Guy
Forum Replies Created
Viewing 20 posts - 121 through 140 (of 1,973 total)
  • in reply to: Beocenter 8000 remote control #72790
    Guy
    Hi David and welcome to Beoworld!
    Can I first just check that this is the Beocenter you are referring to:  https://beoworld.org/beocenter-8000/
    If so, then either BeoLink 1000 (BL1000) or Beo4 should be fine to operate it.  I wouldn’t bother with the aftermarket versions, just find a decent working BL1000 or Beo4 on eBay for £30 to £50.
    Come back and ask if you have any further questions once you get hold of a suitable remote.
    Guy
    Multicare have now added the BM4401 service manual to Beoworld, and it can be found at the foot of this page:  https://beoworld.org/beomaster-4401/
    in reply to: Beocenter 2 remote control issues #72696
    Guy
    Second post here, second para states that BC2 goes to A.Opt 0 if no speakers are connected – and post was made by quite an experienced poster/founder member.
    https://archivedforum.beoworld.org/forums/t/13784.aspx
    And a post here says it goes to A.OPT 6:
    https://archivedforum2.beoworld.org/forums/p/12695/110803.aspx#110803
    And here:
    https://archivedforum2.beoworld.org/forums/p/49635/349244.aspx#349244
    in reply to: Beovision 10-32 Stuck on Setup #72560
    Guy
    Can you get into the ‘Options’ menu and turn off the Tuners?  Both analogue and DVB-HD if there.
    Alternatively, try going to the Service menu* and find the option ‘RESET TO FACTORY SETTINGS’.  Then try setup again.
    * The Service Menu must be activated while the TV SETUP menu is displayed. From
    this initial state, the Service Menu is activated in the following way:  Beo4: the Service Menu is activated by pressing 0 0 GO within 3 s.
    in reply to: Beoplay M3 line in sound skipping #72530
    Guy
    After disabling my mesh network and just going with one router everything now works fine.
    Good to hear – I hope it keeps working!
    I meant to say, it could also be worth checking that your M3 is at the latest SW level – it should be at 6.5.57689.212515568 which was released on 22 October 2025.  Full details of this and earlier versions are listed in the release notes here:  https://update.bang-olufsen.com/products/b4ebddbebc6542ad87534e36f49d6a9a
    Guy
    I found a copy of the service manual on the Kose trading site (hopefully attached below), but it should be on Beoworld also – I will check with Multicare.
    in reply to: Beoplay M3 line in sound skipping #72505
    Guy
    Hi Peter and welcome to Beoworld!
    Have you tried changing the Line In detection level to ‘disabled’?  It’s the setting above the delay setting.
    in reply to: Beocenter 2300 Mute Transistor defekt #72359
    Guy
    You have asked this question a few times on the forum so I  thought I would have a look for the answer!
    I could see from the circuit diagram in the service manual (available on Beoworld to Silver/Gold members) that it appears to be mounted on a separate board to the main PSU/Pre-Amp PCB (PCB2).  I couldn’t find a diagram, so I did a search with Google AI and received this answer:
    Transistor Details: The mute transistor designated as TR1 in the Beocenter 2300 is a 2SC4213 SMD transistor.
    Part Number: The specific part number for the TR1 mute transistor is 2SC4213.
    Type: It is an SMD (surface-mounted device) transistor.
    Location: The P-L MUTE circuitry uses two identical 2SC4213 SMD transistors (TR1 and TR2) and two 8.2K ohm resistors, which are mounted on a small, vertical 4-pin sub-board on the main PCB.
    Function: A failure in one or both of these transistors is a known cause for audio issues, such as a popping sound when changing sources or one channel being dead, as they control the power-link (P-L) muting function.
    Replacement: Replacements for this specific transistor are available from various online electronics suppliers.
    If you are experiencing a mute-related problem, it is recommended to test both TR1 and TR2 and their associated components, as either or both can be the source of the fault.
    I am guessing slightly but I think the small vertical PCB may well be the one that you can see the edge of (between the PL sockets and the 3 capacitors) in the PCB photo at this link:  https://kosetrading.com/product/bang-olufsen-bo-beocenter-2300-dab-radio-type-7400-power-supply-part-pcb-2/?srsltid=AfmBOoqX2I4oeoPjxBq0Qiioegkc5mxQQZ2tYzAHYY9v579QJKmKr1Mo
    in reply to: BeoVision 6-26, Beoremote One IR and Apple TV #72274
    Guy
    I guess, I’d have to find a descreet place for an IR-Eye…
    The Beo4 remotes are so powerful that the IR-eye can probably sit hidden behind another object and still work perfectly.  The IR signal will most likely bounce off the walls to reach the sensor.
    EDIT:  And on the Beo4 with navi button you can adjust the IR power as follows:
    Access the service menu by pressing Stby (red dot) + LIST at the same time, and then MENU + (joystick) at the same time. Press ^ several times until the display reads IRPWR: X. Again, 1 is the lowest and 7 is the max IR signal strength (default is 4)
    in reply to: HDMI to DVI and Sound #72208
    Guy
    Hi Nils and welcome to Beoworld!
