Millemis
Forum Replies Created
Viewing 20 posts - 1,121 through 1,140 (of 1,253 total)
  • in reply to: Beosound 9000 mk1, mk2, mk3 data-link #36977
    Millemis
    Interesting….worth investigating!
    Anyone with a MK1 here to test it?
    in reply to: Beolab 3500 from Beosound 9000 via masterlink cable #36994
    Millemis
    Have you tried to disconnect both and reconnect?
    Tried pulling out the ML cable (sorry, I know that is cumbersome)?
    Please do check the ML wire.
    Do you have a junction (box) somewhere along the way?
    in reply to: Beosound 9000 mk1, mk2, mk3 data-link #36975
    Millemis
    Sure….that is well known (amongst those in need of datalink).
    In retrospect it is a pity, now that the Beogram/vinyl players have become so popular.
    If you don’t need Masterlink, you could however, use the Phono socket on one of the older Beomasters (3500/4500/6500/7000 etc).
    Also see:
    https://www.beoworld.org/article_view.asp?id=64
    in reply to: Beosound 9000 mk1, mk2, mk3 data-link #36973
    Millemis
    None has datalink – as far as I know.
    in reply to: Beoplay 500 #36938
    Millemis
    Part of understanding this is the wish to take part in the big current market for headphones – homeworking.
    https://press.bang-olufsen.com/d/gKpSDxqk8eyT/news#/august-2022/bang-olufsen-to-win-hybrid-workers-with-microsoft-teams-and-zoom
    in reply to: Beoplay 500 #36934
    Millemis
    Maybe you are right….or the design is similar!
    P.S.
    This is the source of the picture:
    BANG OLUFSEN BEOPLAY 500 Wireless Active Noise Cancellation Over Ear Headphones User Guide
    in reply to: Beoplay 500 #36932
    Millemis
    Yet another pair of headphones.
    Fairly easy to find a picture on the internet.
    3D1F9888-0DB6-4600-9B26-A124C9854082
    in reply to: Beoplay V1-40 vs. Beovision 10-40 ? #36681
    Millemis
    Ich stimme trackbeo zu – der BV11 hat das beste von beiden.
    Von den zweien wäre V1 meine Wahl……übrigens – ich finde den nicht ‘ugly’.
    Aber wenn du noch Masterlink-basierte Audioprodukte hast – und die unbedingt behalten möchtest – wäre BV10 schon noch zu überlegen.
    Mit eksternen Lautsprechern angesclossen gibt es eine gute lösung.
    Das grösste Problem da meiner Meinung nach ist, daß eine PUC-lösung (für Steuerung von externen Geräten z.B AppleTV) nur durch ein Update vom Techniker möglich ist.
    Aber vielleicht reicht dir ein Chromecast-dongle.
    Das ist alles viel einfacher mit dem V1.
    (Der hat auch noch Netradio eingebaut).
    in reply to: Beosound 5 / beomaster 5 hdd upgrade #36780
    Millemis
    Hi yael and welcome to the forum.
    You could start reading this thread from the old forum:
    https://archivedforum2.beoworld.org/forums/p/6533/91292.aspx#91292
    in reply to: Beosystem 7000 und Beovision Eclipse #36645
    Millemis
    I can easily reach (and play from) my Beosystem 7000/CD on my Essence in a linked room.
    The setup is Beosystem 7000 -> Beolink/ML Converter -> NL/ML Converter -> into my NL products.
    Why shouldn’t that be possible with the Sound Center……which is a NL product?
    It is all about how the setup is configured!
    2DA91609-8FB5-48E6-91A4-1E9C1E1FB154
    in reply to: Beosystem 7000 und Beovision Eclipse #36643
    Millemis
    Hallo Matthias
    Eigentlich gibt es 2 Möglichkeiten.
    1: die kompliciertere und bessere.
    Du brauchst einen (B&O) ML/NL Konverter um deinen BM7000 bzw den Masterlink Konverter mit einem NL-basierten Setup (Eclipse und eventuelle andere NL-Lautsprecher im Setup) zu verbinden.
    So kannst du den BM7000 inclusive Beogram ungefährt so bedienen wie vorher mit dem BV10.
    2: die einfachere/günstigere, aber nicht so bequeme Lösung.
    Ein (DIN-)Kabel vom BM7000/A.Aux oder auch vom PL zu Minijack/Line-Eingang am Sound Center/Eclipse.
    Hierbei wird einfach das, was am BM7000 abgespielt werden über die Lautsprecher/Eclipse, hörbar. Die Quelle/BM7000 muß manuell/Beo4 ausgewählt/kontrolliert werden. Die Laustärkeregelung erfolgt über den Eclipse.
