Madskp
Forum Replies Created
Viewing 20 posts - 1,201 through 1,220 (of 1,582 total)
  • in reply to: Beosound 5 repair #47954
    Madskp
    GOLD Member
    Dont worry, its just a CR2032 coincell battery on the PCmotherboard to hold the clock. I have never seen leaks on these even on very old computers.
    in reply to: Beosound 5 repair #47952
    Madskp
    GOLD Member
    Hello and thanks for the input.
    I have measured the battery voltage to 3V, but I could try to put in a new one tomorrow just to rule that out.
    Could be interesting with another motherboard. The only one of the same type I can find cost more than another BM5/BS5
    in reply to: Beovision 11-46 #47941
    Madskp
    GOLD Member
    On the older BV10 you got to the Service Mode by pressing MENU then 0 0 GO within 3 seconds, so you could give that a try!
    I tried this on my Beoplay V1, but I can’t get that combination to work. It will just acces the menu, ignore the 0’s, and select the first menu item
    in reply to: Beovision 11-46 #47940
    Madskp
    GOLD Member
    According to the Service Manual, there’s a ‘Customer Service Menu’ but I don’t think it shows the ‘counters’. To access: Press the MENU button on the remote control, choose ‘Setup’, and press the Centre button. Press RED button and within 3 seconds press the Centre button.
    I can confirm this is how the customer service menu is accesed on a Beoplay V1 ( same platform). But I dont see counters anywhere, so it might only be via the servicetool as Guy mention.
    in reply to: Your latest addi(c)tion? #34908
    Madskp
    GOLD Member
    What are these power supplies intended for? Based on the Din plug my guess would be soldering irons?
    Madskp
    GOLD Member
    Am I correct to assume that Data male-to-male 2-pin minijack cable is a special B&O cable? I can’t seem to find any in my searches.
    It might be called trigger cable or mono cable. I think the most important is that it has two male 2 pin minjack 3.5mm conenctors
    Madskp
    GOLD Member
    Looks like two sets of identical cables.
    It is one cable, but in one end the individual cables just have some length to fit the space between connected components.  wired up for 2 whole sets of connections with both analog sound Left and Right (phono plugs with thin wires),  digital sound, coax (phono plug with thick wire),  composite video (phono plug with thick wire), S-video (S-Video plug), and data/control signal cable (2 pin minijack).
    My father got me two sets of these cables once when he was still working at B&O. I striped them down and rebuilt them to make cables for sound from PC to stereo, and video cable from computers to TV’s. Hell of a work to get those cables disassembled as the wires inside are twisted.
    Next question, Any idea what the DATA cable and Digital output cables might look like? I’ve been searching around online to find somewhere to order those without avail.
    The digital cables are with phono plugs as described above.
    The data cable is the one with 2 pin minijack. Looking at the picture though it sees like it is with a male connector in one end, but with at female connector in the other end. I think you will need a 2 pin minijack cable with male connectors in both ends to be able to connect it to the DVD players data connection.
    I think that’s in case your TV is connected to further TVs in link rooms. Only the analogue signals would be distributed, whereas digital available in the main room for better quality/surround.
    I agree that must be the explanation, and also it might be an easier way to explain i to the end user to just connect all cables.
    in reply to: Beosound Ouverture CD and Tape faulty #47768
    Madskp
    GOLD Member
    Ahh now I see what you mean. Found this thread with the video showing the cleaning https://forum.beoworld.org/forums/topic/who-wants-his-beosound-9000-to-live-forever/#post-11109
    in reply to: Beosound Ouverture CD and Tape faulty #47766
    Madskp
    GOLD Member
    It works for me too now that I see that the pictures are shown when clicking the links.
    Thanks ?
    in reply to: Beosound Ouverture CD and Tape faulty #47762
    Madskp
    GOLD Member
    Thanks for the input. I will defeneatly check all the buttons before I begin.
