Tignum
Forum Replies Created
Viewing 20 posts - 261 through 280 (of 538 total)
  • in reply to: Beosystem 3 screen out to Hdmi #46198
    Tignum
    GOLD Member
    Also have been checking the Service Menu:
    service menu
    But did not find it there either. Could it be because we don’t have a B&O screen connected?
    Sorry that I cannot help you any further! Johan
    in reply to: Beosystem 3 screen out to Hdmi #46197
    Tignum
    GOLD Member
    Just tried myself and could not yet find a way to configure to 1920×1080. Will seek some more.
    in reply to: Beosystem 3 screen out to Hdmi #46196
    Tignum
    GOLD Member
    Hello and thanks for your reply. I am doing many and many and many trying from months, buto the problem is not solved. It seems i am not able to find the menu tou suggested. In “Options” i press “red arrow” and go, or “0 0 go”, but i really can not find the “screen configuration”. However, after many and many try, i can tell “EDID emulator” is not the solution. And i can tell the problem source seems to be “Playstation 4” connected to “Dvd source”. U did a “giant work” and i am very frustrating because this seems to be a very stupid setting problem able to destroy all mi job……
    Hi emabonacchi, this is the text from the BS3 service manual:
    It is important that you only place the ‘cursor’ on ‘OPTION’. Don’t press go yet.  ‘OPTION’ only needs to be highlighted, then press the red button and GO. Hope this helps. I will try on my BS3 to reconfirm.
    Regards, Johan
    Tignum
    GOLD Member
    Hello mjcallo, welcome. That looks really good! Hope you will get the cassette part working again. If you will not find the stands, you could reproduce them maybe, see for instance: https://archivedforum.beoworld.org/forums/t/41952.aspx for inspiration.
    Best of luck, Johan
    in reply to: Deurtjes BEOcenter 2300 #52396
    Tignum
    GOLD Member
    Hallo hvb, beter nog, je wordt silver of gold member, en kunt de service manual downloaden van de BeoWorld site!
    Succes en groet Johan
    in reply to: Fitting a new Apple TV into a Beoplay V1 #46181
    Tignum
    GOLD Member
    For now, this should be it then (using less confusing names):‎220122 apple tv ir location.‎001
    in reply to: Fitting a new Apple TV into a Beoplay V1 #46179
    Tignum
    GOLD Member
    Thanks! I did google a bit more for the IR sensor location of the 2 and 3 and found these (for the 1427):
    1427
    And for “second and third generation”:
    apple-tv-3e-generatie-poorten.jpg kopie
    This is different from what I made sofar. Some teardown images (of 2nd gen) confirm center location.
    What do you think?
    Regards, Johan
    in reply to: Fitting a new Apple TV into a Beoplay V1 #46176
    Tignum
    GOLD Member
    Helli Guy, for my own reference (and hopefully for others now too) I made the below overview. I have various of these black AppleTV boxes (from 3rd gen up to 4K) and remember I was trialling (and erroring) to find the right location to put the IR emitter.
    Do you think this is about right? Note that the LED status indicators are white dots that I added (and are not necessarily at the right location)
    The dimensions and version numbers I took from the Apple support site.
    Cheers, Johan
    in reply to: B&O Beolab 6000 aansluiten op Yamaha silent piano #52326
    Tignum
    GOLD Member
    Dag Gertie, top. Laat je weten hoe het bevalt? Succes en prettige avond.
    Groet, Johan
    in reply to: B&O Beolab 6000 aansluiten op Yamaha silent piano #52324
    Tignum
    GOLD Member
    Nog een reden om bij Steve te bestellen – gratis instructievideo: https://www.youtube.com/watch?v=QRNExNUcrgo – vanaf 4:50.
    Hij zegt daarin over de verloopstekker: “Just drop a note with your order and I will add a free adapter for you”. Hoe mooi kan het worden?
    Groet, Johan
    in reply to: B&O Beolab 6000 aansluiten op Yamaha silent piano #52323
    Tignum
    GOLD Member
    Dag lumix, de aansluitingen zijn inderdaad niet 3.5mm, maar 6.3mm phono jacks, waarvan de buitenste stereo is “AUX OUT [R]/[L/L+R]”.
    Met een eenvoudige verloopstekker als deze (google “6.3mm to 3.5mm stereo plug”):jack-verloopstekker-aantal-per-stuk
    Kun je de Soundsheavenly kabel inpluggen. Volumeregeling gaat dan hetzelfde als met je hoofdtelefoon: “You can use the [VOLUME] control on this unit to adjust the output volume from the AUX OUT jacks.”
    Steve van Soundsheavenly is de sponsor van deze site, het zou wel leuk zijn als je bij hem bestelt. Steve verzendt naar Nederland.
