Tignum
Forum Replies Created
Viewing 20 posts - 381 through 400 (of 535 total)
  • in reply to: Three generations of link-system #39226
    Tignum
    GOLD Member
    Hi bnousr, you will need to bring the two new NL sources (A.TAPE and PHONO) to the ML side on your main ML network. I have tried to make more visual Carolpa’s earlier detailed suggestion (to correct if I made a misinterpretation):
    bnousr1.001
    As said, I do doubt if there will be no ‘RADIO’ command conflict, if so it could probably be fixed with a 3rd BLC, something like this:
    bnousr2.001
    which will be a bit more costly ofcourse. Maybe Carolpa or another more experienced can confirm the above / help to get it more complete to get you where you want to be. Regards, Johan
    in reply to: BV6-26 – use of DVI Socket #44693
    Tignum
    GOLD Member
    Hi stotty, don’t press red arrow and GO together! Please try ‘red button’, let go, then ‘GO’. 🙂
    in reply to: BV6-26 – use of DVI Socket #44690
    Tignum
    GOLD Member
    Hi, I do have a BC6-26(9280), and I do recall that I had to put the ‘HDCP mode’ setting to ‘hdmi’ or ‘disabled’, where ‘HDMI’ worked for my AppleTV
    The menu for that is found with Be04 when the ‘cursor’ is at the ‘settings’ position in the TV menu (don’t press GO yet), then press the red arrow button, then press GO.
    Go here (sorry it is in Dutch:-))
    20230315_180422
    Then press ‘red arrow’, and then ‘GO’
    20230315_180435
    20230315_180446
    20230315_180453
    I am not 100% sure if this is useful, as I understood that not all BV26’s have the ‘hd ready’ kit. But worth a try maybe?
    Good luck, Johan
    in reply to: Three generations of link-system #39224
    Tignum
    GOLD Member
    Hi bnousr, I think posting your settings is helping a lot!
    In general, I think you should see the BLCs as filters to pass on sources from ML to NL and vice-versa.
    In case of the BLC-BS6, the A.Slave setting means you can only pass on sources from its ML side onto NL side. As you only want to pass on the PHONO and the A.TAPE sources, you can ‘uncheck’ in the ‘Experience mapped to NL’ all the boxes apart from ‘N.RADIO’ and ‘A.MEM’ (as they are the same as PHONO and A.TAPE). At ‘Name used on NL’  you can call the N.RADIO source ‘PHONO’, and the ‘A.MEM’ source can be called ‘A.TAPE’. The BLC-BS6 will now pass these sources and commands onto the BLC-BSM that is connected to your main ML network. On the IR mapping page, assign the N.RADIO command to BLC-BS6 with NL source renamed PHONO. The A.MEM command is then to be assigned to BLC-BS6 with renamed NL source A.TAPE.
    See my (simple) setting of the BLC connected to my BeoSystem 6500, just for passing on CD onto the NL side:blc
    And the setting of the other BLC to push that CD signal onto its ML side:
    blc2
    As said I am wondering if you cannot better set the BLC-BSM as an A.Slave too, and only pass on the netradio and netmusic onto the main ML network as Carolpa already suggested. I would then assign the ‘RADIO’ IR command to the Beosound Moment’s ‘TuneIn’ NL source, and the ‘N.MUSIC’ (=A.TAPE2) command to the Beosound Moment’s ‘Music’ NL source.
    The only thing that I can’t figure out is how the main ML network will react to a ‘RADIO’ IR command, as it might start the TuneIn radio on the BS Moment, as well as the FM radio of the BS9000. Or am I seeing that wrong Carolpa? Were you counting on a 3rd BLC?
    bnousr, I hope this helps.
    in reply to: RaRa: Beolink Converter 1614 met aanbouw? #44342
    Tignum
    GOLD Member
    Hoi, wellicht om een (doorgeknipte) kabel door een buis te kunnen trekken. Groet, Johan
    in reply to: RaRa: Beolink Converter 1614 met aanbouw? #44340
    Tignum
    GOLD Member
    Hallo HuubC, en welkom.
    Is het niet een vastgelijmde Masterlink ‘junction box’, om meerdere ML kabels aanelkaar te verbinden? Deze heeft aan beide korte einden twee ronde gaten:junction box
    Groet, Johan
    in reply to: 5 Beolab 7.4 for surround #44310
    Tignum
    GOLD Member
    Hi beos6, not a bad thought! Powered speakers with proprietary acoustic lens technology in a casted aluminium cabinet, sometimes for 50 euros. Hard to beat, they were not cheap when new, like 2500. You might need some space for the BV7s and stands that come with them though :-). And they tend to be a bit sticky.
    What was your thought how to place them (stands)?
    Regards, Johan
    in reply to: Beolab 8000 geeft geen geluid meer #44276
    Tignum
    GOLD Member
    Hoi, je kunt hem wellicht het beste opzoeken hier op het forum (via de zoekfunctie) en een Personal Message sturen. Hij zit wel in Utrecht! Succes, Johan
    in reply to: Beolab 8000 geeft geen geluid meer #44274
    Tignum
    GOLD Member
    Hallo telemeeuw, en welkom!
