matador
Forum Replies Created
Viewing 20 posts - 301 through 320 (of 845 total)
  • in reply to: BeoGram 5000 to Beovox CX50? #46946
    matador
    Hi and welcome to Beoworld,
    I can’t tell about the CX50 but if you’re looking for consistency, you should look around for a Beomaster 5000/5500/6500 or 7000. Those are the amps that are part of the Beosystem with same numbers, They’re often called “pizza box” because of their design. I dont know all the Beomasters some may or not have integrated RIAA preamp, I don’t know.
    The 5000 is the oldest and is quite difficult to service but its a beautiful beast and sound very good. It also need a specific remote that could be a little bit too much if you dont need the whole system. The 5500 may sound a little bit duller (mine did compared to my 5000), the other I don’t know. Some have different finishes (mat silver, silver, white, black…)
    For the speakers, depending on the amp you choose, you may also want to look for the Beovox (passive) 3000/4500/5000 and their Beolab (active) counterpart with same numbers. They are panel speakers and their Mondrian style should match the pizza box design.
    Hope this helps.
    in reply to: Beo6 battery management… #46395
    matador
    Random observations. I dont know if this is relevant or even useful.
    I’m measuring the battery out with a voltmeter.
    The remote is on the 400mA dock. It is stuck in a loop:
    Starting > Fading > turning off > starting again and so on…
    When starting the voltage goes up to 2,7 volts.
    When fading the voltage decrease slowly down to 2,1 volts.
    When the remote turns off the voltage seems to go steady around 2,4 volts.
    Ad lib.
    The screen shows “charging“.
    If I disconnect the dock, the remote goes off, the voltage goes crazy between 2,4 and 2,1 volts for a couple of seconds before going steady at 2,45 volts.
    If I remove completely the battery, the remote also loops and still shows “charging“.
    So I’m unable to say if the battery is dead or the remote can’t see any battery for whatever internal reason. Plugin in a “fresh” battery pack changes nothing so I’m prone to believe its more a remote related issue but then the questions would be:
    1 – Why so suddenly? Is there a sensitive component that could be damaged when opening the remote to change the battery? I think we would have heard of it and the Service Manual doesn’t mention any specific procedure.
    2 – In three remotes the same way? C’mon…
    in reply to: Beo6 battery management… #46394
    matador
    It didn’t work.
    The Beo6 Is still out of battery even thought it was docked for hours and the battery was healthy before the “incident”.
    That’s three of four Beo6 that show the same symptom and that’s only because I’ve not tested the fourth one.
    The only common history they all share is that they have been teared down and up again many times. Is it possible that it was a sensible component about power management that may be hurt in the process? The service manual or the BW replacement procedure article say nothing about a specific thing care of.
    in reply to: Beo6 battery management… #46393
    matador
    Trying this, hope it works…
    IMG_0857
    in reply to: Beo6 battery management… #46392
    matador
    Another problem, but still Beo6 battery related. Today, my beloved an trustful Beo6, heart of the living room, started to show a problem: some keys did’nt emit anymore.
    In the end it was some sort of config corruption and the easy way would have been to set the remote to standard config via the internal menu and then back to the the custom config.
    But before I knew that I did the usual: opening, checking, trying to swap the keyboard, etc.
    In short I openend the remote disconnected all and connected it all back.
    The key are working again but the remote is not charging anymore, the battery last a few seconds before going off. I would say like if it was no battery at all but the remote is working for a few seconds when left from the base. Even when on the base, using the remote also drain the battery immediatly leading to a reboot.
    The power on this remote is really a mystery to me… Any hints?
    in reply to: B&O Century Remote #46852
    matador
    Very common IR board fault. Two capacitors to change. Follow the guidelines in the link provided by Guy above.
    in reply to: Beosystem 72-23! #46674
    matador
    I’d like to add that, to me, the most obvious problems just that it is… Ugly!
    The 72-22 was very nice: mat silver, dark wood, always sexy Beolab 18, whatever ridiculous the price was, the system is beautiful.
    There, it is just… Ugly. And as far as I can tell but I’d like to have your views on that, This color scheme do not make me think me to any Scandinavian dawn.
    Beolab 28 with tweed like fabric? Really?
    in reply to: B&O in Movies, TV Shows or similar… #34126
    matador
    Beovox “something” in the very mind-puzzling movie “The Father”.
    Capture d’écran 2023-05-17 à 13.01.24
    I have had hard time trying to find to what they are connected. Found some hints but not sure:
    A Beosystem 5000 behind the table? Maybe…
    Capture d’écran 2023-05-17 à 13.02.17
    Or perhaps the Beosound Century MK2 seen in the mirror?
    Capture d’écran 2023-05-17 à 13.02.24
    Because I know it can’t be the Beolit 12 in the kitchen, right?
