Tignum
Forum Replies Created
Viewing 20 posts - 461 through 480 (of 527 total)
  • in reply to: Changing cloth on BeoLab 8000 > instructions? #39500
    Tignum
    GOLD Member
    Hi KolfMAKER, I posted some pictures a while ago when I fixed my BeoLab 8000s (and 6000s): https://archivedforum2.beoworld.org/forums/p/189/332850.aspx#332850. Unfortunately the photographs have gone (as Guy said already) but I still had them. I did use fabric from akustikstoff.com that to me is very nice material. In my view the limited stretch works much better than panty material that seems to have infinite stretch, but also can get too thin when stretched too much. I used akustikstoff’s standard black (10) fabric.
    I decided to use double sided tape (HPX ultra mount tape) that is thin and very sticky to both the plastic of the fret and the cloth.
    My frames were quite bad with the top flap and some of the clips on the side loose. The vertical long strips of tape on the inside of the frames I positioned deeper to make sure the working of the clips is not affected.
    The flap in the top is the most fiddly part. But with a bit of patience the result will be much better than before. Hope this helps, good luck!
    20210228_19375620210228_19480720210228_19280920210228_19272320210228_19261920210228_19255420210228_19183620210228_19161820210228_19113920210228_19113320210228_19081220210228_19075820210228_19060020210228_190247
    in reply to: Intermittent buzzing on Overture #39324
    Tignum
    GOLD Member
    Hello Matt,
    Not so easy to judge from your description I think. You write that it has been reconditioned, would it not be an idea to record the noise (maybe even film the Ouverture when it happens) and ask the seller/reconditioner? I would say that if it was sold as reconditioned to you, it should be working flawlessly, and the seller should feel responsible for it.
    Regards, Johan
    in reply to: THE BEOWORLD AUTUMN 2022 PRIZE DRAW !! #39422
    Tignum
    GOLD Member
    The Bot comments are so good! 🙂
    Sorry I could not join the event. And what a good prizes again. Congratulations to all prize winners!
    Thanks Beoworld team. I am really happy to see that the forum is up and running again.
    Johan
    in reply to: Screws for Beolab 6000 base #39297
    Tignum
    GOLD Member
    Hi Matt, welcome!
    The service manual says 4×16 (for pos. 15):
    beolab6000
    and that is correct: M4 x 16mm, with a 7mm head.
    20220926_11362720220926_11364920220926_113612
    I need to clean my caliper :-).
    Good luck! Johan
    in reply to: Your latest addi(c)tion? #34884
    Tignum
    GOLD Member
    That BeoMaster 5000 with the rosewood sides is ABSOLUTELY GORGEOUS. Lucky you!
    in reply to: What are you listening to…..right now. #33171
    Tignum
    GOLD Member
    I enjoyed listening to (and watching) the
    https---hypebeast.com-image-2020-03-beastie-boys-story-spike-lee-documentary-imax-apple-tv-trailer-00
    on AppleTV+
    in reply to: BS 4 -> BV 6-26 -> BL 4000’s #39081
    Tignum
    GOLD Member
    Hi stotty1111, are you positive that the TV and the BeoSound are in the right option setting?
    options
    in reply to: Since 2008 #38882
    Tignum
    GOLD Member
    Looks amazing against the natural stone wall. Living Colour must sound great! Nice to see you play some decent rock ? :-). Happy listening Evan!
    in reply to: Beolab 8000 rubber feet #38893
    Tignum
    GOLD Member
    Hi again, here they can be bought: https://www.idav.nl/rubberen-voetjes-beolab-8000.html?id=268961159. Not cheap – 50 euros for 8.
    in reply to: Beolab 8000 rubber feet #38890
    Tignum
    GOLD Member
    Hello styppen, they are called
    Naamloos
    and are indeed adjustable (I took one from my 8000):
    20220907_075718
    But if you cannot find the real ones, maybe you can find some short, flathead M5 bolts (called thumbscrews) and stick a rubber protector on it (one like this:)
    20220907_075746
    Then you will still have the possibility to adjust the stance.
    Good luck! Johan
    in reply to: Since 2008 #38877
    Tignum
    GOLD Member
    VERY David Lewis. I share the BeoLab 5 dream with you. Hopefully one day my budget and BeoLab 5 prices will match too :-).
    Enjoy them! (time to warn the neighbours – I believe the calibration can give quite a bit of rumble?)
    Johan
    in reply to: Beovision 7 32, no sound. Help! #38613
    Tignum
    GOLD Member
    Hi LesleyJJ, welcome!
    Are you positive the speaker is in working order? Have you heard it before?
    It needs to be connected with a mains cord (to power the built in amplifiers) and a PowerLink cable (round DIN plugs with up to 8 pins) to provide the audio signals and the command to power up the speaker when you switch on the TV.
