matador
Forum Replies Created
Viewing 20 posts - 481 through 500 (of 845 total)
  • in reply to: BeoLink Converter 1611 Innovative Configurations #42319
    matador
    I am now trying the BL3500 with BL1611 and it seems to behave exactly as Matador’s.
    Guy, do you have a Beolink Active 1636 (or 163x)?
    I was told 163x converter replaced 1611 😉 and I would like to know if it can drive the 3500 as standalone the same way the 1611 does.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42318
    matador
    I think yours may be SW2.1, whereas mine is 2.0.
    One is labelled SW 3.1. The other (the one I use for tests) does not show SW version on the sticker, but I will check it next time I plug it
    About the price of 60kWh of electricity.
    God, with those price it almost worth moving to your region!
    in reply to: My Beocenter 9500 Restoration #42788
    matador
    Hi Beitie,
    Thank you for sharing your work. May I suggest that you add your pictures  in the post by clicking in the little framed mountain, last button in the window where you type your message? Better than as attachement because they will show up in the thread bigger than the little preview of an attached picture.
    Thank you.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42312
    matador
    Is that the same on yours Matador?
    I can’t say, you’ll have to wait I replug the whole thing (I disconnect everything after each experience and don’t use it daily). PC shows PC and open the audio/audio port of the 1611.
    Just guessing but wasn’t the PC command added for the Beoport or when computers became an usual source of sound? Then it would make sense it shared the V.AUX entry like if it was the audio part of an AV source (sound plus picture i.e computer screen). Maybe related to the beomedia implementation? I don’t know.
    It would be interesting maybe to have a little timeline with beosources names changes and equivalent over time?
    I have an energy counter plug. I will check if power consumption change between on, muted and off. would be sad and surprinsing that there is no standby mode even if I dont hear any click when the speaker turns on.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42310
    matador
    A.AUX doesn’t work (nor does PC)
    I don’t understand: is it that the commande from remote does not call an audio source?
    she doesn’t like the look, and thinks there’s something missing from the middle.
    Honestly? she can’t be more right, I feel the same. Just put an iPod on dock or better a cactus in the middle!
    in reply to: BeoLink Converter 1611 Innovative Configurations #42307
    matador
    One of my first tests will be the BL1611 ‘dual-input’ to the BL2000,
    Selectable with the front key!
    Congrats on your new toys, may we make the interest to this understated speaker rise, make it the poor man’s Beosound 35…
    in reply to: BeoLink Converter 1611 Innovative Configurations #42303
    matador
    Burned!
    Yes stupid me about ML over PL… Anyway, falling is sometimes discovering.
    SO, guys, THREE sources on a Beolab 3500, yes three!
    Source 1 from audio input of the 1611 converter.
    Source 2 from video input of the 1611 converter.
    Source 3 from the PL path “Menu 0 4 GO”. But there is a little background hiss, hopefully from too quick wiring, Steve should tell us.
    The three sources are working altogether. Of course touching any control on the remote turn off the speaker when on PL mode.
    I’ve tried wiring the Matserlink input along with the converter and guess what happened? A “mix” of the two sources of course (Master link from the hack and Masterlink from the converter)!
    As for the 5v triggering, I’ve talk with the (sympathetic) guy and tried and it works for him (MK1, which has MCL engraved under the DIN socket), but not for me (MK2).
    in reply to: B&O CX100 Woofer #42830
    matador
    Unless it is another fault, it’s a quite cheap and not so complicated task to refoam it.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42301
    matador
    What I wonder is if it would be possible to have a stereo jack to Masterlink wire and then have a third input. Imagine:
    A.AUX = Airplay (Multiroom), volume control from the remote.
    DVD = Turntable through integrated or external RIAA, volume control from the remote.
    “Menu 0 3 GO” = Bluetooth Receiver, volume control from the device (which make sense since it will often be a phone, and the symmetrical to asymmetrical loss will be less sensible because of BT).
    in reply to: BeoLink Converter 1611 Innovative Configurations #42300
    matador
    From my readings in the forum, it allows to the linked device to know when you turn on or alter volume on a master unit like the BC2300, from its local controls, A.AUX.LINK not carrying volume or On/Off information.
    Therefore the Powerlink socket just has the data pins connected and no sound pins connected at all.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42298
    matador
    Guys, I’m sorry to be unable to participate to your Datalink investigations, far beyond my understanding, experience and available material (I used to have a full 5000 that was quite amazing but it goes away…).
    in reply to: What are you working on now? #33340
    matador
    Nice!
    Did you change the lid or is it the original one? If so how did you get it back this nice?
    in reply to: Beogram 4000 and Beolab 5s #42756
    matador
    Not sure: when I bought mine it had no speaker connected which would automatically turn the unit in A.OPT 0, but I still could check the unit listening to the radio thought headphones. (Didn’t spared me to buy an unit with all the sledge linkage missing ;-))
    in reply to: Beogram 4000 and Beolab 5s #42754
    matador
    As the OP mentioned, I would have expect the analog sources of the 9000 travel via Master link to the BV and then the speakers.
    in reply to: beolab 6000 repair with end of 3500 #42763
    matador
    My god, “a beolab 3500 just lying here…”, criminal.    😀
    Service manual show different part number but the look like very close with the same groove and have the same way of mounting, two prongs and a screw in the middle.
    If you have booth at hand, I would take measurements and try my luck.
    Capture d’écran 2023-01-13 à 14.15.55Capture d’écran 2023-01-13 à 14.15.47
    in reply to: BeoLink Converter 1611 Innovative Configurations #42281
    matador
    Who said B&O was all Look over substance?     😀
    in reply to: BeoLink Converter 1611 Innovative Configurations #42279
    matador
    (making my own ASNUT cable)
    Please, name it differently!
    in reply to: BeoLink Converter 1611 Innovative Configurations #42277
    matador
    There is a Beoport around for not too much. I’m still hesitant to take it since I’m a Mac guy.
    But after today, who knows how much fun we could have with it!
    I know they’re is a driver for Mac Called BM-link that still can be found but it seems it was another one a little bit better and this one cannot be found anymore. That stops me.
    Good it helps your setup Guy.
    Cheers and again, thank you for being partner in crime.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42275
    matador
    Well done! MM
    Thanks MM
    in reply to: BeoLink Converter 1611 Innovative Configurations #42274
    matador
    I think that together we have doubled the value (and second-hand prices!) of BL1611 Converters, and probably BL3500 as well.
    Actually that was my main concern before posting, since I still need a second converter.  😀
    Maybe add a note to say that the BL3500 is in L.OPT 6.
    Done.
    Actually, is it me or have you got the Audio and Video Beo4 sources reversed in the diag?  Pins 3 and 5 (video source) were on the right hand side – source B.)
    They were reversed, corrected now.
    Also, have you tested what source (A or B) the PC command selects, if any?
    Channel A (Audio side) can be triggered with a PC command. Beolab will display “PC”.
