeoCom 6000 mk2 handset, to use daily. It must have been rarely used: the texture of the back cover feels really new, and the white texts on the buttons is really white still. I put a new battery in it and it works fine.
    Happy with it!
    IMG_2074IMG_2073
    Tignum
    GOLD Member
    Casper should be on BeoWorld – boy the man can talk enthusiastically about B&O! 🙂 Wonderful products.
    in reply to: What is next for B&O recreated classics #63602
    Tignum
    GOLD Member
    A BeoCenter 9300 with touchscreens under the doors: for music selection on one side, and beolink control on the other side!
    in reply to: Beosound 5 option question #63476
    Tignum
    GOLD Member
    Hello Rob, yes I do have the attic’s BS5/BM5 connected to a BLC, it is in A.Slave mode (and it plays some AudioSlave too sometimes!).
    While I am listening to BeoSound 5 MOTS music (Chili Peppers) in the kitchen (BeoLab 4000s connected to another BLC – A.Master – with IR eye) I can’t say you can really instruct the playback of MOTS music with a command. You select music on the BS5 (or with a colored Be04 button) and when that queue has ended, the BS5 will continue to play songs that are more of the same. The Red Hot Chili Peppers are apparently more of the same as The Offspring’s L.A.P.D :-). Having said that, when I hold the ‘GO’ button on my older Beo4 for some time, still in the kitchen, the music stops for a moment, to let me know this song is now the ‘seed’. I tested it by playing an album halfway through, and after a long ‘GO’ press the BS5 indeed moves to MOTS and plays similar songs. So you could say that is a way to ‘activate’ MOTS.
    I am not sure this all just works because of the BLC behaving as a MasterLink unit. I do not have a true NL speaker to test this with. Maybe Carolpa will chime in?
    Regards, Johan
    in reply to: Repurpose control unit AV9000 #63382
    Tignum
    GOLD Member
    Sounds a bit hopeless imho… 🙁
    If your aim is to have a modern screen with an iconic triangular shape speaker, you could of course get a BeoLab 10 (and find a, for you, suitable way to play the TV’s sound).
    Regards, Johan
    in reply to: Repurpose control unit AV9000 #63323
    Tignum
    GOLD Member
    This thread is less promising: https://archivedforum2.beoworld.org/forums/t/16929.aspx and speaks about a bespoke cabling between monitor & control center. Here is a danish manual that indeed indicates there is a bespoke control center cabling: https://radioogtveksperten.dk/images/manualer/tv/AV_9000.pdf.
    J.
    in reply to: Repurpose control unit AV9000 #63318
    Tignum
    GOLD Member
    Hi Roderic, I did think about this some time ago, but abandoned the idea, and bought a BeoSystem 3. When taking a look here: https://beocentral.com/av9000controlcenter, it seems encouraging! What connections are there on the ‘control center’? If there is a (digital) audio in, there might be a chance you could mount a modern tv on it, and feed the audio signal to the control center. Controlling that modern (non B&O) tv with a Beo4 will be another story, maybe a Neomesteren product could provide for that. And setting the surround levels etc. (if at all possible) must be done through a menu, so the ‘control center’ has to have a video output that the modern TV can handle.
    Maybe you can share some photographs of the connections between the monitor and the control center?
    Regards, Johan
    Tignum
    GOLD Member
    Hi Eric, Mk3 will do. Check Steve’s site: https://soundsheavenly.com/powerlink-8-pin-din-connection/20-272-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/9-length-18m
    “This cable is perfect for use with all Beolab speakers that do not have displays (although not suitable for Beolab 5 – this needs mk 2).”
    Here there is some more insight: http://www.soundsheavenly.com/faq/guide-various-types-powerlink-cable-bang-olufsen-use/
    Regards, Johan
    Tignum
    GOLD Member
    Hello MM,
    See below the configuration. Downstairs I use the Core for Radio, but in the ‘Study’ (=attic) there is also the BS5. When playing radio on the BV10 I like the visual of the BS5’s screen to show the station :-). The Beo4 commands are from the ‘ML source’ listing.
    The BV10 and it’s ‘own’ Beo4 are in LINK mode as I also use the BC6 (that is close to my desk) to play from the BS/BM5.
    Have a nice Sunday!
    Regards, Johan
    bv10
    Tignum
    GOLD Member
    Hello Håkan,
    That should work fine. See my setup where I also linked a BV10 through NL.
    250105 beosetup.001
    Let us know how you move on 🙂
    Regards, Johan
    in reply to: Advice required on replacement Beovision #62276
    Tignum
    GOLD Member
    Hi London Joe, and welcome back!
    I trust there are some nice B&O TVs to be found, but an option could be to re-purpose the BeoSystem 3 that is integrated in the BV9, and use it with a modern third party TV. You can feed the audio from that screen into the BS3 and enjoy its surround sound, as well as keeping all MasterLink integration you have right now. I do this with an LG screen, using the LG as the ‘video hub’ (with an Apple TV connected) and the BS3 as the ‘audio hub’ (with my ML/NL system). You will have to deal with two remotes unless a dealer can help and load a PUC file into your BS3. You will need an S/PDIF converter (optical to coax) most likely, and a suitable B&O IR eye. Check this also https://forum.beoworld.org/forums/topic/controlling-an-lg-oled-tv-using-beosystem-3/ . There are more threads.
    Just to make sure you consider this option too.
    Regards, Johan
    in reply to: Beocenter 7700 problem: no output on one side #62022
    Tignum
    GOLD Member
    Hi Mark, you could contact BeoBuddy (forum member) for repairs. He is located in Utrecht, he has been helping me with repairs quite a few times, all successfully.
    in reply to: The Beoworld December 2024 Prize Draw #61788
    Tignum
    GOLD Member
    Congratulations! These are nice prizes.
    Thanks PrizeBot and all at BeoWorld. Merry Christmas!
    in reply to: B&O Inspired Amplifier #61636
    Tignum
    GOLD Member
    Built to last! Beautiful work xschop.
    in reply to: Paul McGowans’s opinion of B&O speakers #61635
    Tignum
    GOLD Member
    That broken TL tube would annoy me big time!
    in reply to: Software update Beosound 5E #61512
    Tignum
    GOLD Member
    Hoi Peter, schitterend apparaat! Ik zocht er één en dacht die op mp gevonden te hebben, maar het bleek toch een BS5/BM5 combo te zijn. Wel meegenomen 🙂
    Heb je de procedure in de handleiding gevolgd? https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND%20SYSTEMS/BEOSOUND%205%20ENCORE/beosound5-encore_userguide_dutch.pdf
    Groet, Johan
    in reply to: Jacob Jensen weather station outdoor sensor replacement #61508
    Tignum
    GOLD Member
    Nice. Fingers crossed! (with ‘kit’ I trust you mean ‘sealant’ :-))
    in reply to: BS 9000 multiroom RJ45 #61228
    Tignum
    GOLD Member
    Something like this then:
    ‎ml.‎001
