Tignum
Forum Replies Created
Viewing 20 posts - 361 through 380 (of 559 total)
  • in reply to: What are you working on now? #33392
    Tignum
    GOLD Member
    looks very good!
    in reply to: New Software Edge/Shape/Core/BS1/BS2/A9 (mk3/4) #40377
    Tignum
    GOLD Member
    Switching radio stations on the Core through Beo4 and MasterLinked products (using a BLC) did not work a couple of times now. After changing the radio station in the app however, it does work as normal. I will see if this persists and if I can replicate and influence and let you know. I did restart the Core and deleted and rejoined both the Core and the BLC to no avail.
    I found out that after a full system switch-off (in the app, or with a long press on the Beo4) the issue arises: when I then choose RADIO on the Beo4, the last chosen radio station plays, but I cannot use the Beo4 to choose another station. Only after I change radio station in the app once, I can use the Beo4 again for changing stations (I use TuneIn btw). I will see if I can report this to the software team. Is anyone else seeing this too?
    After some friendly e-mail exchange I received this answer: “We are pleased to inform you that yes it will be fixed in a future software update regarding the issue; the issue has been reported to the Product Development team, and they will provide a software update as soon as possible.”
    Good morning, yesterday I updated my Core’s software to v2.3.54367 and it seems that all (B&O) radio station selection (via ML and BLC) works fine now. To test it, I put everything to standby, started RADIO on my BeoSystem 3, and was able to right away toggle up/down stations. Also direct preset number selection works well, including preset 1 (so far that was not at all possible with a Beo4). All working as you would expect. Happy with it! Have a good day. Johan
    in reply to: AV 7000 – what center speaker would you recommend? #48624
    Tignum
    GOLD Member
    Some other thoughts Cyana: move the electronics and cable salad one level down in the cabinet (for Ravsted’s idea), or maybe hang the TV on a wall mount (so you can make more height space for a speaker).
    Nice and clean set-up, your complete 7000 set must be rare!
    Regards,
    Johan
    in reply to: AV 7000 – what center speaker would you recommend? #48623
    Tignum
    GOLD Member
    Hi, I would remove the drawer just below the TV. Put a speaker in there. Make a wooden frame with same dimensions as the drawer. Clamp black speaker cloth on it. Place it in the ‘hole’ in front of the center speaker. You will have a nice integrated center speaker.
    Or even show the speaker! (if it is a nice one :-)). But very good idea this, will look refined.
    in reply to: AV 7000 – what center speaker would you recommend? #48619
    Tignum
    GOLD Member
    Hello Cyana,
    Nice to hear you are expanding the usage of the system, and bring it into the 21st century! I think it is great that B&O also provides support to keep on using older systems, even in today’s NetworkLink systems: my BeoMaster 6500/BeoGram CD 7000 set is eventually linked to a BeoSound Core!
    Check this thread if you want: https://forum.beoworld.org/forums/topic/difference-between-source-sugnals/page/5/
    With placing a speaker behind the TV you might block the tweeters indeed. There is no way to bring the TV up a few centimeters?
    Regards,
    Johan
    in reply to: AV 7000 – what center speaker would you recommend? #48617
    Tignum
    GOLD Member
    Hello Cyana,
    For the center speaker not easy: also the slim BeoVox CXs on their sides are higher than 100mm (they are 120mm). Could look nice & symmetrical. Does your Sony TV by any chance have the possibility for using the in-built speakers for the center channel? There are some higher end models that can do that!
    The manual (you can find it on Beoworld when becoming a silver or gold member ;-)) does not say anything about storing the 5 channel mode as default. It does say that by choosing an audio source ‘sound 2’ (stereo) and by choosing a video source ‘sound 3’ (stereo + center) is selected. I fear you cannot store ‘sound 5’ as a default.
    Keep us posted!
    Regards, Johan
    in reply to: AV 7000 – what center speaker would you recommend? #48615
    Tignum
    GOLD Member
    Hi Cyana, the Cona is a (passive) BeoVox and needs an amplified speaker signal. The red/white cinch connectors do not provide that. So then there needs to be an amp between the AV and the Cona. The Cona is not very powerful as beojeff said.
    I also must revise my original response about the center channel: the center channel red/black clamps do provide an amplified channel, and can only be used with passive (BeoVox speakers) or need attenuation.
    Regards, Johan
    in reply to: AV 7000 – what center speaker would you recommend? #48612
    Tignum
    GOLD Member
    Hi cyana, hi beojeff,
    I did once plan for an AV7000, but then went for a BeoSystem 3. However I thought to remember that the center channel of the AV7000 was not using a PowerLink socket, but had regular red/black terminals. The manual confirms this (but is not specific about what speaker):
    Naamloos
    It would mean you can choose a BeoVox speaker (that has no internal amplification like the BeoLabs have), maybe a CX100 (or two)? BeoLabs that have a[n autosense] line in connection can be connected too (4000/6000/8000) [but would need attenuation]. Beolab 7s do not have such a[n autosense] line in connection and would require attenuation [as well as a trigger signal to power up]. [] Steve (Sounds Heavenly) can help there if you want to go that way. The BeoLab 3500 seems a nice ‘soundbar’ option but is even more tricky to make behave as a center speaker.
    The sub outputs are red/white cinch connections, these do not provide the power-on 5v signal that PowerLink connections provide and BeoLab 2 and 11 need. BeoLab 19 seems to be the easiest [directly] connectable sub. A lot is possible but will need some cable magic [for instance a powered trigger kit].
