Madskp
Forum Replies Created
Viewing 20 posts - 1,361 through 1,380 (of 1,579 total)
  • in reply to: Buying advice BLC NL/ML #45126
    Madskp
    GOLD Member
    n my configuration, Aux-In directly into the BLC NL/ML automatically turns on the PL speakers and sound starts playing from standby.  Also, if a CD was already playing on BS3000, the CD stops spinning and the BS3000 goes into stby, or if an AAC file was playing on BS5, it goes into stby. If my A6 was already joined into the BLC NL/ML soundstream, when sound starts playing on the PL speakers, it also plays on the A6.  But if the A6 was on stby, one must manually join it via the B&O app.
    Thanks for that thorough explanation of how this function works. I could see the benefit of that as it would probably be used in a combination with an existing Sonos system were it would be great if it could be sued without interaction with two apps, and it sound like that should be possible.
    Let me know if any additional questions.
    I don’t know if you can answer this as it doesn’t seem like there is a Beovision in your setup. But I wonder if it is possible to use a NL Beovision (in my case a Beoplay V1) joined/integrated permanently with the BLC so the sound is coming out of the TV setups speakers?
    Thanks in advance
    in reply to: Mx6000 and active speakers #45313
    Madskp
    GOLD Member
    Hello again. I don’t have much experience with the different B&O active speakers, but most of them should work with your TV. Im sure some other members here can give you some advice regarding that, but you might want to create a new topic with that as a question to get the right people to answer
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #43014
    Madskp
    GOLD Member
    Sounds like this is actually beginning to be a usefull setup. I havent tried the LP software since I got a BL3500, but I might give it a go again with that just to see If I have better results than I had when connected to the BC6.
    I will repport back
    in reply to: Beosound 2000 remote #45505
    Madskp
    GOLD Member
    Hello and welcome to Beoworld
    A very great system you got there. I had one myself for several years and was very satisfied with it.
    As for remote a BEO4 will also work. There are many different versions of this remote, but I think the only ones you should avoid are the hotel versions that are limited. You will know them by the lack of print on some of the keys.
    in reply to: Beoplay V1 network #45144
    Madskp
    GOLD Member
    Great to hear 🙂
    One question about the Google Home App and the V1, what can you do from the Google Home APP? Can you control some functions on the TV?
    in reply to: Mx6000 and active speakers #45311
    Madskp
    GOLD Member
    That should work fine. The powerlink connectors do have both left and right speaker channels in both connectors, as well as a 5V trigger signal and data signals for display,  for the Beolab Active speakers. But with an adapter to RCA with just te sound signals you should be just fine
    in reply to: Beoplay V1 network #45142
    Madskp
    GOLD Member
    A quick thought maybe try to change the IP settings to manual, and apply and afterwards change back to automatic. Other than that it  a reset to factory setting is also something to try, but you will loose all other settings
    in reply to: BL3500 and the MCL/PL connector #44565
    Madskp
    GOLD Member
    That’s a shame the timer didn’t work. The Almando Masterplay  is connected via masterlink though, could this Reddit chap be putting the voltage onto the masterlink pins rather than the DIN? Rob.
    No, according to the picture Matador got from him in this thread https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/10/#post-14503 it’s clearly the MCL connector he is using. That said it might be possible that the ML connector could be used for activating somehow
    in reply to: THE BEOWORLD SPRING 2023 PRIZE DRAW !!! #45220
    Madskp
    GOLD Member
    Congrats to the winners ??
    in reply to: THE BEOWORLD SPRING 2023 PRIZE DRAW !!! #45174
    Madskp
    GOLD Member
    10th Prize – an B&O Official Spark to Icon Book First out of the (rather heavy) bag this Spring sees a return to massage therapy for your poor postman and his aching back. Yes, it’s the literary leviathan that goes by the name of “Spark to Icon”. An official Bang & Olufsen publication charting the creation and rise of Bang & Olufsen from the Eliminator through to BeoLab 5 taking you on a multi-page journey through the history of the company we all know and love. A great read, and now something of a collectors piece. All yours if you win our 10th Prize… Mr H. Sørensen (square4) from Fredensborg, Denmark Jolly well done to you – and Happy Reading! Spring23_10th
    A great read indeed. Have it myself in the Danish version
    in reply to: THE BEOWORLD SPRING 2023 PRIZE DRAW !!! #45154
    Madskp
    GOLD Member
    Participants are awaiting in exitment ?
    in reply to: Beoplay V1 network #45139
    Madskp
    GOLD Member
    Sounds like the physical network connection is lost. Have you tried connecting something else, like a laptop to the network connector used for the TV just to rule out if its the TV or the network connection.
    regarding Google Home, have you been able to see it there before? My V1 cannot be found by the google Home App.
    in reply to: Buying advice BLC NL/ML #45121
    Madskp
    GOLD Member
    Thanks for all the input, its really great and usefull info.
    unfortnuatly the seller that I have been in touch with thinks its way to difficult to find the version info which I fully understand if he has no knowledge of IP adresses and network.