    2a: falls es dir nur um den Plattenspieler geht, könntest du einfach diesen mittels Adapter DIN zu Minijack mit dem Line-Eingang am Soundcenter verbinden (der BM7000 wird dann nicht benötigt).
    Der Beogram muß mauell bedient werden/Lautstärkeregelung über Eclipse.
    Hoffentlich hilft dies ein wenig!
    in reply to: “Hey Google, play the Beogram” ;-) #36525
    Millemis
    OliverC is right…that is the signal chain (which also includes a MCL to ML Converter in order to integrate the MCL Beomaster to the ML chain).
    The Beolink Gateway (as well as the newer Beolink Intelligence) makes the voice controlling possible.
    Means no magic……but clever programming combined with the linking possibilities built-in to the Bang & Olufsen products.
    Something that you would want that more B&O dealers would/could showcase!
    In the cinema room they are using a Trinnov Altitude audio processor (unless they have changed that lately). This advanced processor – amongst a lot of other things – makes it possible to set up several different speaker groups like we also know it from the BSys4 respectively the Sound Center of the newer BV’s.
    This way B&O can showcase different multichannel Beolab setups in the same room.
    The Trinnov processor can also be integrated with the Beolink Gateway for creating different scenes (lightning, screen etc) as Steve told us in the video.
    All in all that room is a further development, a perfection of what a B&O setup has been able to since the days of the Beosystem 3/cinema options.
    @Steve
    Thanks for the video – I have been looking forward to it ?
    in reply to: BeoLab5 internal DACs #36438
    Millemis
    Of course there is a DAC inside, but that is part of the signal processing, that is responsible for any signal going into the BL5’s.
    Many people claim to hear a difference using the digital vs the analog input.
    IMO it is hard to a/b testing, since you will have to have exact the same SPL for both.
    Besides external DAC’s which are part of both solutions, are mostly (quite) different – using different filter settings etc.
    You normaly do not know everything about each signal chain!
    In my view it will be impossible to compare ‘your DAC’ and the DAC solution in the 5’s!
    So choose what you like best……..…or skip the hassle with using an external device, if you already now don’t notice a significant difference.
    Enjoy the music.
    in reply to: Connect Beogram 4400 to a CD Player #36395
    Millemis
    As far as I remember the BM4400 has 5-pin input connections (one for Phono and two for Tape).
    Basicly you can use any CD player – in some cases you’ll have to use an adapter (R/L to DIN).
    If you want vintage B&O….go for a CDX/CDX2 – which one is better the vintage specialist here may tell you.
    There you have options for controlling directly on the device.
    in reply to: How to move Beovision Avant 32 #36372
    Millemis
    That is not going to be an easy task.
    I’d lay it on the back with a lot of blankets/cushions to stabilize.
    Or rather…..I’d go looking for someone with a bigger car so that it could stand upright.
    in reply to: What are you listening to…..right now. #33162
    Millemis
    Here is another one of my favourites.
    Bear with me – much more time to listen for time being ?
    The Mary Fahl album Live At The Mauch Chunk Opera House from 2014.
    Since it is a live album, I let the TrueImage processor upmix to 5.1.
    0F531F5A-FA9A-42D2-A84C-F289B651206B
    in reply to: What are you listening to…..right now. #33161
    Millemis
    The band Renaissance touring in 2014…..with Annie Haslam – and Mary Fahl (who had a new album out a couple of days ago) as guest.
    Millemis
    Thanks!
    Obviously a work in progress.
    We’ll see sometime in the fall……when they have sorted things out.
    in reply to: Set-Up 5.1 Meinungen #36338
    Millemis
    Wenn du auf 5.1 sowieso begrenzt bist, wäre es ja gar nicht möglich.
    Auch da der Couch an der Rückwand steht, ist eine 7.1 Konfiguration schlecht machbar.
    Ich denke…..ein Paar BL 8000/BL3 R/L vom Sofa würde besser aussehen.
    Wie groß der Mehrwert im Sound ist, kann nur ein Test zeigen.
    Probieren geht über Studieren….wie man sagt.
    Wenn es dir möglich ist?
    P.S.
    10 Meter zum Fernseher ist doch sehr viel…..auch wenn es ein grosser ist.
    Wenn die Couch ein Stück weg vom Rückwand stehen könnte wäre es soundmässig besser.
    Millemis
    Ok – that explains it!
    Would be nice if you could post a couple of pictures to show how it looks when you choose B&O Radio etc.
    How do you make favourites – can you access these with a Beoremote One (do they show up there)…that is, if you use a BROne with your ASE products?
