Mark-sf
Forum Replies Created
Viewing 20 posts - 221 through 240 (of 488 total)
  • in reply to: Beogram 8000 – massive hum #52975
    Mark-sf
    The correct cable did have a Phono label at one time to distinguish it from a Beocord cassette cable. Datalink cables have 7-pins instead of 5 and pins 6 and 7 are removable as they have a small screwdriver slot at their tips.
    in reply to: Nomination for the honesty in advertising award… #52430
    Mark-sf
    I’m not sure I’d buy that he sold it for $3K as it was never sold in mint condition. You can clearly see in the video the wear spots on the control panel and pitting throughout. Also his “repairs” are dubious. Who wraps tonearms in foil tape? If he knew what he was doing he could balance and center the platter plus clean the top plate. The cantilever is also askew. In that condition and at that starting price he’ll be lucky to sell it in 6 months. Pass!
    in reply to: RX-2 won’t track; resets to outer groove. #52319
    Mark-sf
    Image shows the stylus is long gone. Time for re-tip or replacement.
    in reply to: Beogram 1202 Pickup gap #51890
    Mark-sf
    While it is not the best angle to examine, it does look like the tracking force is too heavy or the stylus’s suspension is shot and needs replacement. If it’s an SP-10 or 12 it should be 1.2 grams.
    in reply to: Beocenter 8000 and Active Speakers? #50960
    Mark-sf
    You can use the Line input into the Beolabs as I described above as they will turn on when they sense an audio signal.
    in reply to: Beocenter 8000 and Active Speakers? #50958
    Mark-sf
    Which active speakers are you considering?  If not B&O you can pad the speaker output or use the headphone output directly.
    in reply to: Beogram 1602 Tracking #50488
    Mark-sf
    What you are hearing when you physically touch the stylus is cantilever movement not the condition of the diamond. Have it checked under a microscope as it might be that the diamond portion might be missing.
    in reply to: Beogram 1602 Tracking #50485
    Mark-sf
    My guess is that you are not really tracking at that weight. How did you measure 1.44g?
    in reply to: Beogram 8002 #50452
    Mark-sf
    You simply need a Moving Magnet Phono Preamp even though your cartridge is a moving iron type. I can recommend the Schiit Mani as a great value. There are also ones from Parasound, Pro-Ject, and Rega to name other quality units.
    Mark-sf
    If you don’t have any test equipment such as a multimeter and oscilloscope, you should have it looked at by a B&O service tech.
    Mark-sf
    From the diodes D200, 201, & 202 all three sources share the same circuit. So I would start by checking whether you have a signal on the anodes of D200 (Phono) and D201 (Tape). If not then I would trace back into their respective preamp circuits.
    in reply to: Beogram 4002 – Tonearm won’t move (another) #49911
    Mark-sf
    This is a common problem. You need to disassemble and clean the pivot point that the spring /arm is attached to as well as the up/down pivot that the solenoid plunger moves. Both of these get gummed up through non-use.
    in reply to: Beomaster 3000-2 input signal trace design #49889
    Mark-sf
    The signal path is described later in the service manual where you have gotten the schematic.
    in reply to: Beogram 4500 pickup does not move #49708
    Mark-sf
    Yes, the platter is the metal disk that the record supports and when shipped from the factory it is removed and in its own styrofoam piece. The stylus will not scratch it but if its loose it can destroy the cantilever that holds the stylus as well as the tonearm.
    To reattach the cord, download the service manual from either the Members area here or Beomanuals.com. You will see the pictures.
    in reply to: Beogram 4500 pickup does not move #49706
    Mark-sf
    I would not accept a shipment where the platter and cartridge were not removed. Padding can help it survive without the transport screws engaged but an in place platter will likely cause damage. You are correct that the cord is necessary for arm movement as it goes around two pallets that are driven from the arm motor.
    in reply to: Beomaster 3000-2 Won’t Power On #49407
    Mark-sf
    Have you checked the fuse as the load surge may have blown it?
    in reply to: Beomaster 3000-2 heavy distortion from right channel #49230
    Mark-sf
    The base of TR45 should be adjusted to 27.2 which should give you 26.6 at the collector of TR48. If the base of TR44 is 29.2V and you still are seeing a drop to 22V then the speaker output voltage before the output cap can’t be 28v. Note that the positive side has an 100 ohm resister to isolate it where the negative doesn’t. You need to further investigate after  TR47 for the current draw.
    in reply to: Beomaster 3000-2 heavy distortion from right channel #49228
    Mark-sf
    The 250-ohm trimmer and TR45 governs how much no load bias is applied to each base. It is mounted on the heat sink to sense temperature and also adjust the bias. It’s possible that transister is bad or the adjustment is too high. The circuit calls for a BC311 and since the bias is not separately adjustable for its BC310 mate its possible that your BC161 is a poor match. Sorry, but its been too many years since I worked on one of these.
    in reply to: Beomaster 3000-2 heavy distortion from right channel #49226
    Mark-sf
    Glad you got it sorted out as I was out of suggestions. First try the bias adjustment.
    in reply to: Beomaster 3000-2 heavy distortion from right channel #49222
    Mark-sf
    The diode is blocking current flow from TR48 collector to base of TR47 as it conducts in the other direction due to the higher voltage that is supposed to be on the base. Therefore, it cannot be bypassed with a jumper.
    You say there is 0 volts on the anode, is it the same at the collector leg of TR46 and the base leg of TR47? If you power down, what is the ohms reading to ground from the anode for each channel?
