Forum Replies Created
Severed_hand_of_skywalkerBRONZE MemberSo yesterday my Theatre stopped outputting video to my LG TV. After an hour of troubleshooting I figured out that the problem was the ARC cable supplied with the theatre. I think I’m not the first person to have this problem with the cheap cable. My suggestion is to replace it with a good cable proactively.
Severed_hand_of_skywalkerBRONZE MemberTook some new pics of my theatre now that I’ve had it about a month. Love it more every day.
Severed_hand_of_skywalkerBRONZE MemberSo is there any way to revert back to TuneIn?
Severed_hand_of_skywalkerBRONZE MemberGreat video. As a designer myself I love these types of stories.
Severed_hand_of_skywalkerBRONZE MemberI did it and regret it. 80% of the stations I listen to in TuneIn are not in B&O Radio which I am very very unhappy about.
Severed_hand_of_skywalkerBRONZE MemberI believe I am reading it correctly, that if I want to add two wireless speakers, the only wireless standard supported is WISA, and am I correct that when I look at B&O’s product offering on their website, for a wireless rear surround option, the BeoLab 18’s are the least expensive option at $11k per speaker? Will any of the Beosound series work via power link in a wired application?
Yes any old Beosound speakers will work with the theatre through powerlink or you add the wireless transmitter (I wouldn’t use wireless unless you REALLY had to).
I wouldn’t go with BL18’s as rears unless you have a ton of cash as it’s overkill for most rooms. You can get used BL3 or BL4000’s or even a used BL17 for rears and it should work just as well (again depends on how big the room is).
I also moved from an ARC receiver to the Theatre and it’s very seamless to use and switch inputs. It’s all not as daunting as it sounds.
Severed_hand_of_skywalkerBRONZE MemberThere are tons on eBay.
Severed_hand_of_skywalkerBRONZE MemberMy new Theatre BL18 and BL3’s
Severed_hand_of_skywalkerBRONZE MemberNew software update for BST today. 2.3.4. No indication what’s new.
Ooops I saw someone mentioned this yesterday.
Severed_hand_of_skywalkerBRONZE MemberHow does one get the BeoRemote to work with Apple TV without IR? HDMI control should do it right? But how I set that up?
Severed_hand_of_skywalkerBRONZE MemberHow exactly does one go about submitting missing radio stations that are in TuneIn but not in B&O Radio please?
17 November 2022 at 03:57 in reply to: Multiroom Beoplay A9 Gen 1 and Beoplay A8 with Beosound Moment #40187 Severed_hand_of_skywalkerBRONZE MemberThe cost of the Core it better just to get a whole new B&O product like a Level for not that much money especially if you sell your A8. The Level will sound better and portable too.
Severed_hand_of_skywalkerBRONZE MemberEvery few days my moment gets stuck on this screen and the only way I know how to get out of it is by going into the app and telling it to restart itself. I have check for updates turned OFF in the app and it still does this. Is there a way to restart the moment on the unit itself rather than the app?
Severed_hand_of_skywalkerBRONZE MemberI think you need to talk to your dealer. I used a dealer on the other side of my country and I got the first order they got straight from Denmark to NY then NY to Toronto and a private delivery company dropped it off in my place all before halloween.
Severed_hand_of_skywalkerBRONZE MemberI was in a similar situation as you where I had a Marantz 6011 receiver with pre-outs powering my BL18’s and BL3’s for about 7 years and I was rather happy with it. Marantz is really the best sounding receivers I have ever used.
But I just replaced it all with the Beosound theatre and reported my issues with it here. But to be honest once you get used to the sub menus of the app and get it set up it works very well. Better than I was expecting but I had low expectations based on previous experiences. I’m quite sure they will update the software to make things better.
In terms of experience and setup the Theatre kills the marantz. You don’t have to worry about what you plug into what speaker port. You don’t have to set crossover levels per speaker you don’t have to go through a long setup etc. The Theatre basically does the hard work for you.
In terms of sound it’s complicated. The marantz really made the speakers transparent and filled the room maybe more than was intended, but I loved that. The bass was clean and not boomy and the 5.1 surround was flawless. My only complaint is that the centre channel never sounded clear or loud enough despite a high end B&W speaker.
The theatre accomplishes a lot considering I no longer have an external sub hooked up. 90% of the time I feel like I don’t need one but there is a bit of impact at some levels I feel are missing. The theatre doesn’t seem to make quite as much use of my rears as my marantz did so I usually feel like it’s a forward stage unless something bold happens in the rear speakers. On the plus side the centre channel is always perfect. I don’t know if it’s the processing or the speaker or both. The bass is also there but it’s very clean but I feel like even if I add the sub this is just a typical B&O non-offensive level of bass. I feel it does a great job with movie audio when I throw it an atmos track but not as good at up converting older 3.1 or 2.0.
So in terms of sound difference there is a HUGE price difference between the two but I don’t see the value in that difference. The value for me is more the experience with the theatre as its more Apple like. Everything detects each other and works well with one another. It finds all the other B&O equipment in my house and will unify everything. And of course I no longer have a huge box just to process the sound, its all hidden within the theatre.
So if you just care about sound go with an external system. If you care about overall experience and design all for much more money go for the B&O.
Severed_hand_of_skywalkerBRONZE MemberSo, just ordered my Theatre!
Just a quick question, is the B&O app better on IOS or Android, or is it the same? Just wanting to set up a user hub in advanced. Thanks
Typically most apps are better on iOS. Basically even Android enthusiasts recommend and iPad over any android tablet. Yes that will be debatable.
Severed_hand_of_skywalkerBRONZE MemberSo good news… the buzzing sound I was hearing in my front right BL18 speaker was being caused by the cable. It was a brand new Cat7 cable but that didn’t cut it somehow. My dealer sent me a cable and the problem went away.
Severed_hand_of_skywalkerBRONZE MemberIt is my understanding the only way to update the software of the Beolab 17 is with the wireless transmitter? It would be nice if you could do it through the Theatre.
I was thinking the same. Its totally baffling that we cannot.
Severed_hand_of_skywalkerBRONZE MemberYes they have their fans for sure. The Mark II’s are more valued.
Severed_hand_of_skywalkerBRONZE MemberDo the 18’s up front widen the width of the soundstage?
By a ton. I mentioned in my day 1 post that on its own the theatre sounds very much like a soundbar. A good one but still very central front.
Using the 18’s as the fronts made a huge difference in the sound stage making it much wider.
