Millemis
Forum Replies Created
Viewing 20 posts - 721 through 740 (of 1,256 total)
  • in reply to: New product launch – beosound theatre? #38383
    Millemis
    Ok – thanks!
    in reply to: New product launch – beosound theatre? #38381
    Millemis
    Hasn’t that been so for ‘ages’ already?
    Or is just because – on the BST – I usually use the My Buttons for my favourite (3) stations and never looked at it that way?
    This is exactly like it used to be on my ASE products.
    Should that really be new on the BST?
    N.B.
    I tranferred my TuneIN favourites long ago to the B&O Radio list in the app back then when the B&O Radio started.
    in reply to: New product launch – beosound theatre? #38379
    Millemis
    My Theatre just got the 2.5.5 update.
    In the report I find this:
    Long press now activates PUC function’.
    Anyone knows what that means….what is the purpose/benefit?
    IMG_0571
    Furthermore, how do you ‘add the favourite radio stations to….’?
    I guess that means that it now should be possible to use the numeric buttons to go direct to one of the favourites?
    in reply to: Your latest addi(c)tion? #34903
    Millemis
    Hej Martin
    Not really….unless I buy a GuldTuborg
    M?M
    IMG_0570
    in reply to: Your latest addi(c)tion? #34901
    Millemis
    My latest new….
    IMG_2146
    Use it or just look at it?
    in reply to: How to Connect Beolab 14 to a streamer and a TV #47085
    Millemis
    This one may be an option:
    https://hallaudio.com/en/produkter/traadloes-streaming/hall-wifi-streamer/
    in reply to: New product launch – beosound theatre? #38377
    Millemis
    It is definitely Atmos (based on Dolby Digital Plus), if labelled ‘Atmos’…….independent on the streaming service.
    in reply to: Beosound A9 Gen5 Review #47021
    Millemis
    @Steve
    in reply to: New product launch – beosound theatre? #38375
    Millemis
    Not many titles with DTS:X sound – and certainly not from streaming services.
    Best way to send a request is to ask your dealer to forward it to B&O HQ.
    Personally I have some blu ray titles, that have a DTS soundtrack – with 5.1/7.1, but none with DTS:X.
    I let my blu ray player decode these – they play/sound fine on my BST setup.
    in reply to: New product launch – beosound theatre? #38372
    Millemis
    Nvidia Shield – well then:
    https://www.nvidia.com/en-us/shield/support/shield-tv/avr-surround-audio-setup/
    in reply to: New product launch – beosound theatre? #38369
    Millemis
    Already in the previous update version support for 3rd party speakers and amps were added.
    IMG_0564
    in reply to: Link Beovision 7-40 to 2x Beovision 6-26 #47037
    Millemis
    In addition to what Guy writes, a solution would be to use additional boxes on each BV6-26.
    Alternatively to use ATV’s – looking up the Ocilion website there is an app that lets you enjoy all that the box can offer.
    Streaming via chromecast from a mobile device also seems to be an option.
    I agree that you most likely won’t find any Ocilion PUCs in the tv’s.
    It is a tricky situation – I am afraid that you will never get back the ease of use that you had previously.
    On the other hand you may gain new possibilities (streaming from video services and alike) from a new Ocilion setup.
    in reply to: New product launch – beosound theatre? #38367
    Millemis
    I agree with Mr10 – the better choice would be to connect the player directly to the BST in order to benefit from PUControlling it/using the BROne…..if possible.
    This is mostly the best way.
    (Which player is it?)
    A passthrough function of the LG will not help, since the BST can not decode DTS:X.
    You must let the player do the decoding to PCM (if it can), so that the BST becomes the base layer (5.1.7.1) to play.
    Then the BST/the True Image processor will adapt this to your room……depending on your speaker setup/listening positions.
    Note: some players will only decode DTS to a 2 channel stream.
    in reply to: What are you listening to…..right now. #33199
    Millemis
    in reply to: Beosound A9 Gen5 Review #47016
    Millemis
    Excellent – thanks!
    in reply to: AppleTV 4K dolby vision issues #46815
    Millemis
    There are lots of videos out there how to set your ATV4K in order to get the best video quality.
    This is an example of how these look:
    IMG_0550
    As I – now – understand it, your ATV is located in a distant room.
    (This has nothing to do with the matrix, you also have)
    Therefore you use the extender kit (Balun…).
    It might be that this does not support the required bandwith for these settings.
    Best thing to do would be to relocate the ATV – if you possibly can – and plug it directly into the LG or the BST (with PUC) using a proper HDMI cable with at least 18 Gigabits per second speed.
    in reply to: AppleTV 4K dolby vision issues #46800
    Millemis
    This means that the extender kit is used for something else…..but not the ATV, right???
    It is unbelievable that a “Certified B&O Installation Partner“ would not adjust an installation, that has been done less than 6 month ago for free….
    ….and instead demands a service agreement before doing the job.
    Also a certified B&O partner should prioritize the direct connection to the Theatre and the use of PUC for controlling.
    in reply to: Me, myself and I… #46859
    Millemis
    Matador is a very wellknown family saga in Denmark.
    If I say that everyone in Denmark know this tv series – and that the wast majority have seen it – I am not lying!
    The series is based on an idea from the danish writer/journalist Lise Nørgård, who died in january this year at the age of 105.
    It was meant to be a novel, but ended up being a series with 24 episodes.
    It covers the period (in Denmark)from 1929 to 1947 – the airing started in 1978 (Danish tv – DR) and it has been aired multiple times up till now.
    It is often used in schools when teaching history.
    Matador is the name for the social game known in english as Monopoly.
    A matador is the bullfighter who leads the team and gives the bull the death blow…..a person with power and will to use it.
    in reply to: Beosound Balance and Dolby Atmos #46713
    Millemis
    Sia43 wrote
    I, for one, acquired a pair of Levels and a Pair of Emerges and will not buy another B&O product until they fix the mess they created with their Mozart system.
    • I see no mess there!
    They never promised anything regarding use of Mozart based speakers with the Theatre as you both your.
    Be happy, if – and when – they come up with such a solution.
    B&O is a small company, where things takes time…..you probably knew that when buting.
    in reply to: Beosound Balance and Dolby Atmos #46711
    Millemis
    The physical connection is not the problem.
    Every new (B&O) speaker/sound system has some kind of sound processing going on.
    With the ‘common’ Beolabs the Theatre knows about the characteristics of each speaker – not so with systems like Level etc.
    My guess is, that we will have to wait for a new connection via Mozart in order to have a proper integration with speaker roles etc.
    The interesting question thereafter however, will be if we will be able to mix and match speakers connected with Powerlink, WiSA and a new Mozart-based connection on the Theatre.
