Tignum
Forum Replies Created
Viewing 20 posts - 201 through 220 (of 538 total)
  • in reply to: ml powerbox alternative #54111
    Tignum
    GOLD Member
    Hi Madskp, nice to have a fellow wonderer! When I will get my (5th) BLC I will produce a USB to RJ45 5V cable and test it. Trusting I will not brick the BLC with that! I read somewhere the thought that the BLC is mainly developed to bring ML sources to NL and not vice versa. This explains there was no need to provide ML power.
    I also believe there is more going on inside the ML Power Box than just put 5v into ML. If someone has one, could open it and share a photograph of its magic content, that would help a lot I reckon. A mini flux capacitor could be in it? Who knows?
    Regards, Johan
    in reply to: Refoaming Beolab 90 bass driver. #54015
    Tignum
    GOLD Member
    When I read the title of the post I thought WHAT?! You got me there haha.
    in reply to: Beogram 4002 Restoration #53983
    Tignum
    GOLD Member
    IMG_6477
    That joint for sure looks amazing to start with!
    in reply to: Beosound 5 option question #53840
    Tignum
    GOLD Member
    Hi Razlaw, I can start/stop the BS5, go to next/previous song, instruct a new MOTS seed, access colored favourites, select internet radio stations from preset list. So basic control. In my case the BS5 is in the office/attic where I use it mainly. But in the kitchen/living I often listen to BS5 N.MUSIC and let it MOTS on. I am discovering songs in my own collection that I sofar never really listened carefully to! And I enjoy knowing that my B&O kit is maximally integrated. Regards, Johan
    in reply to: Beosound 5 option question #53838
    Tignum
    GOLD Member
    I have a Beosound 3000 connected by ML but it does not have the newer software chip to function well with a BS5 also connected. Have spent many hours trying to get both to work together well. The BS3000 would need a new chip with Option 5. Second, having N Music available both from NL and Mozart products and the BS 5, I thought might cause problems…..although as I type this it occurs to me I could rename N. Music on the BS5 as well as N. Radio.
    Hi Razlaw, my thought was to introduce a second BLC: one for the BS3000 and one for the BS5, both A.Slave. That should allow to ‘filter’ the audio sources you want to have ‘mapped to NL’. And maybe solve your Line In / Mozart problem?
    In my (non Mozart) set-up I do the same: I have one BLC feeding BS5 N.MUSIC into NL, and one feeding BS6500 CD into NL. Works well.
    Just to be sure! Hope this helps, regards, Johan
    in reply to: Beosound 5 option question #53834
    Tignum
    GOLD Member
    Hello Razlaw, I would say option 1? The only ‘no speakers connected’ setting is 0, but that is disabling IR remote control. Apart from Option 1, all settings are meant for a MasterLink setup in my view.
    “The music system has five different Option settings:
    Option 0. Used when your music system is connected to your video system and no speakers are connected directly to your music system.
    Option 1. Used when your music system is set up on its own or connected to a video system, when speakers are connected to your music system.
    Option 2. Used when your music system is set up in one room and connected to a video system set up in another room.
    Option 5. Used when your music system is set up in a link room which also comprises a Bang & Olufsen television.
    Option 6. Used when your music system is set up in a link room without a Bang & Olufsen television.”
    Regards, Johan
    PS – why not ML connect it to a BLC and enjoy control from other devices?
    in reply to: Beoplay Converter nl/ml for sale #53852
    Tignum
    GOLD Member
    Hey! I’ve got this converter for sale. Its in excellent condition. I am missing the power adapter unfortunately.
    Hi Beoboyo55, FYI, these BLCs work with a normal 230V power cable, no adapter/transformer needed. Regards, Johan
    in reply to: beo5/6 adaptor part #53588
    Tignum
    GOLD Member
    Hello matador – good hint! I checked my plumbing box and found a few strong plastic rings with a matching (outer) diameter. I cut off the rubber ‘sock’ from the adaptor and found metal – steel for the magnetics with the base obviously. I fixed the ring with some good double sided tape, and it works well:
    IMG_0172
    IMG_0171
    I will now try and find TX5 1.5mm x 5mm screws as one of them has a very tired head.
    Merci! Regards, Johan
    in reply to: beo5/6 adaptor part #53586
    Tignum
    GOLD Member
    Hi Matador, that is a generous offer, I think that it is a highly complicated part to measure and draw!
    For now I just some horribly cut transparent packaging tape to keep all parts together while I will get a virtual machine working and the configuration tool running.IMG_0164
    Some better cut black tape (maybe plotted) could do the trick also. Let me try that first.
