Madskp
Forum Replies Created
Viewing 20 posts - 1,141 through 1,160 (of 1,530 total)
  • in reply to: Beolab 3500 does not work in Masterlink #47579
    Madskp
    GOLD Member
    Great to hear that you have solved it 🙂
    in reply to: Beosound 5 repair #47956
    Madskp
    GOLD Member
    Continuing I noticed that the CPU cooler gets very hot. I have measure the CPU Vcore voltage which is around 1.0V. This doesn’t sound critical to me, but I don’t know what the correct voltage should be.
    Also measure random voltages around the motherboard, and nothing looks suspicious.
    Also did some checking for short circiuted caps, but that is not the case either.
    I am a little interested to see if I can make the BS5 screen show some life. Does anyone know if it should be possible to make i show the picture from an other computer, provided power is supplied to the BS5 screen?
    Or should it have some signal via the USB cable?
    in reply to: Beolab 3500 does not work in Masterlink #47575
    Madskp
    GOLD Member
    For masterlink to work, must pin 3 and 12 be connected to the masterlink plug?
    Not quite sure I understand what you mean.
    Pin 3 and 12 should be used in the masterlink plug end, but in the Rj45 end they can be spliced toghether.
    You can see the pinout in the Beolink Handbook 1.9 at page 98 https://beoworld.org/beolink-handbook-version-1-9/
    in reply to: Beolab 3500 does not work in Masterlink #47572
    Madskp
    GOLD Member
    The CAT7 wire should have a shield that according to the Beolink Handbook should be connected to the three solid blank wires in the ML cable. This is the 9th wire.
    hope this will help you
    in reply to: Beocenter 9500 / Beolab 3500 connection #45681
    Madskp
    GOLD Member
    When you have both the BC9500 and the BL3500 in the same room both units will recieve the remote signals.
    To avoid this you can temporarely set the BL3500 to option 4. Then you will have to use the Link command before any command you send to it.
    The BC9500 will not react to theese commands.
    in reply to: Beocenter 9500 / Beolab 3500 connection #45679
    Madskp
    GOLD Member
    Another thing that comes to mind that might not be a thing, but wont hurt to do is to check if Masterlink (ML) is set to off on the BL3500 as that is not needed in this setup.
    with the remote press
    Menu + 0 + 0 + Play ( If your BL1000 doesn’t have menu use shift + text).
    If the display show ML ON use the arrows to change it to ML OFF
    in reply to: Beocenter 9500 / Beolab 3500 connection #45678
    Madskp
    GOLD Member
    Hi again
    Regarding option settings, try that first.
    Reading your first post it sounds like the BL3500 is in another room than the BC9500, so opt. 6 would be right.
    Beolink 1000: Link + 6 + Store, the BL3500 should show option 6 in the display
    Regarding wirering the first thing I would check is if you are using the speaker 2 sockets for the MCL plugs, and that you have the correct left/right polarity (I do not suspect that as you can control the music)
    in reply to: Beosound 5 repair #47955
    Madskp
    GOLD Member
    Hello, you said, reset the CMOS, did you check whether the battery has the correct 3V voltage? I had one where I thought as well the mainboard might be dead but it was just an old battery
    I replaced the battery today, but still no luck.
    I also meassured that all voltages on the ATX connecter is within specification, and they are.
    Next I replaced 2 1000uf caps next to the ATX connector as one of the looked bulgy. Still no sign of life.
    in reply to: Beosound 5 repair #47954
    Madskp
    GOLD Member
    Dont worry, its just a CR2032 coincell battery on the PCmotherboard to hold the clock. I have never seen leaks on these even on very old computers.
    in reply to: Beosound 5 repair #47952
    Madskp
    GOLD Member
    Hello and thanks for the input.
    I have measured the battery voltage to 3V, but I could try to put in a new one tomorrow just to rule that out.
    Could be interesting with another motherboard. The only one of the same type I can find cost more than another BM5/BS5
    in reply to: Beovision 11-46 #47941
    Madskp
    GOLD Member
    On the older BV10 you got to the Service Mode by pressing MENU then 0 0 GO within 3 seconds, so you could give that a try!