    De eerste series BeoLab 8000 zijn van binnen voorzien van zwart dempingsschuim dat langzaam verteert. Dit wordt vaak foam rot genoemd. Het verteerde schuim kan de printplaten van de luidspreker langzaam aantasten, en daarmee de werking. Er zijn vervangende schuimsets (wit) te koop voor de doe-het-zelvers. Dit is ook gebruikt in de latere 8000s. Maar alleen vervangen lijkt bij jou niet (meer) afdoende. Ikzelf heb mijn 8000s door Beobuddy (hier op het forum) onder handen laten nemen. Hoop dat dit helpt!
    Groet, Johan
    in reply to: What are you listening to…..right now. #33195
    Tignum
    GOLD Member
    in reply to: Three generations of link-system #39222
    Tignum
    GOLD Member
    the primary objective is to feed the audio from the Beosystem 65000 were the Beogram 6500 to the rest of the house which has my biggest interest, so don’t care about the Radio, CD or the cassette (well tape could be fun if it would be easy and without any conflict of commands being re-used) />
    I think that A.TAPE is not a command that also exists under another name, so should be easily possible. Bonus!
    in reply to: Three generations of link-system #39221
    Tignum
    GOLD Member
    bnousr, Carolpa, out of curiosity, I put my BM6500 in option 1 and connected a speaker to it. The system, connected to 1611/BLC/A.SLAVE works as normal.
    In another room (that uses my main ML chain) I could listen to, and control the BG CD 7000.
    Also, when starting the BG CD 7000 (from stdby) from the other room, the speaker connected to the BM6500 stays muted.
    This seems exactly what bnousr looks for. And to be honest, I would find it quite elegant to let the BM6500 amps drive the passive CX and Cona speakers (and not introduce another amp and leave the BM running idle).
    Again, the above is not allowing the BM6500 play any other sources than its own.
    As maybe said before, I think it’s really great that B&O allows to use all these generations of devices together. When it is all set-up (which takes a bit of fiddling) it can work really well.
    Regards, Johan
    in reply to: Soft Touch surfaces #44144
    Tignum
    GOLD Member
    Hi Tony, when they are metal enclosures (like BeoLab 7), you could consider sandblasting/powdercoating. Check this thread with some photographs: https://forum.beoworld.org/forums/topic/beolab-10-paint-melting/
    Regards, Johan
    in reply to: Securing glass panels – Beocenter 9300 #44166
    Tignum
    GOLD Member
    Hi stotty, I used 3M 4910F, VHB™ Clear Foam Tape, 6mm x 33m, (about 1mm) Thick that you could consider to use. It has good bonding indeed, but feels a bit less permanent than glues. I used it on a BeoMaster 4500. In the old forums there are some more threads on this: https://archivedforum2.beoworld.org/forums/p/43948/319119.aspx#319119. Be careful with the thickness
    I used methylated spirit that dissolved the original tape but left the paint on.
    Best of luck. Johan
    in reply to: Three generations of link-system #39217
    Tignum
    GOLD Member
    OK, all clear! Was just thinking – bnousr just wants to push BeoGram 6500 audio onto NL, for the main ML system to use it. Couldn’t the speakers stay connected to the BM6500?
    I agree that with your solution (an ML amp connected to the main ML chain driving the CXs and the Cona) allows listening to all sources (no need for the 3500 anymore).
    Regards, groet, Johan
    in reply to: Three generations of link-system #39215
    Tignum
    GOLD Member
    Hi Carolpa! was hoping you would join :-). I was not saying one BLC would be enough, just that in principle you could use a BLC as an ML splitter (in the same ML chain) when required. Indeed the IR commands logic would be gordian knot needing a bit of untieing! Regards, Johan
    in reply to: Three generations of link-system #39213
    Tignum
    GOLD Member
    Hi, yes, just different form factor. So I reckon you can use the BLC as an ‘ML splitter’ if you need to.
    Even with using the BS6500 with speakers, I still think that with two audio slave BLCs you can get everything working, if you find enough suitable IR commands. And I am actually quite curious, as I am slowly but seriously planning to add a BeoSound9000 to the mix!
    in reply to: Three generations of link-system #39211
    Tignum
    GOLD Member
    Do you have speakers connected to the BS6500? If not, my current thought would be to set both BLCs in A.SLAVE mode, as they are only sources. Set the one connected to the BS6500 to map the desired experiences onto NL. In the other BLC, the one in the main MasterLink network, assign those to a logical command (avoiding the earlier mentioned conflicts, which is a bit the ‘pain’ with MasterLink).
    in reply to: Three generations of link-system #39209
    Tignum
    GOLD Member
    Nice set-up and diagram! What sources of the BeoSystem 6500 do you want to distribute?
    in reply to: Three generations of link-system #39207
    Tignum
    GOLD Member
    hi bnousr, my BeoMaster 6500 (with only a CD7000 plugged in, no speakers) is set to A.OPTION 0, so that it does not react to Beo4 IR signals. My BLC is set to A.SLAVE as well, and it is configured to only pass CD audio onto NL (experience mapped to NL).
    My second BLC is an A.MASTER to pass on audio from the Core (and the other BLC).
    The IR command PHONO is the same as N.RADIO, and ATAPE2 is N.MUSIC . So you need to figure out what command activates what source connected to your BM6500.
    Do you have the “BeoLink Converter NL/ML Type 1790 Installation Guide”? Maybe that can help setting up your BLCs up optimally. Let me know and I can dm you a copy. Let us know how you get along, I can help with some screenshots of BLC settings if you want.
    Johan
