Guy
Forum Replies Created
Viewing 20 posts - 241 through 260 (of 1,973 total)
  • in reply to: Beosound 1 cd scraping #68740
    Guy
    I had had this problem – have a look at my post (and the rest of the thread) here:  https://forum.beoworld.org/forums/topic/beosound-1-faulty-cd-player/#post-56558
    If you look at the later posts, you can see that the rubber suspension mounts  actually have a function in holding the CD unit together.  The rubber mounts may have been damaged in the past if the laser has been replaced.  If you look at the last post in the thread you will see that I added a couple of small screws to hold my unit together and prevent rubbing.
    Your best bet is to carefully dismantle and try to work out the specific problem in your case.
    Not sure about the workbench hence will check – I think that the threads were merged into the specific product threads.
    in reply to: Access OPTIONS on Beomaster 7000 #68737
    Guy
    What sort of TV do you have?  And what is the connection between TV and BM7000?  Check that the cables are all fully inserted.
    Assuming that TV and BM7000 are correctly connected, and the Pentas are connected to the TV, then the TV should be in V.OPT 2 and the BM7000 in A.OPT 0.
    Using the BL1000, in the main room, with the system at stand-by:
    Press SOUND then 0 then STORE (to put the BM7000 in A.OPT 0)
    Press PICTURE then 0 then STORE (to put the TV in V.OPT 2)   EDIT:  See below: Should read PICTURE 2 STORE
    in reply to: Beovision 7 40 blank screen help please #68731
    Guy
    Great result!  Thanks for letting us know 😀
    in reply to: Beocenter 2300 #68240
    Guy
    Does it start to spin and then stop – is there any rotation?
    It could well be a problem with capacitors.
    Have a look at the following threads, according to the type of CD module fitted:
    (Older type, with curved laser path)  https://forum.beoworld.org/forums/topic/beocenter-2300-cdm-4-cd-repair/
    (Newer type, with straight laser path)  https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/#post-50372
    in reply to: Search issue in forum 2012-2022 #68121
    Guy
    Are there are problem with the forum?
    Not sure.  But as a temporary workaround, try using google and after the search term enter “site:https://archivedforum2.beoworld.org/forums/”  without the quotation marks.
    eg: beogram 6000 site:https://archivedforum2.beoworld.org/forums/
    in reply to: oneRemote backup battery? #68063
    Guy
    I have taken mine to pieces (to repair a loose connection) and there is definitely no backup battery, so you will have to set it up again according to the instructions.
    EDIT:  Attached is a pdf of the instructions in case you don’t have them.
    in reply to: Your latest addi(c)tion? #68003
    Guy
    Sometimes it’s hard to resist when a B&O LOT with lot of black boxes show up 😀
    I guess this was from a B&O repair shop as there is several microcomputerboards, presumably for Beolink Active, 7 new in Box IR eyes, 2 used IR eyes, 1 Beolink Converter 1611, 1 AV 9000 Audio kit 1610, 2 Beolink Active 1636 SW1.6, 5 Beolink Video MKII SW 1.5, an outdoor mounting box for IR eyes, 5 Masterlink Distributors and some Masterlink cable.
    Next up testing if everything works
    A great find, especially with the later SW versions on many of the boxes.  I haven’t seen a 4-way ML distr box before.
    in reply to: Beomaster 6500 White Plugs #67291
    Guy
    The socket enables you to ‘loop out’ to a device such as a graphic equaliser (remember them?) or similar.  Same is fitted on BC9500.
    With the plug in place it connects DIN pins 1 and 4 (output) to 3 and 5 (input) respectively, as you may be able to see in my blurry photo attached:
    in reply to: Beo4 Remote wonkiness with Beovision Avant US #67131
    Guy
    Hi and welcome to Beoworld Dan – hopefully we can help.
    To be honest it sounds to me like the fault may be with the TV.  The fact that you can see the remote transmitting IR suggests that it is sending the signals but that the TV is not responding.