    So I think Ill wait for another on to come for sale
    Thanks again for all the info
    in reply to: Buying advice BLC NL/ML #45115
    Madskp
    GOLD Member
    All on my 3 BLC are on the same and latest software version which is: Version : 1.4.3.19864 Date : Dec 11 2015 I would assume that all boxes for sale would be on the same version and if not, I would recon that it would download the latest and update the box. At least I’m not getting any errors when I ask the units to check for software update; just get that I have the latest version already.
    thanks for info. It could be great if it could be verified if a not up to date BLC actually gets updated. Looking at a cheap unit right now but the seller has never used it him self but got it in a LOT of other things, so has no idea of software version
    in reply to: Buying advice BLC NL/ML #45113
    Madskp
    GOLD Member
    Hi Madskp, look here, please, that thread will help you: Beolink ML/NL version number? 1.4, 1.3 Kind regards, Rolf
    Thanks a lot, great info, might have overlooked that thread while searching for it.
    Does the AUX input have audiosense for automatic playback when a source is playing?
    Yes.
    The manual states that this function is for the powerlink connectors, but has the software been updated since the manual was written so it also works for audio distributed to ML and NL?
    in reply to: Buying advice BLC NL/ML #45111
    Madskp
    GOLD Member
    Ok so software is an important issue. What is the latest software version for the BLC?
    in reply to: BL3500 and the MCL/PL connector #44563
    Madskp
    GOLD Member
    Did a test with the BL3500. and the 1611 where I tried to inject 5V on pin 2 and 4 on the powerlink connector on the 1611 while the BL3500 was set to timer. No reaction regardless of option settings, but I noticed some lock up’s of the BL3500 once in a while where I had to power cycle the system. I thin Guy also experienced that in the 1611 converter thread.
    in reply to: BL3500 and the MCL/PL connector #44562
    Madskp
    GOLD Member
    Following with interest still!  It’s a shame that Timer selection didn’t make any difference as there was a glimmer of hope there!
    Yes I was just beginning to see something that might be what we were looking for in the first place. I thin I will try to test with the 1611 and the Powerlink  connector on that again in combination with the timer thing the newt time I have time to do a test
    in reply to: BL3500 not responding #44794
    Madskp
    GOLD Member
    Hi again Madskp I have also had the thought, that the BL3500 in my absence has been connected to a BEO-Amp via a masterlink cable, and that the BL3500 somehow has been disconnected to the remote control, so that the BL3500 does not respond to any command via the Beolink 1000? Could that be the reason to the fact that I can’t deactivate the speaker to be an inactive speaker with the command MENU, 0,4,PLAY to the state “MCL SEL” ore any other command MENU 00-01-02-03-06 ore -09, PLAY ?? Have a Nice day / Peter
    Hello again. I have a hard time imagining that the remote function should disappear because it was disconnected from another Masterlink product. You should always be able to do the basic functions like changing the options settings on a working unit.
    in reply to: BL3500 and the MCL/PL connector #44560
    Madskp
    GOLD Member
    New test. In this thread https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/18/#post-18025 user ebnrob mentioned that the manual for Almando Masterplay box (for use with the BL3500 via Masterlink) requires the timer function on the BL3500 to be activated for the Almando Masterplay to activate the BL3500.
    That made me think that it might be the missing link in activating the BL3500 with a 5V trigger signal. Also it makes sense as this is the only use case in a normal B&O MCL/ML system I can see where the master system activates the link room.
    With ML turned off (Menu+0+9+GO)  I tried activating the timer, and injected 5V on Pin 6 (data) and 7 (data ground), but without no luck. No response at all.
    Also tried injecting the 5 V on pin 1 and 7 as this was previously mentioned by the Reddit user who has this working. But again no response at all.
    Will try to think further about this and also think if there is a way to replicate it via Masterlink.