    Je moet wel (aan de onderkant) de input schakelaars van de BeoLabs op ‘LINE’ zetten:
    schakelaarline
    De kabels zullen de geluidskwaliteit niet beïnvloeden.
    Hoop dat je zo verder kunt! Groet, Johan
    in reply to: beoplay connection hub & beolink passive #52188
    Tignum
    GOLD Member
    I added the photographs of the wiring of a RJ45 to DIN 8pin cable to a previous post.
    in reply to: B&O Beolab 6000 aansluiten op Yamaha silent piano #52321
    Tignum
    GOLD Member
    Dag Lumix, hoe regel je het volume van de koptelefoon op dit moment? Als je de koptelefoonuitgang gebruikt om de BeoLabs aan te sturen, zou je op dezelfde manier het volume moeten kunnen regelen.
    De 6000s hebben een line-in ingang waardoor ze aan gaan als er een geluidssignaal wordt waargenomen.
    Soundsheavenly heeft hier een eenvoudige oplossing voor: https://soundsheavenly.com/line-in-connection/77-243-minijack-to-beolab-line-in-using-phono-rca-sockets-one-cable-for-two-speakers.html#/5-length-5m
    Laat je weten of dit is wat je bedoelt?
    Groet, Johan
    in reply to: Questions and or suggestions for the B&O app team #50821
    Tignum
    GOLD Member
    Hi, Michael,
    Great to see you (we) are directly in touch with the people that make the stuff we love.
    Hoping the NL/ML converter (BLC – aka “swiss army knife”) will get some development attention in the future, there are two things that I can think of.
    I run a couple of MasterLink networks connected (and fed) through BLCs (the 4th one arrived this week :-)). The things that I would love (if possible):
    • Get visibility and control of BeoSound/BeoMaster 5 on the app screen (cover art, playlist etc)
    • Get the possibility to assign the AirPlay source directly to an ML IR command (as is possible with e.g ‘B&O Radio’ and ‘Optical’ (see photo).20240120_103203
    Let me know what you think, Regards, Johan
    in reply to: Beovision 3502 #51753
    Tignum
    GOLD Member
    Hi Guy,
    These plugs/cables are used here in Europe (Netherlands), you can plug them in two ways, often on both ends even.
    apparaatsnoer-c7-lengte-0.5-meter
    Hope this helps, regards, Johan
    in reply to: beoplay connection hub & beolink passive #52186
    Tignum
    GOLD Member
    ^ Very neat – what make/model is the little 2 port terminal box?
    It is a Delock 2 Port RJ45 Cat.6A LSA
    in reply to: beoplay connection hub & beolink passive #52185
    Tignum
    GOLD Member
    Thanks Guy! This should help anyone replicating the solution.
    Some commercially available RJ45 to 8pin DIN cables seem to differ a bit nowadays from the table on the right.
    The ‘Data GND’ is a separate copper strand in the cable (not a shield around the white ‘Data’ wire).
    The ‘Signal GND’ wires are not braided copper shields but green (R) and brown (L) isolated wires, marked with a thin white stripe, per pair isolated with aluminium foil. The total bundle of wires is shielded with a braided shield. See below pictures:20240120_19311720240120_19361020240120_19323220240120_194156
    in reply to: beoplay connection hub & beolink passive #52183
    Tignum
    GOLD Member
    Same logic, but with a little more elegant box (to put into the TV cabinet of my parents in law):20240118_11403620240118_113955
    in reply to: beoplay connection hub & beolink passive #52181
    Tignum
    GOLD Member
    I got it working. The only thing to do (at least for a Passive 1656) is to get the trigger signal from the ‘speaker on/off’ (DIN pin 4) onto the ‘power on’ (DIN pin 1).
    In the end I decided not to cut/solder funny cables, you never know when you will fool yourself with it later :-), so just wired a two port RJ45 terminal this way:
    20240117_205719
    All that is needed are those 5 connections. I = in, O = out.
    I run a Cat7 patch cable from the Connection Hub to the terminal in (I), and a PowerLink Mk2 RJ45 to 8 pin DIN cable from the terminal out (O) to the PowerLink socket of the Passive. PowerLink Mk2 is needed as it has the ‘Power On’ wire going to pin 1.
    Hope it is useful to someone sometime.
    Thanks Guy for your interest and support.
    Regards, Johan
    in reply to: BeoWorld – For Sale (UPDATED 18th Feb 2024) #52128
    Tignum
    GOLD Member
    Hello Lee, I was very happy to see that the site came alive after the change. Thanks a lot to you and Keith. I hope you will find a good solution/buyer. BeoWorld is a rare and wonderful community.
    Johan