    You state that the BeoVox 4500s are active, are they then not BeoLab 4500s?
    Hope this helps. Regards, Johan
    in reply to: internet radio for my BeoSound 9000 system #43080
    Tignum
    GOLD Member
    Hi Joost, good to hear you got it all working now!
    in reply to: Flash Your B&O – new(er) thread! #33515
    Tignum
    GOLD Member
    Summertime in Istria, Croatia
    20230803_124406
    in reply to: Beovision 7-32 upgraded to Full HD #47637
    Tignum
    GOLD Member
    But honestly I’m considering doing the same modification of the Beovision 7-40 monitor (still here) as I feel you really loose some of the ‘class’ by just putting a plastic TV on top of the stand….
    Very nice Ravsted! I agree with the above. However, how nice would it be to replace just the glass panel with a thin edge (oled) screen. You will win serious on inches too. Wishful thinking probably, as sizes would need to match very precisely.
    Maybe one day there will be stick on & cut to size screens :-).
    Tignum
    GOLD Member
    Hi TWG, the museum is also very nice!
    Johan
    in reply to: New product launch – beosound theatre? #38387
    Tignum
    GOLD Member
    Beautiful! And it must be a joy to watch a good movie with your setup.
    Congrats, Johan
    in reply to: BeoSound 5 no network connection #47049
    Tignum
    GOLD Member
    Hi Alan, hi Mr10Percent, I just checked my (recently acquired) BS5/BM5 and it also says ‘no’ at network connection (where I can acces it through my LAN for sure), and my ‘last n.radio update’ is 2023-06-07 which is today. Do you think you can update the software? My ‘BS5/BM5 application’ states 7.04.01.1945. Regards, Johan.
    in reply to: BEOVOX MS 150.2 Woofer #46781
    Tignum
    GOLD Member
    Hi Christian – good progress! For the fabric: I used akustikstoff.com (for my 8000s & 6000s) and liked it.
    Regards, Johan
    in reply to: Three generations of link-system #39255
    Tignum
    GOLD Member
    Keeping you posted, I have now integrated the BS5/BM5 combo into the mix. What I did since I got it:
    • rubbed the sticky soft touch coating from the BS5 with methylated spirit (under the coating is black gloss  paint, it is looking quite nice again, and is much nicer to touch)
    • had the cover of the BM5 sandblasted and powder coated in black fine structure (only pity is that the BANG & OLUFSEN logo is lost now)
    • vacuumed out the BM5 with a soft brush (lots of dust, I damaged the yellow soft foam pad of the fan, but could replace it with a pad I had left when I gutted an HDR2)
    • cloned the 500G HDD onto a 1T SSD, then stretched the data partition so there is almost 1TB space for content (using the helpful threads in the Forum and with some help of my brother, the BM5 needed a couple of recovery startups but now works rock solid)20230429_201643
    • 20230429_201716
    • put it in Option 0, connected it to NL using a 3rd BLC in A Slave setting, only pushing N.MUSIC onto NL (I tried it straight onto the main ML network first with AM NO setting, but the system behaved a bit weird then, possibly with the main BLC being an A MASTER)
    • converted my ALAC based iMusic library (all ripped CDs) into FLAC files using XLD
    • placed the set behind my home office desk so the BS5 sits next to my monitor (so not in the kitchen :-))
    Now the system looks like this:
    As I type this I am I in the kitchen listening to The Police playing on the BS5 in the attic.
    I can also play my (ALAC) library through my Core and Twonky, but what I want to explore now is the MOTS functionality (currently 20% scanned), as well as the Favorites, using the four colored buttons on the Beo4. Also I think the screen is not perfectly horizontal, maybe there is a possibility to set the rotation stop of the bajonet style fixation for that.
    The interesting thing to know maybe is that when I did set the BS5 to connect to my Twonky/DLNA ALAC library, it played all the ALAC files fine, it only did not show the album art at all. I decided not to dig any deeper on that and convert the library into FLAC and place it on the (now) SSD of the BM5. All album art is shown perfectly after using the XLD converting.
    Enjoy your sunday! Regards, Johan
    in reply to: Beomaster 5500 refurbishment – success! #45970
    Tignum
    GOLD Member
    Nice set herrit! And really complete with the record deck and the mcp. This was the set my father in law bought (with BeoVox Pentas) that got me infected with the BeoVirus. Very much worth fixing, maintaining and using. Enjoy! Regards, Johan.
    in reply to: RIP Peter Pan #45976
    Tignum
    GOLD Member
    Thanks for letting us know MM. I will remember his contributions to the forum with sometimes hilarious photoshop exercises but mostly with very helpful insights and visuals. Always worth a read. I do like his stubbornness to stick with what he needed, changing just to change is not always good.
    It’s nice to know you had this special friendship going on!
    in reply to: DIY Beolab 8000 Wood frets (STLs included). #36865
    Tignum
    GOLD Member
    Very contemporary tuttivini! Good cabling for the rear 8000s 🙂
    in reply to: Beosystem3 #44094
    Tignum
    GOLD Member
    Hi Graham, that sounds like the best option to keep operating the BS3 as you are used to. Ideally the Sony has some kind of autosense to switch on when your BS3 provides a signal to it. Maybe you can align on that with the Sony guy. Regards, Johan
