Millemis
Forum Replies Created
Viewing 20 posts - 1,221 through 1,240 (of 1,252 total)
  • in reply to: Stereo sound from a mono speaker? #34264
    Millemis
    Would be nice to know which other Play speaker can work this way.
    For obvious reasons you can not expand the inner ring with the M3…….but what about the M5, since it has more drivers?
    in reply to: New Halo firmware at last…. Version 1.5.930 #34267
    Millemis
    Thanks!
    Would be nice to see the Halo in action with the 90/50’s – to see which benefits that would bringin real life.
    in reply to: Connecting an Essence remote with Beosound 5 Encore #34252
    Millemis
    Seems that not all can see the pic/screenshot, that I postet previously.
    Tried to convert (from png) to jpg – maybe that is better.
    F79B8FF6-66D3-4672-9333-B3AA283CC097
    in reply to: Which Beocenter / Beosound #34249
    Millemis
    That all depends on how the converter is configured.
    You could start with reading one of the threads in the old forums – e.g. this one:
    https://archivedforum2.beoworld.org/forums/p/16772/145937.aspx#145937
    And the manual – can be found here:
    https://www.manualslib.com/manual/2021215/Bang-And-Olufsen-Beolink-Nl-Ml.html#manual
    in reply to: Connecting an Essence remote with Beosound 5 Encore #34251
    Millemis
    The BS Encore is an ir-controlled products.
    Be sure that the Essence remote supports ir modes (the first versions did not).
    Then switch it to ir mode – see here:
    https://support.bang-olufsen.com/hc/en-us/articles/360045073252-How-do-I-set-up-Beosound-Essence-Remote-for-use-with-Beosound-Moment-
    Maybe this can help:
    A7F186BC-5922-45FC-9934-437B122AB9FB
    This is all I can find right now – maybe another member knows more.
    in reply to: Beoplay EX – First Image? #33905
    Millemis
    Now launched in the EU as well – available from the beginning of May.
    https://www.bang-olufsen.com/en/dk/earphones/beoplay-ex
    Price is as with the EQ.
    in reply to: Which Beocenter / Beosound #34247
    Millemis
    Anything that has a datalink connection for the controlling.
    See this article:
    https://www.beoworld.org/article_view.asp?id=64
    Most common in use are the ‘pizza box systems’/6500-7000 or the BeoSystem 4500.
    in reply to: Beoplay EX – First Image? #33903
    Millemis
    Oh, well!
    The price is equivalent to 375 €.
    Will be interesting to see, when it will be released in the EU/UK….and if the price will be the same, which would be in the range of the current in-ears.
    in reply to: Beosound stage #34215
    Millemis
    Stage/C1 is a common combination – there should be no problems there.
    You can use the line input of the Stage for any audio device….with the right cable.
    However, if you connect the BM5 you will have to deal with two x volume controls (and maybe even two remotes).
    Do you also have the BS5 unit?
    If you just want to have access to the music on the harddrive of the BM5, you can access the files throught the Stage/the Bang & Olufsen app.
    You also have access to internet radio via the Stage, no need to use the BM5(/BS5) for that.
    But maybe you like the BM5(/BS5) and want to keep it —— it is possible, but with some drawbacks.
    in reply to: Beoplay EX – First Image? #33900
    Millemis
    This is odd – still not released (as far as I can see), but already unboxed/reviewed on YT:
    https://youtu.be/10wSPyMMhkc
    in reply to: What are you listening to…..right now. #33129
    Millemis
    Here is the direct link to the old thread in the archivedforum2.
    https://archivedforum2.beoworld.org/forums/t/66.aspx?PageIndex=1
    An always inspiring thread ?
    in reply to: Chromecast #34148
    Millemis
    In that case it is not a MK3 version.
    With the pre-HDMI versions you mostly adress the DVI as PC – however,  there are different versions there (of the BV7 without HDMI).
    in reply to: (Ungelöst) Beomaster 5 / Sonos Port #34193
    Millemis
    Ein ML/MCL converter für multiroom system!
    Was für Geräte hängen daran?
    in reply to: (Ungelöst) Beomaster 5 / Sonos Port #34190
    Millemis
    Du kannst den USB-eingang des BM5 für eine externe Soundkarte – genauer gesagt einen Behringer UCA222 – nutzen.
    Z.B von hier:
    https://www.thomann.de/de/behringer_ucontrol_uca_222.htm?gclid=EAIaIQobChMIq5390pyU9wIVSON3Ch1Wiwd1EAQYASABEgJYq_D_BwE
    Dann hast du einen L/R Phono-eingang – dieses USB-gerät wird vom BM5 erkannt und ist durch A.Aux erreichbar (siehe Bedienungsanleiting des BS/BM5). Der Sonos Port muß dann auf ‘fixed volume output’ eingestellt werden – die Lautstärkeregelung erfolgt via das B&O-setup.
    Ein Problem aber könnte sein, daß A.Aux nicht direkt von deinen Link-räumen erreicht werden kann. Dazu müssten wir mehr über das Setup wissen.
    P.S.
    Für den Ton eines TV’s ist das nicht zu empfehlen, da ein ‘Sound delay’ entstehen wird.
    in reply to: Chromecast #34146
    Millemis
    As long as the tv has an HDMI input port, that should be fine.
    Just connect with a good HDMI cable and configure the device with a mobile phone/tablet….
    With the Chromecast only picture and sound is shown/heard – all controlling happens in the sending device (apart from the volume control).
    With the B&O tv you will have to assign a command/button on the Beo4 in order to turn on the tv to the right input.
    in reply to: USB fan on avant 2014 mk1? #34140
    Millemis
    Hi scanorama99
    There were several threads in the (now) Archived Forum 2, where there was talk about this.
    See here:
    https://archivedforum2.beoworld.org/forums/p/30790/356657.aspx#356657
    The Willy, who is mentioned there, is not on Beoworld.
    However, he is active in the Beotalk YT show – you may be able to contact him via the show or his social media.
    But…..maybe another member will be able to provide more details.
    It does not seem to be that hard, if you have some technical skills.
    in reply to: Beo4 #34025
    Millemis
    There is a Service Manual for the 1624, which on the first pages gives you an overview of the ‘buttons’ of that remote here:
    https://www.manualslib.com/manual/1104340/Bang-And-Olufsen-Beo4-1624.html#manual
    in reply to: Beo4 #34023
    Millemis
    There are several different versions of the Beo4 – and also different sw versions.
    If you do not find the wanted entries in the List (by ‘adding’), they won’t be there. A ‘reset’ will not help.
    So hard to say, if we don’t know more about version/sw version.
    P.S. e.g. N.Radio came later, when it was needed for the actual current Beo-product. However N.Radio is the same code as Phono….if you have that on your Beo4
    in reply to: Where do you see B&O in 5-10 years? #33672
    Millemis
    Well, I must be the only optimist around ?
    No, you are not….I just find this kind of rhetorical questions a bit over the top.
    Not worth spending much time answering IMO
    in reply to: Where do you see B&O in 5-10 years? #33671
    Millemis
    Double post
    However, the other one disappeared ?
