matador
Forum Replies Created
Viewing 20 posts - 621 through 640 (of 845 total)
  • matador
    Hi alls,
    I haven’t chime in so far because having given up on the case I felt I couldn’t help.
    But, from the tail to the tip:
    • warm, ambiance and white may refer to the kelvin temperature of color : the difference between the surgical white of early led lamps and the more comfy orangish light close to tungsten lamps color…
    • I’ve investigate the use of led lamps with LC’s and what I learned, that hasn’t been mentioned so far, is that there is two dimmer types: Leading Edge Dimmers vs Trailing Edge Dimmers
      One work with dimmable leds, the other won’t. This leads to led lamps that are compatible with the sort of dimmer LC’s are (can’t remember which). What I remember is, in time, they where hard to find and quite expensive but it was long ago and nowadays maybe basic Phillips hue or Ikea will fall in that category.
    So beside the IR/BT need and if the crazy “power consumption” comes from the lamp and not the LC itself, then it may worth a Beoworld investigation to see where we are now.
    (Got one LC2 with a 100W spot lamp above my desk for when I swap belts on any Beocord) and it is really carefully monitored for on/off time, so I can’t help further but now you know all I know.)
    Regards.
    in reply to: Download FROM Beo 5/6 #40409
    matador
    As far as I know, no it’s not possible.
    But I would like somebody say otherwise.
    in reply to: B&O NFT collection #40163
    matador
    My two cents…
    NFTs are not for us. Period.
    C’mon guys, where all dealing with any capacitor value shortage or Beoparts.com life expectancy to keep alive a beomaster that is an energy consumption nightmare (I would like my english level allows me a more scaring wording…) Bt lets be realistic, we are all dinosaurs   and some of us are T-rex (Square 5, who takes it all) but we’re all close to die.
    That said, we love the brand, some for a simple Beosound A1, others for the history of it and others for someone else that live through the BV harmony or the BS theater or even  the recreation of beograms (that are dreams for many of us I believe).
    SO.
    That NFT thing is B**** sh***t to me too. I can provide you any B&O 3D animated gif for free.
    BUT
    If it’s a way to keep the brand alive because it as to live with it’s life, then… OK
    We all know what B&O is. Let’s be friendly and educate those who don’t go to Bose or Devialet and will end up asking for help to infuse sinter bearings…
    in reply to: B&O NFT collection #40157
    matador
    By the way, it offends me when websites don’t let casual non-logged-in users see pictures
    Don’t let yourself be offended: this is a know issue that will be addressed when the voluntary guy running Beoworld will have time to sort this. In the meantime it’s possible to every member to add a simple picture as an image (with the picture button in the post compose window) and not an attachement for everyone to see it.
    in reply to: U70 Earpads… #40036
    matador
    And if anyone is interested…
    • You can turn the old white wool pads inside out to have a leather like surface again…
    • You can also try “mad catz triton” replacement earpad: a couple of dollars, slightly larger but they should fit nicely.
    God save the U70!
    in reply to: Beogram 3000 tonearm lifting too late… #39884
    matador
    Hi Martin. Thanks for chiming in…
    I don’t feel like it lift slower than it drops or slower than the BG12xx I own.
    Of course, compared to a BG400X the move is more “damped” But nothing that I could described as sluggish.
    Yes it has worked in my possession. It has even been my main deck until I get a 400X.
    Hope the helps.
    in reply to: Beogram 3000 tonearm lifting too late… #39882
    matador
    Anybody?
    in reply to: DIY Beolab 8000 Wood frets (STLs included). #36821
    matador
    Yes it is.
    in reply to: Ouverture glass doors repair… #36959
    matador
    I dind’t see the answer until now.
    I’ve contacted Beogogo, who I’d like to thank for his generous offer.
    in reply to: Repaint Beolab 4000’s #39891
    matador
    Or you may consider car covering vinyl…
    in reply to: The New BG4000C #33561
    matador
    Which actually mentions Beogram 4000 as well.
    Yes, I’m with you on this but i think we’ll never have another answer that the one Steve gave us earlier in this thread.
    in reply to: The New BG4000C #33559
    matador
    Maybe there?
    in reply to: The best choice for your first B&O speaker? #39820
    matador
    I’ve always wanted one but those are expensive around here, at least not the price I would be ready to pay for it. Also most of them have faulty CD player…
    Yes the grill is fragile, but If I had one with damaged grill I’d try to “wood” it. Should look nice!
    But I rather like a nice gold or silver BS1 with floor stand.
    in reply to: Beosystem 10 vs Beolit 20? #39575
    matador
    the Beosound 3 does NOT have an aux input.
    If only…
    in reply to: The New BG4000C #33555
    matador
    With the lack of details on what is done to the Beograms…
    I was wrong! But still…
    in reply to: The New BG4000C #33554
    matador
    The 95 people basically received a “new” product, while the kit “only” provide a more professional refurbishment.
    One can wonder if this is not only a way of speaking.
    With the lack of details on what is done to the Beograms I wouldn’t consider this expensive refurbishment as “more professional” as the work of some fellow Beoworlders that go very deep into the guts of the deck (bearings, full recap, light replacement with less, …)
    For exemple, appart the one on the marketing photos I’ve not seen a BG4000c with the plates and the platter perfectly aligned and adjusted (you can skip perfectly if you want).
    in reply to: The New BG4000C #33552
    matador
    Could somebody remind us the bold lines why the 4002 is easier to service than the 4000?
    in reply to: Beosystem 10 vs Beolit 20? #39573
    matador
    I also see there’s something called an A1, which’ll be in the other end when it comes to sound,
    Given you have considered a Beosystem 10 or even the Beolit 12 I’ve talked about, an A1 or even a second and A2 will not be “in the other end when it comes to sound”. At all!
    I suppose they can’t be compared with the Emerge or the Level of course, that are standalone systems but they’re both very impressive speakers by themselves.
    in reply to: Bang and Olufsen Stereo Waltz #38939
    matador
    Ok, ok , ok, It’s just for display… But still…
    IMG_0278
    in reply to: LC2 Repair #39613
    matador
    Lausvi, your avatar rocks…