    Capture d’écran 2023-05-17 à 13.01.54
    in reply to: Beosystem 72-23! #46665
    matador
    Hi everyone, Hi Steve again,
    I don’t share Steve’s enthuthiasm (and he very well know why, right?).
    Whoever Beoworlder coud make “almost” the same set for the fraction of the price; most of the money economy being in a forum-guided-beogram-4002-refurbishement-project, up to everyone to choose his own components. My choice was an original BG4002 because I like the color (loved the 4000c in his champaign color promo pictures but real life yellohish pictures proved to be too much “nicotine*” to me), Beolab 8000 over  Beolab 18 because its all I can afford and a 70€ Playmaker and some Powerlink wires instead of a Core, Emitter and whatever else.
    The result may not be Hi-Fi or two-point-zero but I’m listening to records with the eye candy.
    I remember Leo or maybe Moxx, ironically saying “new beoplay=new colors”. I feel the same here and it’s sad for me. Not that I dont understand people that will go for it, they surely will and its good for them and for the brand (moneywise). But sad in the idea that they sold us (the few of us) an idea that was “we’re going to recreate many of our iconic products, wait and see”. I remember a thread in BWII where people where guessing what would be the next “recreated” products, part of the new “recreation” program. In the end it’s just the Beoplay, new colors strategy. Nothing more. Up to anyone to like it or not.
    But to be complete, the exercise, yes, would have to have ginger colored wired!       😉
    in reply to: BL3500 and the MCL/PL connector #44570
    matador
    Madskp, I love you and am for sure following this.
    in reply to: Beosystem 72-23! #46660
    matador
    Really ? Sorry to be bitter again but this is starting to look like the Omega brand that can’t stop to produce infinite different flavors of their “once in the past” bestseller Speedmaster watch.
    Appart from the fact I don’t like the color scheme at all, I wonder how many iterations we’ll see in the future: pop colors Basquiat yellow/red/blue? All mat black version? Limited original colors version? Beoplay H4 tangerine like edition?
    It just kill the hope I had in the “Recreation” trend when the first 4000c came out, that made me hope for some other comebacks that I understand will never be.
    in reply to: Beomaster 5500 running hot #46627
    matador
    You’ve got the answers, you’ve got the schematics, you’ve got the value, that’s all the tutorial you’ll need.
    Hello, please and thank you would have been welcome also.
    in reply to: Beo6 battery management… #46391
    matador
    Hi everyone,
    I would like to keep investigating. I’d like to try different source of power but to help the process and remove the variables I’d like to know how the thermal protection works.
    If I want to remove it for my tests how do I mimic it? Do I need to short it (Meaning red wire and white wire connected together) or just remove it (meaning white wire disconnected?
    Thank to anyone who can help.
    IMG_0869
    in reply to: What are you working on now? #33369
    matador
    Too bad! Thank you for looking.
    (It would be nice and useful to launch a thread on these Beo4 screen fault and find solution! I still dont understand when the fault is before or after the gummy band…).
    Enjoy the beer!
    in reply to: What are you working on now? #33366
    matador
    the only fault was a damaged screen – it displayed fine but had damage in the corner.
    Wouldn’t it be possible to repair the screen? I don’t remember well how they’re made and what cause the leaking, but if it can be removed and the glass repaired, that would made a better remote that one with a missing line of pixel or very dimmed digits.
    in reply to: Beoplay A3 #46237
    matador
    Hi Xavieritzmann,
    Did you have the main charger plugged all that time?
    By now all batteries would be dead or weak at the best and as you said, I wouldn’t trust too much a 10€ battery. This added to the fact that you already had charging issues before, I wouldn’t say that the A3 is dead yet.
    Do you have a way to borrow an iPad 1 or 2 to check A3 in its normal condition, then assess the battery health and then, once you know, play with the adapter? I feel like you have too many “variables” in your equation  there.
    It is possible the A3 is faulty, but I think its a solid piece of hardware so, I would insist a little more to bring it back to life.
    in reply to: wanted motor for casettedeck Ouverture 4000 #44039
    matador
    Exactly.
    in reply to: wanted motor for casettedeck Ouverture 4000 #44036
    matador
    Is Ouverture 4000 a model?
    C’mon, I think we can be forgiving there, Bang & Olufsen being the first to have numerous confusing model names, right?
    in reply to: Bad smelling cabinet damping S45-2 material! #46369
    matador
    Follow Dillen’s advice has always proved to be te way to go…
    in reply to: Beoplay A3 #46235
    matador
    Maybe it worth asking Keith if he have any manual related to the A3.
    I think the A3 is a very delicate thing to open, not that delicate actually but the chances to harm the aluminium trims are there, so no ay to look inside to see any markings on the PCB.
    Here is the picture of a 1.0.4.0 SW A3.
    IMG_0853