    I tried this on my Beoplay V1, but I can’t get that combination to work. It will just acces the menu, ignore the 0’s, and select the first menu item
    in reply to: Beovision 11-46 #47940
    Madskp
    GOLD Member
    According to the Service Manual, there’s a ‘Customer Service Menu’ but I don’t think it shows the ‘counters’. To access: Press the MENU button on the remote control, choose ‘Setup’, and press the Centre button. Press RED button and within 3 seconds press the Centre button.
    I can confirm this is how the customer service menu is accesed on a Beoplay V1 ( same platform). But I dont see counters anywhere, so it might only be via the servicetool as Guy mention.
    in reply to: Your latest addi(c)tion? #34908
    Madskp
    GOLD Member
    What are these power supplies intended for? Based on the Din plug my guess would be soldering irons?
    Madskp
    GOLD Member
    Am I correct to assume that Data male-to-male 2-pin minijack cable is a special B&O cable? I can’t seem to find any in my searches.
    It might be called trigger cable or mono cable. I think the most important is that it has two male 2 pin minjack 3.5mm conenctors
    Madskp
    GOLD Member
    Looks like two sets of identical cables.
    It is one cable, but in one end the individual cables just have some length to fit the space between connected components.  wired up for 2 whole sets of connections with both analog sound Left and Right (phono plugs with thin wires),  digital sound, coax (phono plug with thick wire),  composite video (phono plug with thick wire), S-video (S-Video plug), and data/control signal cable (2 pin minijack).
    My father got me two sets of these cables once when he was still working at B&O. I striped them down and rebuilt them to make cables for sound from PC to stereo, and video cable from computers to TV’s. Hell of a work to get those cables disassembled as the wires inside are twisted.
    Next question, Any idea what the DATA cable and Digital output cables might look like? I’ve been searching around online to find somewhere to order those without avail.
    The digital cables are with phono plugs as described above.
    The data cable is the one with 2 pin minijack. Looking at the picture though it sees like it is with a male connector in one end, but with at female connector in the other end. I think you will need a 2 pin minijack cable with male connectors in both ends to be able to connect it to the DVD players data connection.
    I think that’s in case your TV is connected to further TVs in link rooms. Only the analogue signals would be distributed, whereas digital available in the main room for better quality/surround.
    I agree that must be the explanation, and also it might be an easier way to explain i to the end user to just connect all cables.
    in reply to: Beosound Ouverture CD and Tape faulty #47768
    Madskp
    GOLD Member
    Ahh now I see what you mean. Found this thread with the video showing the cleaning https://forum.beoworld.org/forums/topic/who-wants-his-beosound-9000-to-live-forever/#post-11109
    in reply to: Beosound Ouverture CD and Tape faulty #47766
    Madskp
    GOLD Member
    It works for me too now that I see that the pictures are shown when clicking the links.
    Thanks ?
    in reply to: Beosound Ouverture CD and Tape faulty #47762
    Madskp
    GOLD Member
    Thanks for the input. I will defeneatly check all the buttons before I begin.
    Could be great if the CD reading issue is just about cleaning. If anyone has other input in that regard it is very welcome
    in reply to: BL3500 and the MCL/PL connector #44593
    Madskp
    GOLD Member
    I got a Beosound Ouverture and just did a quick test with powerlink from that to the Powerlink connector on the BL3500 MKII just to see if it was any different than the Powerlink connections from my MCL2AV that I had tried with previously.
    Tried with ML both on and off, but no reaction from the BL3500 at all.
    in reply to: Beosound Ouverture CD and Tape faulty #47764
    Madskp
    GOLD Member
    Laser eye to be cleaned/replaced. Common fault.
    Will try to clean it before I take anything apart to check if that helps.
    ape belt, common fault again. Full tutorial on the old forum, unfortunately with pictures missing. 2 hours work and quite an adventure but pretty sure that’s the fault (three Ouvertures, three time the problem).
    Thanks for the heads up about estimated time consumption 🙂
    I found the thread here https://archivedforum2.beoworld.org/forums/t/26380.aspx
    A google search for Beoworld Ouverture belt shows a thumbnail of one of the pictures in the search result.