    Often the mains cord comes directly from your wall socket into the BeoLab 7-1, and from the speaker a mains cord (with a fe-male and a male plug) is used to provide power to the TV. It could be that your speaker gets no power? The photograph is not so clear. Check page 6 of the manual found here: https://support.bang-olufsen.com/hc/en-us/articles/360042003031-Beolab-7-1, and page 30 of the reference book of the BV7-32 found here: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_7-32/beovision_7_32_mkii_iii_iv_v_7_40_mki_ii_reference_book_english.pdf
    The PowerLink cable has to be plugged into one of the two sockets on the TV that are called: PowerLink Centre. The inside of the connections covers contain stickers with the names of all the sockets.
    In the menu of the TV (options/sound) you will have to select BeoLab 7-1 at ‘CENTRE’ and the others to ‘NONE’.
    Hope this helps, let us know. Good luck, Johan
    in reply to: 30 meter Powerlink kabel gezocht: #37176
    Tignum
    GOLD Member
    Het zijn zeker goede pluggen 🙂 Maak er wat moois van! Heb je alle pinouts, ik kan je het BeoLink handboek nog sturen evt? Groet, Johan
    in reply to: Beolab 8000 + Beolab 2 connect to Amp #37208
    Tignum
    GOLD Member
    If your amplifier has a specific sub out, then connect all speakers separately to your amplifier, not via the BeoLab2. You otherwise might risk that the higher frequencies are filtered out by the amp already, and they do not reach the 8000s.
    Checking some webshops for cabling that is meant to connect BeoLabs to pre-outs, they all feed the (5v) trigger signal into the PowerLink cable through either 3.5mm trigger port, or a USB port. The sellers claim that the regular 12V trigger signals of such amplifiers are brought back to 5v by the cable. USB is 5V already. These cables are not cheap in my opinion!
    Here my knowledge/help stops. Maybe a BeoWorld member with actual experience can help you with any other doubt. Good luck!
    in reply to: Beolab 8000 + Beolab 2 connect to Amp #37206
    Tignum
    GOLD Member
    Hello Phil and welcome,
    I would say that if your amplifier is stereo (and has no specific subwoofer connection) then it is best to connect the 8000s to the PowerLink output sockets of the BeoLab2 using good PowerLink cables. This is how B&O has designed it to work: the BeoLab 2 filters out the lower frequencies and the 8000s do not have to deal with those anymore.
    The BeoLab 2 then needs to be connected to the Amp with a PowerLink cable that somehow gets the trigger signal. This 5V signal will tell the BeoLabs to switch on. This is what you refer to with the ‘AUX/RCA PowerLink trigger cable’ I think.
    Steve at Sounds Heavenly (site sponsor) is always happy to help! I think he is back tomorrow. I would not be surprised if he will step in, correct me, and help you. Also in case your amp has a specific subwoofer connection that makes it a bit more complex.
    Or find a nice BeoMaster/Sound/System with PowerLink connections :-)?
    Best of luck, Johan
    in reply to: 30 meter Powerlink kabel gezocht: #37173
    Tignum
    GOLD Member
    Gezien. Komen eraan. Succes!
    in reply to: 30 meter Powerlink kabel gezocht: #37171
    Tignum
    GOLD Member
    Ik heb nog een paar stekkers voor je als je die nog niet hebt. 4 zijn nieuw. Als je je adres geeft stuur ik ze op.image
    in reply to: 30 meter Powerlink kabel gezocht: #37170
    Tignum
    GOLD Member
    Als je het probeert weet je het zeker! 🙂
    in reply to: 30 meter Powerlink kabel gezocht: #37168
    Tignum
    GOLD Member
    Zolang het S/FTP (shielded/foiled twisted pair) is moet het goedkomen. Kost dat veel meer? In de BeoLink manual schrijft B&O Cat7 voor vandaar. Heb je die documentatie? Stuur me anders je e-mail adres per PM, dan stuur ik je de pdf (23mb). Staat enorm veel in over B&O bekabeling.
    Ik ben niet zo van het solderen (heb je vast al begrepen :-)), vind het een enorm gepriegel. Ik weet niet of dat kan met zulke kabels. Als alle kernen en ook de braided shield van koper zijn zou ik eigenlijk ook niet weten waarom het niet kan.
    in reply to: 30 meter Powerlink kabel gezocht: #37166
    Tignum
    GOLD Member
    Hoi,
    Ik kan wel zeggen dat het aankrimpen van RJ45 connectors op deze Tasker kabel een gedoe is: je moet connectors vinden die goed passen bij de dikte van de geisoleerde aders. Niet alle connectoren zijn hetzelfde qua aderdiameter, vaak is het zelfs niet aangegeven. Vooral lastig is de afscherming. Bijeengedraaid is die veel te dik. Om dat allemaal netjes te krijgen vergt dus nogal wat DIY.
    Kun je geen soepele afgeschermde CAT7 sftp patchkabel (met aan beide einden RJ45) van 15m vinden evt? Die aan de ene zijde direct in de Almando en bij de BeoLab zijde zoiets gebruiken (koppelstuk):netwerk-koppelstuk-beschermingsklasse-stp
    om van daaruit een (evt. zelfgemaakte) RJ45 naar DIN kabel te gebruiken?
    Dat scheelt nogal wat gedoe!