    I posted some details back here that may help:  https://forum.beoworld.org/forums/topic/hdmi-connection-for-beovision-7-mk1/#post-33294
    And B&O even have some official advice here (but they don’t propose a solution  for potential HDCP problems): https://support.bang-olufsen.com/hc/en-us/articles/14630866152081-How-do-I-connect-an-HDMI-device-to-a-Bang-Olufsen-TV-without-HDMI-input
    You may not experience HDCP problems if your BV6-23 is HD-R.
    in reply to: Broken top glass – Beocenter 9500 #72169
    Guy
    I am not sure whether it helps, but be aware that you can also use a panel from BC8000, 8500, 9000, 9300.  However, you need to be aware that the control panel markings are different:
    Beocenter 9000 panels (and those for the 9300 and 9500) have a “TIMER” indication on the control panel glass.
    Beocenter 8000 panels (and those for the 8500) do not have this “TIMER” marking.
    You may be best looking for a complete ‘spares or repair’ Beocenter – then you will have lots of other spares for future problems!
    (I used Google AI to get this summary – but am 99% sure that it is correct based upon my previous research!)
    in reply to: Beolink 5000 repair #72168
    Guy
    I am not sure why you can’t upload photos normally – I’ll send a message to Multicare.
    I just dug out an old BL5000 keyboard (actually one that Beoworld member Leslie sent me many years ago) and prised out the metal circle with a guitar plectrum.  It came out quite easily, but looks like it was originally  glued in place:
    in reply to: Beolink 5000 repair #72160
    Guy
    Just to add to the above, like MartinM I went for tantalum bead throughout – see my order below:
    in reply to: Beolink 5000 repair #72158
    Guy
    For recap of the IR PCB, there is a guide from Leslie Nelwan at the Beoworld archive showing which caps there needs to be replaced.
    https://archivedforum2.beoworld.org/forums/p/9016/89901.aspx
    Look a little more than half way down.
    When I replaced the capacitors in one of my BL5000s several years ago I found Leslie’s post very useful, especially for the capacitor values.  I also made use of the photos from a 2010 post by ‘MartinM’ here:  https://archivedforum.beoworld.org/forums/t/35123.aspx
    The photos are no longer attached, but I kept a copy – see below:
    in reply to: Beovision 10 Masterlink issue #72126
    Guy
    Have you still got the original Beo4 (not the navi joystick version) and is there any difference in the behaviour of your system when using that?
    in reply to: The Beoworld December 2025 Prize Draw #72075
    Guy
    I must have been busy with something else because I totally missed this draw – many apologies for not being there in support!
    Anyway, many congratulations to all the winners;  I am very envious of the Beosound Stage (well done @miniac) as it’s one of the products that could tempt me away from the Beo4 and onto a newer remote or two.
    And ‘Merry Christmas’ to all Beoworld Members – thank you for all your support and contributions over the past year!  🌲🧑‍🎄🎅🎁❄️🎄
    in reply to: New BeoCom 1 purchase finding the base #72074
    Guy
    Hi Guy, I am having similar problems with my BeoCom 1 6000 phone. I have three of them and one lost base connection.
    Thought it could be battery but still can’t connect with it. Tried all the suggestions I find on line and no solution. Not sure when B&O stopped
    selling phones but would you know of BeoCom IT or help individual in New York City that could help? Thank you!
    Early European BC6000s often developed an rf transceiver problem, where the only fix was replacement of the main PCB.  I am not sure whether this problem extended to the US models.
    If you have tried all the reset procedures mentioned earlier in the thread (including perhaps resetting the base unit) then it could be worth trying to find a B&O specialist who can look at it from a SW perspective, although it’s possibly hardware related.  I don’t know of any NY specialists, but maybe an older established B&O dealer (if you can find one) could still have some Beocom test equipment in store.  However, I am not sure that a fix would be cost effective, so you may be better off looking for a second hand replacement, making sure that it is a compatible US model by referring to the model and type numbers as mentioned in the table I posted earlier in the thread.
    I hope that helps!
    in reply to: Essence MK1 main unit #72066
    Guy
    Ah, I should have checked – you registered nearly 4 years ago, and may well have been on the old forum too!
    Here’s another device that will carry out the same function:  https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/
    Or you could look for a second-hand B&O Playmaker – they have auto-sense on the aux input:  https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND_SYSTEMS/PLAYMAKER/UG_Playmaker_EU_US_current.pdf
    in reply to: Essence MK1 main unit #72064
    Guy
    Hi and welcome to Beoworld!
    The answer is ‘yes’ – the RCA line-in has auto-sense which will trigger the PL and Beolabs.  You may well have to set up autosense (sensitivity etc) in the menu, accessible from most browsers or the B&O app.  You will also have to set up whether the output should be fixed volume or controllable (via remote or B&O app).
    in reply to: Beocenter 9500/8500 Tape Unit #71962
    Guy
    @morgan_mad
    I just wanted to let you know that I tidied up the forum to reflect your change of username and have deleted the other thread with my erroneous response.
    As I said in the deleted thread, your best bet may be to find a ‘spares and repair’ BC9500/8500 and move the parts across.