    Could be great if the CD reading issue is just about cleaning. If anyone has other input in that regard it is very welcome
    in reply to: BL3500 and the MCL/PL connector #44593
    Madskp
    GOLD Member
    I got a Beosound Ouverture and just did a quick test with powerlink from that to the Powerlink connector on the BL3500 MKII just to see if it was any different than the Powerlink connections from my MCL2AV that I had tried with previously.
    Tried with ML both on and off, but no reaction from the BL3500 at all.
    in reply to: Beosound Ouverture CD and Tape faulty #47764
    Madskp
    GOLD Member
    Laser eye to be cleaned/replaced. Common fault.
    Will try to clean it before I take anything apart to check if that helps.
    ape belt, common fault again. Full tutorial on the old forum, unfortunately with pictures missing. 2 hours work and quite an adventure but pretty sure that’s the fault (three Ouvertures, three time the problem).
    Thanks for the heads up about estimated time consumption 🙂
    I found the thread here https://archivedforum2.beoworld.org/forums/t/26380.aspx
    A google search for Beoworld Ouverture belt shows a thumbnail of one of the pictures in the search result.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42591
    Madskp
    GOLD Member
    Just aquired a BS Overture with some issues for tape and CD, but the ML part of it is working fine, so I thought I might do some testing with that and the BLC 1611 and BLC 1614 boxes.
    BS Overture A-opt. 2 – ML – 1611 – iphone
    All video commands will activate the video input on the BLC 1611. No audio commands will do anything. Guess that the audio commands are all assigned to the internal sources, and the AUX input. But a great way to get an extra aux input for a BS Overture.
    Same setup but with a BLC 1614 showed the same result, which also makes sense as there is a Audiomaster in the setup.
    Also tried a quick teest with one of the BLC 1610 boxes with an external 12V supply, and set to local 1611 and tried the 1-2-3 switch in all positions but with no response. Might be that I also need a -12V supply to make it work, or that particular box is defect, or that it will not work at all.
    Madskp
    GOLD Member
    I would suspect that 2 of the pins is Ground and probably internally connected.
    If you have a multimeter you could do some continuity testing to find out if any of them is connected.
    hope this could help you a little
    in reply to: Beovision 11 IR sensor location #47663
    Madskp
    GOLD Member
    Can you choose to control B&O TV’s in the Fire Cub settings?
    if not there might be a risk that it doesn’t use 455khz Ir signals as used in B&O remotes.
    in reply to: BL3500 and the MCL/PL connector #44592
    Madskp
    GOLD Member
    Just added some extra info regarding the early SW versions that I found in the old forums
    in reply to: Beovision 7-32 upgraded to Full HD #47635
    Madskp
    GOLD Member
    Any plans to make the stand work, or does it already?
    This solution https://neomesteren.dk/en/saadan-installeres-bm-7-adapteren should be able to do that, although limited to certain tv manufactures.
    in reply to: Beolab 3500 does not work in Masterlink #47570
    Madskp
    GOLD Member
    Btw could I ask you to check the software version of your BL3500?
    It is done by pressing menu, menu, 0, 0, GO
    I have another thread where I am trying to find out which software versions that has been available, so just to see if there are some version that I don’t know of.
    Thanks in advance
    in reply to: Beolab 3500 does not work in Masterlink #47569
    Madskp
    GOLD Member
    Good to hear that it is working now.
    Always nice with an easy fix.
    in reply to: Beolab 3500 does not work in Masterlink #47567
    Madskp
    GOLD Member
    I don’t see you mentioning if you can play music from the BS 9000 on the BL3500, but the subject suggest that you can’t?
    One thing to check for first if is Masterlink is enabled on the BL3500 by pressing
    Menu, menu, 0, 9, GO with a BEO4 remote. Then you should be able to choose ML on or off with up and down arrows.
    If it is on you can also check the ML status by pressing Menu, menu, 0, 2, GO
    This will either show: NO ML, ML OK or an error 1-4.
    Let me know what you findings are