    I have read that I may need to change the mode on the remote.   If I hit standby+list I get only 3 options: Add? Option? Remove?  All of the documentation seems to say there is supposed to be a Config? option as well.
    There was no ‘config’ option on the early Beo4 (the version with the AV button).  But config would not solve the problem – it just provides an easy way to set up the remote for various different AV environments.
    Hitting go in Option gives me: V. Opt, A. Opt, and L. Opt.  I can’t hit go on any of these, so I have tried 0, 1, 2, 3, etc as different control inputs after selecting V. Opt.
    None of these change anything.
    The V.OPT setting allows you to set up your TV to react to IR commands.  V.OPT 0 will stop it responding to IR, V.OPT 1 will just see it respond to video commands, and V.OPT 2 will see it respond to both video and audio commands.  The correct setting for you is V.OPT 1 – this should be achieved by simply pressing ‘1’ when V.OPT is shown on the Beo4 display (there is no need for the GO button here).
    In your situation I would want to test your remote with another (known to be working) B&O device (pref TV) and/or test your TV with a known-working remote.
    Any of the Beo4 versions should work with your Avant, but a newer version will be no good if it’s the TV that is faulty!
    in reply to: Beogram 7000 with RIAA #66795
    Guy
    You may not be able to find a 7-pin DIN fly lead with colours that correspond to yours.  If you are not happy to work out the connections/colours as suggested then it could be worth taking the Beogram to a repair shop – they should be able to source a suitable cable and work out the correct connections.
    in reply to: Masterlink to Powerlink #66782
    Guy
    I just thought of an alternative solution using the existing ML cable:
    Connect ML cable to BS9000 as normal.  Put BS9000 in A.OPT 0 (automatic if no PL connection).
    At the Almondo end of the ML cable, connect a BeoLink Active and IR sensor.
    Connect BeoLink Active’s PL output to the Almondo PL input.
    (This should then enable full control of the BS9000 as if the Beolink Active is in a link room)
    in reply to: Masterlink to Powerlink #66780
    Guy
    You could try cutting the ML plugs off and soldering 8-PIN DIN connectors, choosing suitable wires so that pins 3, 5 and 6 are shielded, according to the following pin diagram:
    (Click to open larger)
    8-pin PL plugs available here: https://soundsheavenly.com/powerlink-8-pin-din-connection/139-2307-powerlink-compatible-black-8-pin-din-plugs-pack-of-5-plugs.html#/18-colour-black
    EDIT:  If you don’t fancy soldering , you could simply buy a fully wired PL to PL lead, cut in the middle and then use a suitable terminal block connector (or ML junction box) to connect appropriate cables to the ML cable.
    in reply to: Beogram 7000 with RIAA #66756
    Guy
    You may wish to search for  7-pin DIN ‘fly lead’ – this term is often used when one end is bare wire.
    I am not sure of the quality, but something like this comes up on UK eBay with that search:  https://www.ebay.co.uk/itm/124857640859
    in reply to: MCL2AV Tone Control #66694
    Guy
    Update:  I just set up an MCL2AV (Type 2032, SW2.3) with just power supply and IR transceiver connected (no other input or output as these are not required for a simple test).
    With BL5000 (set to two-way control for both AUDIO and VIDEO), full two-way IR volume control is possible (i.e the BL5000 display shows the numerical value of the volume, changing as the button is pressed).  Also, pressing STATUS will show the selected source A.TAPE or CD depending on whether SHIFT RADIO 6 or 7 has been selected.
    Pressing SOUND toggles between just VOLUME and LOUNDNESS, the latter of which can be turned ON/OFF using the up/down arrows with the display showing new status.  (There is no display, nor control, of BALANCE, BASS or TREBLE)
    EDIT:  So it would seem that 2-way control is possible – but maybe only with my MCL2AV Type No and SW version, plus the fact that it was not connected to a full masterlink system.  Also, when you initially used the BL1000 and pressed SOUND twice followed by arrows, you were possibly turning the LOUDNESS on and off, hence noticing the slight change of tone.