    The plastic material of the ‘ring’ is quite soft, I guess for a silent placement. But it got torn anyway. The plastic close to the copper contact points feels much harder. It could be a 2-piece construction maybe? Regards, Johan
    in reply to: Beo5/Beo6 battery #53742
    Tignum
    GOLD Member
    Hi, I do have the original battery still – it says:
    • basic cells by PANASONIC
    • HHR-120AAB33 F1x2
    • 2.4 Volt / 1200mAh
    • BEO5 PA-PN0095.R002IMG_0163
    there is a (Dutch) vendor that uses a photograph of the original battery, priced at 69 euros, here: https://www.idav.nl/beocom-5-6-batterij.html.
    Hope this helps. J.
    in reply to: beo5/6 adaptor part #53584
    Tignum
    GOLD Member
    Back on topic 🙂 No one with a crashed Be05/6 with a good adaptor part?
    Regards, Johan
    in reply to: beo5/6 adaptor part #53583
    Tignum
    GOLD Member
    Hi Matador, no the bad one had a white sticker: https://forum.beoworld.org/forums/topic/beo5-beo6-software-firmware-versions/#post-31292 but I get what you say – can we trust the appearance?
    Regards, Johan
    in reply to: beo5/6 adaptor part #53581
    Tignum
    GOLD Member
    Googling the EAN code on the box resulted in this site: https://www.batteries4pro.com/en/multimedia/remote-control/3,19049-24v-12ah-nimh-battery-for-remote-control-bang-olufsen-beo5-4894128166993.html. They use a very similar image. Quite a bit cheaper. Worth a try? Regards, Johan
    in reply to: beo5/6 adaptor part #53579
    Tignum
    GOLD Member
    Hello Matador, I did use this battery https://www.123accu.nl/Bang-Olufsen-8700091-HHR-120AAB33-F1x2-accu-2-4-V-1200-mAh-123accu-huismerk-i47359.html for some weeks now and it seems to work fine.
    Regards, Johan
    in reply to: Beo5 & Beo6 Software (Firmware) versions #53385
    Tignum
    GOLD Member
    Hello, that is correct. I bought two batteries in the end.
    This one did not work.
    IMG_0157
    It seemed to work at first, but would not charge. Sometimes it showed it was fully charged, but when the remote was taken off the charger, it told it was low.
    This one (from here: https://www.123accu.nl/Bang-Olufsen-8700091-HHR-120AAB33-F1x2-accu-2-4-V-1200-mAh-123accu-huismerk-i47359.html) worked:
    Bang_&_Olufsen_8700091__HHR-120AAB33_F1x2_accu_2.4_V_1200_mAh_123accu_huismerk_ABA00111_big
    Its box:
    IMG_0158
    IMG_0159 2
    Hope this helps! Regards, Johan
    in reply to: B&O videos for 2024 #53216
    Tignum
    GOLD Member
    Hi Steve, would it be an idea to explore how B&O has set up their support team, how they organized dealing with the different requests coming from their customers?
    Regards, Johan
    in reply to: Flash Your B&O – new(er) thread! #33521
    Tignum
    GOLD Member
    The cat enjoying Bryan Ferry behind the couch.20240301_154100Regards, Johan
    in reply to: CX100’s Resto-Mod #53120
    Tignum
    GOLD Member
    Curious to see how much love these good old CX100s are going to get xschop!
    in reply to: Beosystem 3 screen out to Hdmi #46206
    Tignum
    GOLD Member
    Hi emabonacchi, I do use my BeoSystem 3 like that. The video inputs go into my LG OLED c9 (like an apple TV), the audio signal comes from the TV through its Toslink (optical), is then converted to S/PDIF digital coax, and fed into the BS3. Dolby Digital 5.1 surround sound is supported.
    The idea is to use the modern 4K TV as the ‘video hub’, and the BS3 (with its MasterLink capability) as the ‘audio hub’.
    Regards, Johan
    in reply to: BeoWorld – For Sale (UPDATED 18th Feb 2024) #52169
    Tignum
    GOLD Member
    Hello Mark,
    Great to see you value BeoWorld, with all the work Lee and Keith have done to allow many to bring and take useful information for a better Bang & Olufsen experience. And have a good laugh (or rant) in doing so :-). Looking forward to your input!
    Lee, Keith, it has been a pleasure to ‘feel’ your dedication through the years. I hope to see you on the forum for many more years to come. Many thanks to you.
    Regards, Johan