    EDIT2:  And surprisingly most of my BL5000’s display has started working again – must be the warm weather:
    in reply to: MCL2AV Tone Control #66692
    Guy
    At the moment I am using a local non-beo source (radio+shift+7) . This doesn’t allow two-way communication via Bl5000.
    As far as I can remember it worked with a non-B&O source.
    When I first set it up about 15 years ago my only two-way remote was a MCP5500, so perhaps I mis-remembered regarding the BL5000 – not totally sure now!
    Sorry to ask, but are you sure that the BL5000 is in 2-way mode for audio, and that the two-way IR actually works (BL5000 capacitors can fail causing two-way to stop working).
    If I have time in the coming days I will try to dig out an MCL2AV and double check with my BL5000.
    in reply to: MCL2AV Tone Control #66635
    Guy
    Is it possible to do local tone control adjustments while playing local sources?
    I just checked the service manual and had a look at the MCL2AV circuit diagrams – I can’t see any tone control circuitry so I suspect that the answer is no.
    In the past I used a MCL2AV and Passive stand-alone as a computer amplifier and controlled it with both MCP5500 and BL5000.  The remotes worked with two way IR but unfortunately I don’t remember testing the tone controls.
    in reply to: Beo4 Contrast setting #66634
    Guy
    Assuming that the Beo4 has a GO button in the middle (i.e not the NAVI version with the joystick)
    Press Power (Red dot) and LIST together.
    Press MENU and GO together.
    Press LIST until CONT: XX shows on the screen, where XX is a number in the range 00 (lowest) to 15 (highest)
    Press two digits of new contrast required (start low, eg 0 4)
    Press GO to confirm
    Press Power (red dot) to exit menu.
    in reply to: How to plug an earset 1 home to my Beocom 6000 #66539
    Guy
    Photos as promised:
    Beocom 6000s Mk2:
    The one on the left is an upgraded BC6000 Mk1, whereas the one on the right is a Mk2 clearly showing the Earset 1 connection:
    Beocom 6000 Mk1
    The two dots on top are merely covers for the IR transmitter/receivers – there is no earset socket:
    You can pick up BC6000 Mk2s quite cheaply nowadays, and it is a worthy upgrade from the Mk1, with a better menu structure and a more reliable RF chip.  Just make sure that the one you are buying definitely has the earset socket as shown.
    EDIT:  And I am not sure where you live, but one advantage of the Mk2 is that (unlike the Mk1) you can change the language of the menu.  You should therefore be able to buy and use one from another country.
    in reply to: How to plug an earset 1 home to my Beocom 6000 #66521
    Guy
    Only the Mark 2 Beocom 6000 (with the INT button to the left of the circular wheel control) has a headset connection, and there is no need to remove any plugs.
    (Some Mk2s are modified Mk1s and do not have the headset socket because it was not part of the modification)
    I will attach photos to explain when I get home tomorrow.
    Guy
    Hi Andrew and welcome to Beoworld!
    I think that your best bet is to find the user manuals for the TV and work through the first time setup.  I can’t read the label in the picture, hence can;t be sure what version your TV is – there were several mks (at least 1 to 5).  If it’s a 7-32 then this B&O link tells you how to work out the version and has some of the manuals:  https://support.bang-olufsen.com/hc/en-us/articles/360041950211-Beovision-7-32
    Be aware that the TV may not be fitted with a tuner that is compatible with modern TV transmissions in your country of use.  (eg here in UK TVs need a digital DVB-T or DVB-T2 tuner, and these may not be fitted in early BV7s)
    Your first photo shows the power lead connected at the top – the same as the circled power connection in my photo earlier in the thread.
    I think the white cable is connected to the powerlink socket, which would normally supply a Beolab speaker that would sit on the bracket in your second photo (but I am not sure why the cable appears to change colour to black!
    Have a good look in the documentation and ask back here if anything is unclear.
